August 12, 2026, 14:47:30 pm
42 DCNFs
Topic: 42 DCNFs (Read 39538 times)
42 DCNFs
September 01, 2009, 14:13:20 pm »
Are 42 DCNFs to big for a mild 1776? Would 40 DCNFs work better? (Or still too big?)
stock ported heads
w110 or w120 cam
1 3/8 exhaust
Playing with engine combos for the Manx and trying to come up with a good driver that will keep up with modern traffic. I have the 2332 going in the '66 for going fast.
Last Edit: September 01, 2009, 14:17:03 pm by louisb
Re: 42 DCNFs
September 01, 2009, 14:16:52 pm »
That was a very common set up for Cal Look cars in the '70s & '80s. I don't see why it wouldn't work today. Those are some great carbs... too bad they're a pain in the neck in the Type 1 engine bay. Other than that, good stuff. Since you're putting those in an open car/body, they'll work well.
Re: 42 DCNFs
September 01, 2009, 14:17:47 pm »
42s will work great on a 1776. I had them on mine and ran an Engle 110 cam with stock valve size heads. It was so fun to drive and had plenty of torque. I've seen them run on a 1600 with no issues. You just have to jet them properly then enjoy!
Re: 42 DCNFs
September 01, 2009, 14:19:55 pm »
Okay, then it sounds like the 42s are the way to go.
Dave Rosique
nobodyouno
Re: 42 DCNFs
September 01, 2009, 14:31:38 pm »
Quote from: louisb on September 01, 2009, 14:19:55 pm
Excellent choice!
As an added bonus, 42's sound really good
~DR.
Re: 42 DCNFs
September 01, 2009, 16:45:10 pm »
Pain in the neck carburetors which were never designed to run on a VW! They were designed to run on a Ferrari engine, with the throttle shafts across the car. Turning them by 90 degrees to work on a VW engine causes them to flood when turning sharp corners. On a Ferrari they only temporarily flooded when braking hard. You need to make sure they have extended emulsion tubes which Berg sell – or used to – to make them work properly. Used to fit them a lot back in the 1970s and breathed a huge sigh of relied when Weber brought out the IDF and Dell'Orto the DRLA.
Re: 42 DCNFs
September 01, 2009, 16:50:57 pm »
Keith may not like them, but I have over 100k trouble free miles on them. They aren't as purdy as IDAs, but Oh well...
Re: 42 DCNFs
September 01, 2009, 16:53:42 pm »
I built a Bus motor for a friend in 1991-92 that ran 42's. Motor was fairly mild, small Scat cam, stock valved dual ports, low CR, 90.5x69. I recall it idled very smoothly, but like KS said, get the bus in a corner, and it was like somebody turned the lights out. He regretted using those carbs, but they came with the bus, so he compromised.
In a dune buggy, IDF's would be a snap to keep happy. You could practically clean the idle jets while driving.
My vote would be for 44IDFs
Re: 42 DCNFs
September 01, 2009, 17:02:41 pm »
Quote from: The Other One on September 01, 2009, 16:53:42 pm
You don't think 44s would be too big? I would think 36s or 40s for a 1776. Mostly I want something that I don't have to fiddle with after getting them dialed in. Trying to make this something even the wife could drive.
Re: 42 DCNFs
September 01, 2009, 17:14:11 pm »
Quote from: louisb on September 01, 2009, 17:02:41 pm
40mm Webers are good for 1700 and under, in my opinion. One of the best and smoothest motor combos I know of for mild street is 1776, Engle 120, ported stock valve or 40 x 35 heads, and 44IDFs
you have Excel?
Re: 42 DCNFs
September 01, 2009, 17:16:08 pm »
Yep, I sure do. That sounds like a nice driving motor.
Re: 42 DCNFs
September 01, 2009, 17:16:29 pm »
Quote from: louisb on September 01, 2009, 17:16:08 pm
pm me your email
Dave Rosique
nobodyouno
Re: 42 DCNFs
September 01, 2009, 17:21:48 pm »
Quote from: The Other One on September 01, 2009, 17:14:11 pm
you have Excel?
Hmmmmm... didn't know we had a choice here... I thought you had the 42's and wondered if they would work... I should slow down and read all the text
The combo "The Other One" posted is superb! I've run basically that same combo in Baja's, Bugs & Buses... Go for it!
~DR.
Re: 42 DCNFs
September 01, 2009, 17:37:00 pm »
I loved the 42 Specials on my mild 1776 (K65, ported stock valve heads, 8:1)... ran smooth as butter and still returned 25mpg in my heavy Fastback at 80mph. I later put the carbs on an original stock 1600 dual port and they still worked fantastic.
Re: 42 DCNFs
September 01, 2009, 17:43:09 pm »
No, this is still a paper motor sort of. I more or less have the short block and a set of stock heads I plan to self port via the Fischer book. I am still debating the P&Cs, carb & cam size. My requirements are that it be cheap, reliable and powerful enough to push a stocked geared 26-27" tall tired buggy to highway speeds for hours on end. (Up and down steep grades too) I am trying to think of a carb that would work with that size motor and my choices were the DCNFs, Kads or even a center mount of some sort. I am following the KISS principle with this one. That way if I break down in Resume Speed, North Dakota with it I can fix it easy.
Re: 42 DCNFs
September 01, 2009, 17:47:10 pm »
Quote from: Dave Rosique on September 01, 2009, 17:21:48 pm
you have Excel?
~DR.
I remember a very nice white 66 Ghia this mousey little girl owned, a good customer we had @ BH, she wanted a good "freeway motor" for her KG, so we built the motor I listed above with stock valved heads (she wanted heaters) and I swear, that motor was one of the smoothest, yet potent 1776's I can remember. Based on her gender, I was a little nervous of the nature the 120 and 44's, but when I test drove it, it pulled so smooth off idle and just kept pulling, with a wonderful high pitched howl from the carbs as the revs climbed. To top it off, the girl was really pleased with the engine and said it was night and day compared to the stock 34pict dual port 1600.
For a mild daily driver, it's a hard combo to beat. Change to K8 and bigger valves and you've upgraded to very hot street. That's the nice thing about 44IDFs, they run well on a wide array of combinations.
Re: 42 DCNFs
September 01, 2009, 17:49:09 pm »
That sounds pretty good.
Re: 42 DCNFs
September 01, 2009, 18:03:05 pm »
Zenith
Re: 42 DCNFs
September 01, 2009, 18:53:26 pm »
Quote from: Zach Gomulka on September 01, 2009, 18:03:05 pm
Zenith
Dual Bugsprays!
Re: 42 DCNFs
September 01, 2009, 18:56:56 pm »
Quote from: Fastbrit on September 01, 2009, 18:53:26 pm
Zenith
Dual Bugsprays!
I actually have a set of dual 350s.
Dave Rosique
nobodyouno
Re: 42 DCNFs
September 01, 2009, 19:19:15 pm »
Zenith
I've always had a weak spot for the Zenith.
~DR.
John Rayburn
Re: 42 DCNFs
September 01, 2009, 19:41:14 pm »
Dave, you are King Zenith!
I also park at Nick's.
Re: 42 DCNFs
September 01, 2009, 19:51:00 pm »
Sheep says if he ever has a baby girl her name will be Zenith
Re: 42 DCNFs
September 01, 2009, 20:23:08 pm »
Quote from: The Other One on September 01, 2009, 19:51:00 pm
Not sure what would scare me worse, the name or sheep having offspring.
John Rayburn
Re: 42 DCNFs
September 01, 2009, 20:34:41 pm »
Awesome! When she gets older she'll have duel Zeniths!
Re: 42 DCNFs
September 01, 2009, 20:40:05 pm »
I suggested the name "dry sump" but Zenith won out.
Re: 42 DCNFs
September 01, 2009, 20:40:52 pm »
Quote from: The Other One on September 01, 2009, 20:40:05 pm
Guess that is better the Stroker.
Re: 42 DCNFs
September 01, 2009, 20:43:03 pm »
Quote from: louisb on September 01, 2009, 20:40:52 pm
...or
Racer Brown
, which is Sheep's other nickname from his frequency of bathroom visits at BH
Dave Rosique
nobodyouno
Re: 42 DCNFs
September 01, 2009, 20:46:06 pm »
Little boy could be Rod... only if he's cranky while trying to get his bearings...
nevermind
Re: 42 DCNFs
September 02, 2009, 00:36:52 am »
Forgive my crusty and old memory... but I remember a few of my friends that liked the 42s and also liked to take turns fast. So they simply added the extra length breather tubes and the problem was solved. Aren't those still available? I think the Berg family offered 'em at one point. But this was almost three decades ago.
