October 13, 2026, 05:01:01 am
| | |-+  about time for some new head designs isn't it?
Author Topic: about time for some new head designs isn't it?  (Read 11350 times)
« on: September 02, 2009, 21:51:39 pm »
guys, how about a die cast head with VW fins, and valve cover rail, but with S/F or "spread port" intake port AND angled exhaust ports. Get away from the stock Volkswagen intake flange design and get some port area and a nice straight shot into from butterflies.
Longer valves?
« Reply #1 on: September 02, 2009, 22:22:29 pm »
I like it. A type 4 intake flange would work good for this, don't you think? Then you already have intake manifolds available.
« Reply #2 on: September 02, 2009, 22:49:38 pm »
I like it.  Cool
stealth67vw
« Reply #3 on: September 03, 2009, 00:25:17 am »
How bout the MS 230 heads? They don't have angle exhaust ports but everything else your asking for and they use available Super Flo manifolds. They claim 15% more fin area than an 044 and 50% more than S/F, A/F or C/E heads.
http://www.jpmotorsport.se/s/ms230.htm
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
« Reply #4 on: September 03, 2009, 08:47:27 am »
I hear those heads cost as much as I paid for my 67 five years ago.  Shocked
Nifty ideas tough, carry on.  Smiley
« Reply #5 on: September 03, 2009, 11:46:01 am »
Imagine how long it takes to machine those fins...  Shocked
You get what you pay for...
JS
« Reply #6 on: September 03, 2009, 12:19:36 pm »
How much does it cost to get the same HP number out of a set of CB wedgeports? As much as a '67, I'd guess...  Wink
Last time I checked they were around $3200 for the pair.
Signature.
« Reply #7 on: September 03, 2009, 12:24:36 pm »
i'm not expressing any critique on the heads themselves. as far as i'm concerned these heads are astonishing, but so is the price. i got the impression jim was looking for something slightly more accessible, say, in the range of ultra wedgeports? but i might be wrong. Wink
JS
« Reply #8 on: September 03, 2009, 13:00:12 pm »
 Smiley
Signature.
« Reply #9 on: September 03, 2009, 14:31:10 pm »
With S/F or "spread port" intake port AND angled exhaust ports.
If they in addition to be angled out 45 degrees were angled 45 degrees down, you could have shorter exhaust... a plus for higher rev applications...
Tomas/DBR
« Reply #10 on: September 04, 2009, 13:06:33 pm »
Anyone who know more about these DRD heads?
http://www.thesamba.com/vw/classifieds/detail.php?id=828811
wph
« Reply #11 on: September 04, 2009, 21:24:12 pm »
Old skool... by Jeff Denham. Like a lot...
« Reply #12 on: September 04, 2009, 22:56:03 pm »
Dang thosa are FINE!
Jeff is the MAN.
« Reply #13 on: September 05, 2009, 22:30:41 pm »
here you go:
Pat Downs said:
We will be releasing our new cylinder head in a few weeks. The head is our Strip Dominator. We went in with Autocraft and reingineered the 910, adding many improvements. The head will come CNC ported with 50x38mm 11/32 titanium valves, titanium retainers, titanium locks, barillium seats. I will post flow numbers on our website next week. I can say that the head flows over 300cfm@25" in a 94mm bore.The head flows extremely well from .100 lift up to .800 I can post some pics if your interested. I am really excited about this new head. A new manifold is being done that will require no welding and will also come CNC ported. I expect pricing for the completed heads with CNC porting, CNC match ported manifolds and a new sheetmetal type valve cover to be in the low $3,000.00 range.
Pat Downs
The first run of heads are going to be 94mm bore with 50 x 38 valves. Our product line is really based around the stock stud pattern so we wanted to do the first run as 94mm only. You can run up to a 96.9mm bore with the stock stud pattern. One very nice change we made to the casting is a solid rocker arm pedestle that runs accross the entire length of the rocker box. This strengthened the head and allows a broad range of rocker arrangements. I am currently working on a rocker arrangement that uses 2 shafts, each having 3 mounting points. Rocker ratio will be 1.6, 1.7 and maybe 1.8 not sure on the 1.8's yet. I am also working on a valve spring that will set up like a flat tappet spring using 1.800 installed height but will allow lifts to .800 with a roller cam. This way, we do not have to run two different length valves if a roller cam will be used with the head. I will get some pics posted later today. Here is the flow chart on the head. I flowed the head three ways, 94mm bore with a full chamber, 94mm bore with a .200 deep flycut and 96mm bore with a .200 deep flycut. Reason being is that most people who buy this head will flycut it for compression. I also wanted the 96mm bore customers to see what the head flows with a .200 deep 96mm bore.
100-66
200-131
300-187
400-233
500-267
600-290
700-299
800-308
94mm chamber with a full chamber, no flycut
100-62
200-118
300-165
400-212
500-248
600-275
700-290
800-301
96mm chamber with a .200 deep flycut
100-71
200-138
300-191
400-238
500-272
600-295
700-305
800-321
