November 03, 2026, 02:45:36 am
| | |-+  high torque starter?
Author Topic: high torque starter?  (Read 13949 times)
autobarnhauler
« on: January 27, 2007, 20:26:01 pm »
hi guys, ive just fitted my new 22.76cc engine and trying to start it 4 the first time,
and was wondering if i need to fit a high torque starter, as it turns over slowly on a new stock moter.
conpression is 10:1 with c45 cam and msd ingnition.
any ideas? thanks  Wink
GWB, founder member
.... there and back again, a rocket buses tail....
Roman
« Reply #1 on: January 27, 2007, 21:11:18 pm »
Check the trans ground strap etc, it shouldn't be any problem.
My old 2332 had 11.5:1 and started instantly with a stock starter.
At the moment have a 1967 6V starter that runs on 12V, that's a solution that beats any Hi torque starter.
« Reply #2 on: January 27, 2007, 21:17:50 pm »
Use the Bosch SR15N. It is stock style but 3lbs lighter.
« Reply #3 on: January 27, 2007, 21:38:47 pm »
What about if you have a 6V car and a hi-po motor? Will it work using the late model 6V starter and a 200mm flywheel?
Will it have enough torque to turn a 10,5 compression 2276?
autobarnhauler
« Reply #4 on: January 27, 2007, 21:54:39 pm »
cool  Cool Cool thinking of trying a new battery to, thanks Smiley Smiley
GWB, founder member
benssp
www.callookvw.com
« Reply #5 on: February 22, 2007, 15:58:21 pm »
Are you starting the car with the clutch pedal pressed down?
It doe's help Grin
www.vwheritage.com  My Job
YMCA
alex d
« Reply #6 on: February 22, 2007, 16:05:47 pm »
check the bushing in the 'box too
Steve D.
« Reply #7 on: February 25, 2007, 19:42:05 pm »
That motor shouldn't have a problem with a good stock starter and a good battery if all the grounds and such are up to snuff- no fancy $$$ stuff needed here.  Gear reduction starters are lame- they don't weigh anything less than the black Bosch SR15N and they make your car sound like a To#¤ta- the only weight reduction you will notice will be in your wallet.
Über Alles
10.77 avg. on pump fuel.
238I
Hong Kong Syndicate
I'm not Db Cooper!
« Reply #8 on: February 26, 2007, 02:58:11 am »
A 6 volts starter on a 6 volts 67'... it's enough to star a 1776 cm3 ( a few years ago...almost 15  Undecided Y'a I'm old) whit this combo
 69x 90,5/ Engle 110/ 1,25:1/ 200 mm flywheel 109 teeth ( -500 gr) / 2x solex 40PII-4 + Knetch/ 010… whit a CR like 9:1
 Absolutely any kind of problem beside the bad general feed back on Solex’s 40 and 6 volts performance cars but for a 2276?
 I think for a so big engine, the torque of the 6v starter have a lot of work to do =>
 The inertia of the parts (the forged crank whit this counterweights + the rods + Forged pistons ), more the CR, …. I think its to limit
 Sorry for my so poor English
I know, I know my English is very poor Tongue
autobarnhauler
« Reply #9 on: February 27, 2007, 18:26:15 pm »
hi guys, thanks 4 the help, the problem was that my starter was worn and abit "tired"
fitted a new stock 12v starter and she spun over fine, and now runs well, happy days Smiley thanks
GWB, founder member
