November 02, 2026, 22:18:55 pm
| | |-+  modified j tube heat exchangers.
Pages: [1] 2 Print
Author Topic: modified j tube heat exchangers.  (Read 22895 times)
67worshipper
« on: November 15, 2009, 11:49:02 am »
i know people have modified j tubes into heat exchangers.can anyone follow this up with pictures please.they obviously wont give as much heat as proper heat exchangers but will take the chill off an interior for extra usage in the colder months.thanks in advance Grin
vw hot rod heaven
« Reply #1 on: November 15, 2009, 11:58:20 am »
nothing special , but here's the one on the berglar
« Reply #2 on: November 15, 2009, 12:01:25 pm »
 Wink
67worshipper
« Reply #3 on: November 15, 2009, 12:39:19 pm »
cheers fabs.im presuming that they slice round the original heat exchanger and fit it to the merged j tube.the inerds of the heat exchanger wont fit though?
vw hot rod heaven
Rocket Ron
It's old school for a reason
« Reply #4 on: November 15, 2009, 12:59:43 pm »
I'm sure someone does big bore heat exchangers with flange outlets but i cant remember were I saw them Embarrassed sorry
13.12 @ 101.84
Grooving out on life
67worshipper
« Reply #5 on: November 15, 2009, 17:21:08 pm »
ssp do the flanged bigbore exchangers ron but only in an 1inch and 3/8s which i dont think is big enough for a 2276 motor size Huh
vw hot rod heaven
nlvtinman
« Reply #6 on: November 15, 2009, 17:23:58 pm »
Not that it would work as well as the system Fabs showed on the Bergler, but an adapted non fresh air 40hp heater system,  is another option. This was the type of heater system Keith Goss built for his '62 chop top.
Any photos of that Fabs?
« Reply #7 on: November 15, 2009, 18:04:08 pm »
 Wink
« Reply #8 on: November 15, 2009, 19:46:39 pm »
Unless you see a challenge in making them yourself, there is no need. CSP makes them in 1½, 1 5/8" , 1 3/4" and even 1 7/8".
67worshipper
« Reply #9 on: November 15, 2009, 20:07:44 pm »
thankyou torben.i didnt realize csp made all those Roll Eyes
vw hot rod heaven
« Reply #10 on: November 15, 2009, 20:08:35 pm »
http://www.csp-shop.de/cgi-bin/cshop2/front/shop_main.cgi?func=anzeige&wkid=187342392567&rub1=Exhaust%20%2F%20Heating&rub2=Exhaust%20System%2DModified%2CJ%2DTubes%20%2F%20Heat%20Exchangers
http://www.csp-shop.de/cgi-bin/cshop2/front/shop_main.cgi?func=det&wkid=187342392567&rub1=Exhaust%20%2F%20Heating&rub2=Exhaust%20System%2DModified%2CJ%2DTubes%20%2F%20Heat%20Exchangers&artnr=14002b&pn=0&sort=0&all=
67worshipper
« Reply #11 on: November 15, 2009, 20:14:09 pm »
fabs your excelling yourself Grin thanks again.anybody using these and what sort of heat do they give?
vw hot rod heaven
youngnstudly
« Reply #12 on: November 16, 2009, 01:12:21 am »
Real men build heater boxes themselves! But if you must, go ahead and buy them.... Wink
« Reply #13 on: November 16, 2009, 01:18:48 am »
Had Tiger at A-1 Muffler make my 1 5/8" flanged heater boxes and work great!
youngnstudly
« Reply #14 on: November 16, 2009, 01:29:24 am »
Yeah, but that costs $$$$! Shocked Tiger does great work from what I've seen though. Did you order yours with the coating? My homemade ones didn't turn out totally perfect, but they should get the job done...I hope! Grin
67worshipper
« Reply #15 on: November 16, 2009, 14:30:39 pm »
what size motors are fitted to your cars fred?
vw hot rod heaven
Gunter
« Reply #16 on: November 16, 2009, 16:12:10 pm »
Hi thanks all for the comments
they give heat like original
BUT off course if you have the big diametre of 48mms
inside fins is less than original since outside of the heat exchanger remains same size
you can not change that
but our customers (mostly UK) are very satisfied with the heat AND combined with a big engine
Gunter
« Reply #17 on: November 16, 2009, 16:22:42 pm »
perhaps it's a dumb question but don't these heater boxes
require certain alterations to the merged header, and a fresh air shroud?
edit, ok this type works with our headers i suppose, but still requires a "stock" shroud:
i would be more interested in the 40hp style like the chop top.
« Reply #18 on: November 16, 2009, 17:18:50 pm »
yes here's the berglar engine and had the stock shroud
alfie the monster
« Reply #19 on: November 17, 2009, 11:49:54 am »
Real men don't feel the cold  Wink
JG54 Grunherz
« Reply #20 on: November 17, 2009, 16:10:19 pm »
This is a system built for Billboa by Doug Berg.
Beautiful work, fits great and very detailed. I can't imagine it took less than several days to complete this ...
Full 1 3/4" merged with dual 2 1/2" muffs! Shocked Cool Wink Grin
Brandon Sinclair
« Reply #21 on: November 17, 2009, 17:41:40 pm »
That looks like a nice system-the down pipes on the heater boxes look like a nice addition and well at the extra material to support the dual mufflers.  I bet it works pretty well!
youngnstudly
« Reply #22 on: November 18, 2009, 08:00:07 am »
I wish I was a real man!  Grin
Doktor
« Reply #23 on: November 18, 2009, 09:02:46 am »
I have an idea that could fit in this topic very nicely...
How about making a bigger j-tube from stainless stell, and then fit it in the body of original heat exchanger ?
Would that work ?
dr.aircooled
JSL
« Reply #24 on: November 18, 2009, 10:26:01 am »
I was impressed with these....
Ribs were used through out for heat transfer
Cheers,
J
benssp
www.callookvw.com
« Reply #25 on: November 18, 2009, 12:00:35 pm »
do what i did, made a choice between a warm coat and heat exchangers...............the coat won Grin
www.vwheritage.com  My Job
YMCA
« Reply #26 on: November 18, 2009, 14:51:21 pm »
Some really cool ideas and images on this thread. Good to see people fabricating to enjoy heat and high performance for their VWs.
The Ideaman
« Reply #27 on: November 18, 2009, 16:33:36 pm »
Your car has had the tubes cut off the heater channels.  Just put a hot potato in your jacket pocket.
It is the soldier,
Who salutes the flag,
Who serves beneath the flag,
Brandon Sinclair
« Reply #28 on: November 18, 2009, 18:09:02 pm »
There are also heater muffs available for aircrafts that just clamp over your existing j tubes
http://www.aircraftspruce.com/catalog/eppages/homebuildersheatmuffs.php
63 ripper
« Reply #29 on: November 18, 2009, 18:14:33 pm »
 Cheesy Grin Cheesy
JG54
Pages: [1] 2 Print
