November 02, 2026, 19:55:34 pm
| | |-+  project budget 66 'looker! NOW PAINTED!
Pages: 1 [2] Print
Author Topic: project budget 66 'looker! NOW PAINTED!  (Read 41693 times)
« Reply #30 on: May 20, 2010, 16:55:45 pm »
I'm going for 88's, but I'm an idiot Smiley
beetletom
« Reply #31 on: May 20, 2010, 19:17:04 pm »
thanks, i decided to go for some 1641 barrels and pistons, as a mate had a set cheap!
going to decoke them and re ring them too.
GreenTom
« Reply #32 on: May 21, 2010, 00:48:52 am »
hehe Smiley
You're not an idiot Smiley you're "The Hardkore" - Polish roots mate Smiley good luck Smiley
Aircooled Performance Gear
Quick Stick Performance
www.QuickStickVW.com
beetletom
« Reply #33 on: June 18, 2010, 21:04:51 pm »
bought a 1600 longblock today and a pair of kadrons
fitted my butchered rx  Cheesy
sounds exactly like a stinger! probably because the only bit of baffling is in the tail pipes, and have had a 3 bolt flange welded to it
razzed it up the main road on my way home, then noticed a cop car approaching in my rear view mirror, as i got to the roundabout, so kept it in 4th, as he followed me all the way home  Embarrassed
he must of heard me right up the road!  Shocked Tongue
the 65 is sold, and is going to bournemouth tomorrow.
« Last Edit: June 18, 2010, 21:09:10 pm by beetletom » Logged
beetletom
« Reply #34 on: July 28, 2010, 13:06:18 pm »
work has started on the 66!
having hookeys rear bumper mounts welded in
original rear body mounts repaired
original wings repaired
and a small repair to the bulkhead just above the master cylinder where it has peppered through.
and a repaint!  Grin
got a good 1500 gearbox going in! (and then i can sort the rear height properly!)
a nice stainless turbo muffler and header
and had my brm's blasted
beetletom
« Reply #35 on: August 18, 2010, 17:21:45 pm »
don't worry, the cookie cutters are only on there to roll it about on!
the worst bits are the rear body mounts and bumper mounts
got a black 66 only interior for it too!
just need to find some door cards.
beetletom
« Reply #36 on: September 16, 2010, 19:40:06 pm »
the dings and dents have been sorted
not the only person to think that? :lol:
a post gutter has been pulled out and straightened, 1/4 panel too, as it has had a bit of a knock
rear bumper mount welded in and rear body mount was all welded in by the time i left, hookeys ones didnt fit mine sadly, so had to use the usual repro bumper mounts
i still have the original 1966 body mounts if anyone wants to make a good copy of them? the passenger side one looks exactly the same as the usual repro style you can buy, but the drivers looks like a late one, for the z bar, with the pressing, but not cut out!
front end pulled out and straightened, don't worry, the filler looks worse than it is, just a light skim Cheesy
and look at the size of the amp under the bonnet, then you can understand how big the stereo was that was in it :lol:
beetletom
« Reply #37 on: September 16, 2010, 19:40:31 pm »
the inner wing is finished off, nice and smooth! flush panel joins
just the heater channel end plate to do...
can't even tell it has ever been welded (well, the repairs are invisible), and the spotwelds have been remade too
beetletom
« Reply #38 on: September 16, 2010, 19:43:36 pm »
more welding has been done, a small repair on the running board mounting strip, below the rear 1/4, heater channel is nice and rot free inside too!
and the heater channel end plate had just been layed over the top of the old one!!!
and whats better is that its only had 2 holes about a cm long near the outside edge, so those have been welded up!
no idea why someone badly tacked on one over the top!!
all the welding is now done , prepped for primer, which will be done later this week
inner wings, and front bulkhead area now stonechipped and flatted back
i passed my test on tuesday 1st try!, but now got no car to drive!  Cheesy
JSL
« Reply #39 on: September 17, 2010, 12:56:59 pm »
CONGRATS ON PASSING YOUR TEST TOM!!!!
WELL DONE!!! Wink
J
beetletom
« Reply #40 on: September 17, 2010, 13:00:44 pm »
thanks!!!
still in disbelief!
just want to go for a drive  Cheesy
jamiep_jamiep
« Reply #41 on: September 18, 2010, 17:56:39 pm »
Good news about the test Tom, and looks like you're getting on well with the bug.
 Smiley
beetletom
« Reply #42 on: September 28, 2010, 12:22:15 pm »
thanks!
all welding now finished on the body, car is now prepped and in primer for a final prep and then paint!
painted my tinware on the 1300 motor the other day, will change it to 1641 in the future, but just need to get it on the road for now!
and fitted my trekker shroud and an alternator, but i need an alternator stand!
« Last Edit: September 28, 2010, 12:34:01 pm by beetletom » Logged
beetletom
« Reply #43 on: October 01, 2010, 19:57:09 pm »
its now painted!!!  Grin
71CALRIPPER
« Reply #44 on: October 02, 2010, 09:29:41 am »
well done tom
beetletom
« Reply #45 on: October 03, 2010, 12:53:24 pm »
thanks rob!
needed to go down today so my my windows could be fitted, fitted pop outs before i left,the car looks stunning! Cheesy nice deep ruby red, the pics makes it looks worse! so much better in person!
going down to heritage on thursday to get all the trim bits and bobs
thats the finish straight out of the gun too! Cheesy
maccattack
« Reply #46 on: October 03, 2010, 20:10:03 pm »
Looking good! Grin
roland
lates are the new splits...
« Reply #47 on: October 04, 2010, 10:33:05 am »
well done tom! so, it's going to be cal-look or resto-cal? Smiley
JSL
« Reply #48 on: October 04, 2010, 12:23:07 pm »
Well I dont see any trim holes, so it should fit in well with this forum ;-)
Nice work Tom!! ;-)
J
« Reply #49 on: October 04, 2010, 14:40:34 pm »
there's trim hole  Shocked Shocked
beetletom
« Reply #50 on: October 04, 2010, 20:42:39 pm »
yes, theres trim holes i'm afraid!  Grin
back end will be raised back to stock, and see how i feel from there!!
Dereck
« Reply #51 on: October 04, 2010, 21:25:09 pm »
Looking good, wish my 66 was moving a quickly...
Follow me on Twitter: http://www.twitter.com/vondirk
Follow the progress of my Project '66: http://wackyracers.posterous.com/
beetletom
« Reply #52 on: October 06, 2010, 13:34:16 pm »
thanks!, just had this sent to me!
beetletom
« Reply #53 on: October 26, 2010, 21:04:45 pm »
now pretty much finished, just rear brake shoes to fit , then it can go for an mot
have sorted the stance, now back up to stock height at the rear, and has a proper rake!  Cool but i will probably change my mind soon and lower it again  Embarrassed  Cheesy
threw on the t bars for now, till i get my bumpers
picking up a pair of banded steels at slough for the rear, just temporary wheels for now
have worked on it solidly for the last few weeks, changed rear hub oil seals, gearbox mounts, and stuff like that
« Last Edit: October 26, 2010, 21:07:18 pm by beetletom » Logged
beetletom
« Reply #54 on: November 02, 2010, 19:30:46 pm »
was planning on taking it for an mot today, but the handbrake cable snapped last night, have been trying to find one all day today, managed to order one in
so will be finally taking it for its mot tomorrow!!!
i defiantly think a set of sprints will suit it!  Cool so will get a set next year
put the trim rings on, as my steels are pretty ratty looking!!
can't wait to fit the 1500 box and get the rest of the bits for my 1641!
oh and the bumper irons and wipers will be painted the correct silver soon Wink
« Last Edit: November 02, 2010, 19:34:53 pm by beetletom » Logged
Pages: 1 [2] Print
