June 09, 2026, 18:26:31 pm
mvptkfjb
First gear in european AM code IRS gearboxes
Topic: First gear in european AM code IRS gearboxes (Read 49207 times)
Re: First gear in european AM code IRS gearboxes
Reply #30 on:
January 27, 2010, 17:02:29 pm »
The AH definitely won't have a 9 tooth mainshaft.
pupjoint
Reply #31 on:
January 27, 2010, 17:29:07 pm »
ok thanks. AT it is then.
pupjoint
Reply #32 on:
February 16, 2010, 10:25:58 am »
hey guys, found 2 more gearboxes AT and AM. both SSC.
i took the AT home; AT 02 12 4, i think it is the later style SSC. pics to follow.
the other is AM 5362701
Bruce, what is yr take on this AM box? no pic on the AM, forgot to take.
Last Edit: February 16, 2010, 10:32:54 am by pupjoint
Rasser
Reply #33 on:
February 16, 2010, 12:53:34 pm »
Afaik thats the strongest stock case. Look at the top castings! Nice find!
1955 type1
1966 type2 13w deluxe
Reply #34 on:
February 16, 2010, 17:28:11 pm »
That case came out in the fall of 74. Yours is Dec 2, 74.
Have a look at the bottom too!
Double ring side cover is stock on it. Good for up to 250hp.
pupjoint
Reply #35 on:
February 16, 2010, 22:59:00 pm »
thanks!
think u guys missed it in my last post.
the guy who sold me that box also has a SSC AM code box.
code is
AM 5362701
this SSC the top is not like in the pic, but the normal top....cant find a pic. think it is 69 to 72 earlier IRS....but SSC?
pupjoint
Reply #36 on:
February 16, 2010, 23:16:35 pm »
there u go, i copied this pic from Samba, tranny for dummies like me
the AM box is just like the box on the RIGHT.
pupjoint
Reply #37 on:
February 18, 2010, 14:33:46 pm »
Quote from: 67-indeed/DVK on January 21, 2010, 23:04:01 pm
just wondering but what's an AM box like on the motorway?
a 4.37 r&p with a 0.93 4th is probably a bit noisy, or not?
just reread this thread from first post. should have done it earlier. so the AM SSC will have a 9 toothfirst gear, 4.37RP and 0.93 4th?
Reply #38 on:
March 25, 2010, 13:36:56 pm »
Ok, here's a question - I've been offered a DC box out of a type 3. I don't know if it's an early or a late one, but it's a single side cover case. It's cheap (less than a meal out with the better half!) - worth a punt if only for the 4.12 R&P?
JamieL
Reply #39 on:
March 25, 2010, 22:22:32 pm »
Quote from: Neil Davies on March 25, 2010, 13:36:56 pm
SSC case is always worth something - I went through 3 in the Ghia...
Reply #40 on:
March 27, 2010, 07:31:51 am »
A DC in a SSC case will have a 9 tooth mainshaft and a 4.13 R&P. You will also get a fairly rare .89 top gear for a 002 mainshaft.
dangerous
Reply #41 on:
March 27, 2010, 23:07:33 pm »
Some times the SSC trans will still use the 10 tooth mainshaft,(well at least they do in Australia),
but most are the 9 tooth.
The third and fourth are usually fine tooth gears whether they are 113 or 002,
4th being a 0.883 ratio in the later DC trans.
There seems to be a pretty large overlap of the use of SSC cases and the change from 113 to 002 gears and mainshafts,
but with both AT and DC codes there are even DSC trans that had the 002 parts.
The ones I have seen thus equiped used O cut ring and pinions,
but the fnal drive ratios with those codes have always been as per all, of each,(if that makes sense).
This means for example, all the ATs had 3.875 R&P and all DC used 4.125,
and if fine tooth 3rd/4th, then 0.931 and 0.883 respectively.
Reply #42 on:
March 28, 2010, 05:34:34 am »
Dave, did VW of Aus build gearboxes, or did they just install a German made imported one?
Rasser
Reply #43 on:
March 28, 2010, 09:36:15 am »
Quote from: dangerous on March 27, 2010, 23:07:33 pm
I have seen the exact same thing (Denmark). I have a AT and a DC with SSC and 10 tooth, and fine tooth 0,93 and 0,89 respectively. Actually the AT came from a bug imported from germany!
1955 type1
dangerous
Reply #44 on:
March 28, 2010, 20:23:10 pm »
Quote from: Bruce on March 28, 2010, 05:34:34 am
They did build boxes but only until about 1968 as far as I know.
Later cars were less Aussie content but gearboxes may still have been Aus, I really dont know.
I have an AH coded case here that is SSC too, but cant recall if it had the 002 mainshaft.
prob not, since I dont recall it having the sme style of date numbers as later trans'.
pupjoint
Reply #45 on:
May 30, 2011, 18:31:51 pm »
dint wana start a new topic, but anybody has any idea if this AH box come with the stronger first?
AH 4347117, DSC, he hasnt had the time to check if it has the bigger 20mm clutch shaft.
a freind found it back home, it was removed from a totaled 1302 which has a AD code 1600 motor with 10mm studs.
thanks
dangerous
Reply #46 on:
May 30, 2011, 20:48:06 pm »
I doubt it will be 9 tooth mainshaft with that code from the factory.
Look under the intermediate housing for the bolt that locates the front pinion roller bearing.
This will indicate that it is likely the earlier type bearing, which usually also had the earlier 10 tooth main shaft.
pupjoint
Reply #47 on:
June 08, 2011, 14:34:26 pm »
got some pics, it does have the 3.80 first from the nut under the carrier as mentioned
this is the engine it came with
