October 13, 2026, 08:15:21 am
| | |-+  Pictures? How to locate oil cooler
Author Topic: Pictures? How to locate oil cooler  (Read 20266 times)
red baron
« on: February 06, 2010, 13:25:06 pm »
Hey guys,
I like to mount my oil cooler right next to the transmission. Does anybody have some pictures how and where it is mounted. Looks like there is very little space.
cheers...max
ugly duckling
« Reply #1 on: February 06, 2010, 16:42:57 pm »
hello baron. here,s a shot of my buddys ride. there is two coolers the other one is direcly below the gearbox.  UD .
« Reply #2 on: February 06, 2010, 17:58:12 pm »
Hello.
Nice out of the way location, but also very inefficient IMHO.
I use to install an extra stock oilcooler in a homemade mount behind the torsion bar housing , with an air foil to lead air up through it. Rather efficient and still out of the way. Along with the stock oil cooler this setup is able to control oil temperature at a sustained load of 60 - 65 hp even in 35 C. heat. ( with 040 or 043 heads)
I will see if i can find a pic in my files (I know i have one somewhere.)
ugly duckling
« Reply #3 on: February 06, 2010, 23:16:31 pm »
as i EXPLAND that there is another cooler direlctly below the gear box ALSO( NOT SHOWN )with lots of AIR FLOWING ACROSS THE COOLER also it has a fan on it as well the temps have never gone over 190 ON 100 DEG DAY  this is a 3.0 type 1 making 250fw and 250tq. so as far as being INEFFICENT well you have your opinuen and i have mine. now if that was the only cooler that i was running then i would probebly agree with you but sence it is not i will dissagree. have a nice day . Wink UD.
Dan Mazur
« Reply #4 on: February 07, 2010, 02:35:41 am »
How about some "Spell Check"??
Don't worry.  It's mutual.
« Reply #5 on: February 07, 2010, 03:27:41 am »
I understood it Jeff. Point taken.
I didnt catch the part with 1 under the transmission the first time around.
ugly duckling
« Reply #6 on: February 07, 2010, 06:02:45 am »
no problem torben. if you have some shots of your setup i would enjoy seeing them and red baron as well .  and as far as the spell check are you the grammer police larry. UD .
« Reply #7 on: February 07, 2010, 17:39:08 pm »
My set up.
« Last Edit: February 07, 2010, 17:40:47 pm by FDK/Hurry » Logged
« Reply #8 on: February 07, 2010, 18:44:06 pm »
My set up.
Sorry dude but I'm gonna stir things up AGAIN  Wink That scares the Hell outta me  Shocked They are sooooo low  Undecided
71CALRIPPER
« Reply #9 on: February 08, 2010, 12:29:51 pm »
My set up.
One UK speed bump or stone and think warm oil all over the road...
« Reply #10 on: February 08, 2010, 15:48:27 pm »
My set up.
Or just one of those pot holes that have apeared resently
fahrvergnugen
« Reply #11 on: February 08, 2010, 20:51:25 pm »
Here's my setup. It's a bit extreme but why not.
The chassis is up side down, but you'll get the idea Wink
« Reply #12 on: February 08, 2010, 21:03:01 pm »
Hmmmmm VERY interesting - I like that! you could even fit 2 (two) coolers in there
71CALRIPPER
« Reply #13 on: February 10, 2010, 19:48:26 pm »
My set up.
Yeah after the ice and snow Smiley
« Reply #14 on: February 13, 2010, 06:15:08 am »
Anybody using a Seatrab Oil Cooler dual or single fan? And pics please.  Grin
Felix/DFL
« Reply #15 on: February 17, 2010, 22:37:22 pm »
very interesting that so many are using the ineffective coolers without webbing betweeen the plates and the fat isolating paint...
The webbing gives you surface and the surface gives you heat output and that`s  makes a cooler effective.
Without the fan at those canadian Empi/b&m coolers they would be effective as some bended cooper tubes.
I had made me a simmilar setup as the swiss made Caegro-cooler (I yust added some more louvers):
I mounts at the torsion bar and grabs air from under the car. Sorry haven`t got a pic of mine at the moment.
This is a interesting setup with an mocal cooler and spal fan from Tom Ratzeks bug which uses the existing room very good:
« Last Edit: February 17, 2010, 22:39:18 pm by Felix/DFL » Logged
Brandon Sinclair
« Reply #16 on: February 18, 2010, 19:04:40 pm »
If using an electric fan with a remote cooler is it better to mount the fan on the front or backside of the cooler-push or pull the air through?
red baron
« Reply #17 on: February 19, 2010, 08:49:57 am »
mostly it is said that a pulling fan should be better - but i think ith the right cooler you won't notice any difference cause the temp is always okay.
cheerio
71CALRIPPER
« Reply #18 on: February 19, 2010, 12:08:26 pm »
Thats 100% the way i want my 67, tried and tested.
Rob
Peter Roberts
« Reply #19 on: February 22, 2010, 16:16:41 pm »
« Reply #20 on: February 23, 2010, 17:37:13 pm »
My set up.
Not at all Lee, i'ts just the pic, it's the flat half of the coolers catching wind. No speedbump issues here. Also, the rake of the car helps alot. My driveway is also VERY steep, once getting level with the road nothing touches at all.
« Last Edit: February 23, 2010, 17:40:13 pm by FDK/Hurry » Logged
stussyrich
« Reply #21 on: February 25, 2010, 00:46:26 am »
mine use the cup bar and some rubber mounts onto the body for fixing points.
Lil Stink Hound.. 2332 IDA. 11.78 @ 112mph.
Turbo Notch.. 2332 Turbo 10.2 @ 137mph.
stussyrich
« Reply #22 on: February 25, 2010, 00:58:37 am »
The fans help with the cooling but to be honest i,ve only used them once in traffic on a very hot day.
The motor runs no hotter than 140 on a 3.5 hour trip to the track.
Also use a ram air fan shroud and a bmd pulley for safety.
Turbo_Rich
« Reply #23 on: February 26, 2010, 17:05:03 pm »
I've mounted mine vertically on the left hand side (looking from behind) between the firewall and driveshaft. It may not see much airflow but is thermostatically controlled. To be honest the only time its needed is when sat in traffic and the extra capacity helps.
Heres a pic- not great but you can make it out-
JSL
« Reply #24 on: March 01, 2010, 13:32:01 pm »
Sorry if this is a dumb question, but is it best to mount the coolers with fans blowing up, or blowing down?
Im guessing in the pic below the air is being blown down to the street.....
And in the pic below the air is being sucked from the street and being blown up.....
Which way is better?
With my limited knowledge I would guess if the air is being blown down to the street, their might be an issue with getting fresh cool air to blow down. And like wise if blowing up from the street it could result in a heat build up?
But then again, I havent a clue what Im talking about  Grin So Im probably way off....
Cheers,
J
Turbo_Rich
« Reply #25 on: March 01, 2010, 19:59:42 pm »
J- they could be drawing air through! Personally I'd have the air being drawn through (ie sucking the heat out) and have it drawing from outside of the car. To be honest though some of these fans are that strong that it probably wouldn't make that much difference so long as its not drawing in warm/hot stagnant air.
peach_
« Reply #26 on: February 02, 2011, 22:26:00 pm »
Bump  Grin
Im just at this stage in my build and wondered if anyone had any updates?
cheers
SAS RENN-WAGENS and proud
#CALLOOKDRAGS
red baron
« Reply #27 on: February 04, 2011, 09:18:23 am »
Hey I asked this questions some time ago. Here is how I managed to get my 96plate cooler in.
