September 24, 2026, 19:09:17 pm
86C Lift
Topic: 86C Lift (Read 4790 times)
86C Lift
March 01, 2010, 06:32:03 am »
What is the lift at the cam on a 86C? Thanks.
Kaferdog
Re: 86C Lift
March 01, 2010, 06:36:00 am »
Hope this isn't consided a "Can of Worm's "....!!!!...LOL.........
Re: 86C Lift
March 01, 2010, 17:05:03 pm »
I had 14 mm at the valve with CB 1.4 rockers
Re: 86C Lift
March 01, 2010, 20:56:55 pm »
Try checking the 'camshaft registry' ... the card is on the first page near the bottom.
http://cal-look.no/lounge/index.php/topic,10956.0.html
Lift for that cam is quoted @ 1.5:1.
Last Edit: August 23, 2013, 14:22:48 pm by TexasTom
Re: 86C Lift
March 02, 2010, 02:41:06 am »
Thank you sir, that worked. it's .390 lift @ the cam. Thank you much.
Ted
