September 22, 2026, 21:02:00 pm
Berg linkage & repro 36hp fan housing.
Topic: Berg linkage & repro 36hp fan housing. (Read 8178 times)
JS
February 19, 2007, 19:19:35 pm »
My repro 36hp fan housing does not have the nuts for the original coil mount welded in. Will the berg linkage work with only two bolts?
How did you guys solve the problem?
Signature.
Re: Berg linkage & repro 36hp fan housing.
February 19, 2007, 19:41:07 pm »
Get Thread inserts in the fan housing. Expensive but a clean look.
JS
February 19, 2007, 20:53:23 pm »
This might just be a case of me being stupid, but how do i get threaded inserts inside the housing?
Signature.
deano
February 20, 2007, 04:51:13 am »
You might also find that when using some repro 36hp fan shrouds, and the Berg linkage, is that the upper two generator backing screw holes are not even level, which makes bolting up the Berg linkage almost impossible (the linkage is no longer level with the engine). Something to think about.... Go Thing fan housing.
Anglia Obsolete Guru
'67 Heaven
February 20, 2007, 04:55:49 am »
You can slot the holes for the linkage mount as well.
March 13, 2007, 10:04:27 am »
Use pop rivet threads JS, easy... or weld a nut in there.
JS
March 13, 2007, 16:49:26 pm »
Thanks for the advice guys, for the coil mount/third bolt iŽll use this thing.
http://www.biltema.no/products/product.asp?iSecId=885&iItemId=80858
deano, the linkage that i have is already modified in the center hole to fit the repro fanhouses.
Signature.
bullitt
everything as it was at the good old days.
March 15, 2007, 19:29:26 pm »
did the work last week. pop threaded rivets will do perfectly
