September 22, 2026, 19:21:29 pm
Flaring aluminum tubing
Topic: Flaring aluminum tubing (Read 3406 times)
Kaferdog
June 02, 2010, 04:28:02 am »
Looking for tips on flaring aluminum 3/8 tubing for running my fuel line....any inside tips would be great ....!.....Like on what flaring tool would be ok to use etc,etc....
Re: Flaring aluminum tubing
June 02, 2010, 05:49:50 am »
You need a 37 degree for flareing AN fittings. Air craft spruce in corona ca. And the same for tubeing benders. Mc master carr in sante fe springs ca. for tube benders. and eastwood co. Hopefully that will get you started
Kaferdog
June 02, 2010, 06:28:43 am »
Thanks Danny....I will look into that....now that I have a starting point ...Keep up the good work !!!!
