October 14, 2026, 21:06:52 pm
| | |-+  HD transmission mount with CSP bar
Author Topic: HD transmission mount with CSP bar  (Read 4381 times)
pupjoint
« on: June 05, 2010, 09:25:11 am »
CSP recommends welding the torque bar brackets on a HD tranny mount as the stock mount is a weak design. Also use anti seize on the threads.
http://www.csp-shop.de/technik/pdf/deeng/20917.pdf
page 6.
they recommended this
http://www.csp-shop.de/cgi-bin/cshop2/front/shop_main.cgi?func=det&wkid=106807709539&rub1=Transmission&rub2=Transmission%20Brackets&artnr=15740a&pn=0&sort=&all=
Vee Dub parts and CIP don't carry this.
Would this Bugpack unit be the equivalent? or anybody sells something similar?
http://www.bugpack.com/content.php?id=343
thanks
« Reply #1 on: June 05, 2010, 09:40:15 am »
Make sure your exhaust is fitted before you weld, I didn't and mine interfered with it.  I used any HD mount, I have even seen people weld to the frame horns.
Sam K
« Reply #2 on: June 05, 2010, 16:33:29 pm »
I used an EMPI mount (part number 00-9543-0) that still uses stock style transmission mounts. Definitely use lots of anti-seize. I didn't and I had to buy another torque bar because the threads disintegrated when I took it apart.
pupjoint
« Reply #3 on: June 05, 2010, 20:21:14 pm »
Thanks just found vdub does carry the HD craddle, they call it quiet mount something, already placed order just now. csp also recommends  using a mid mount with these bars. Very nice instructions.
Chris W
« Reply #4 on: June 06, 2010, 18:54:14 pm »
Is this what you bought?
http://www.vwparts.net/mm5/merchant.mvc?Screen=PROD&Product_Code=BP6522-11&Store_Code=VWP&search=quiet+mount+s&offset=0&filter_cat=&PowerSearch_Begin_Only=&sort=&range_low=&range_high=
pupjoint
« Reply #5 on: June 06, 2010, 19:38:19 pm »
yes
