November 05, 2026, 00:12:57 am
Old K-8
Topic: Old K-8 (Read 8989 times)
Old K-8
August 16, 2010, 22:48:02 pm »
A shot in the dark. Does anybody have an old cam card for the original Engle K-8? I believe the adv. dur. is 304* back then. Want the original spec's. Thanks guy's!
Ted
Last Edit: August 17, 2010, 04:44:58 am by HotRod Ted
DKK Robert
Re: Old FK-8
August 17, 2010, 01:27:29 am »
Try this Link Ted, Hope it Helps.
http://cal-look.no/lounge/index.php/topic,10956.0.html
glenn
Re: Old FK-8
August 17, 2010, 01:55:55 am »
Here's mine.
Glenn
74 Beetle Specs
74 Beetle Restoration
2180cc Engine
www.DasVolks.com
Long Island's Aircooled Club
Re: Old FK-8
August 17, 2010, 02:52:59 am »
Quote from: glenn on August 17, 2010, 01:55:55 am
Here's mine.
Sorry, that's not the old K-8 cam card.
glenn
Re: Old FK-8
August 17, 2010, 03:30:55 am »
So the specs changed?
I guess I just learned something new.
Glenn
74 Beetle Specs
2180cc Engine
www.DasVolks.com
neil68
Re: Old FK-8
August 17, 2010, 03:58:05 am »
I believe the "old FK8" was the same as the Berg GB310 cam: 304 degrees (advertised), 0.380" lift at cam.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
Re: Old K-8
August 17, 2010, 04:44:07 am »
Quote from: neil68 on August 17, 2010, 03:58:05 am
This is correct, but I believe I made a mistake, the original one is a K-8, the newer virsion is the FK-8 that has been around for a few years now. I have FK-8 cam. I was corrected on the
other forum
The older version has a 304* duration (advertised).
Ted
Last Edit: August 17, 2010, 04:46:36 am by HotRod Ted
Re: Old K-8
August 17, 2010, 04:45:42 am »
Email Engle
Re: Old K-8
August 17, 2010, 04:53:59 am »
Quote from: Zach Gomulka on August 17, 2010, 04:45:42 am
Email Engle
Zach, I thought about that, but having new owners, SoCal Imports, maybe disguarded all the old stuff, but ya never know. I'll call them tomorrow. Thanks Zach.
Ted
deano
Re: Old K-8
August 17, 2010, 16:25:27 pm »
Ask Big Rog.... the old K-8s are (one of) his secret weapons......
Anglia Obsolete Guru
'67 Heaven
Re: Old K-8
August 17, 2010, 20:25:34 pm »
As in Crawford? Thanks Deano.
Ted
Re: Old K-8
August 19, 2010, 01:48:58 am »
I called Chris at Engle today and he said that it's always was the same grind. But I remember way back when, seeing the add's for the K-8 @ 304* Dur. Need to dig up my old HotVW's to see the adds. He did say what matters is what it is @ .050, which I do understand, but why 304* then, now 298*? That is a big difference. Jim, maybe you have some info on this?
Ted
bilboa2
Re: Old K-8
August 19, 2010, 05:07:42 am »
ted check out cb's 2288.. split..hotter k-8? just bought a dry sumped 2332 with that cam for my baja, will do a motor swap soon. bill
Ron Greiner
DKP II
Re: Old K-8
August 19, 2010, 05:40:50 am »
I had the K8 Engle in my 2084 motor back in 1976
it was 304 duration, I don't remember the Lift
this was befoe the came out with the FK series
Re: Old K-8
August 19, 2010, 08:34:20 am »
check Gene Berg's cams. they have engle cams as well and one of them is probally the K8, GB310 so it should be available from them. i know that the light blue berglar had one of those...
