October 13, 2026, 08:15:41 am
| | |-+  Engine and parts help... mild road engine project
Pages: 1 ... 3 4 [5] 6 7 ... 16 Print
Author Topic: Engine and parts help... mild road engine project  (Read 271892 times)
« Reply #120 on: November 14, 2010, 17:11:44 pm »
A few more questions :
- What do you think about the CB update kit for Weber IDF carbs ? http://www.cbperformance.com/catalog.asp?ProductID=508
- Do you use OEM thermostat with fanshroud flaps ? I read some remove the thermostat and block the flaps open, and other say it's better to keep the stock system.
« Reply #121 on: November 14, 2010, 17:22:46 pm »
I like the CB update kits. But they will increase the size of the venturi to 34mm which would be too large for your 35.5 intake valves (there is a re-occuring theme here Wink). The factory thermostat allows the engine to warm up properly, I advise using it.
bluestar
D.A.S member
« Reply #122 on: November 14, 2010, 18:33:22 pm »
ok with Zach for the thermostat , you can use it , it's good for a daily driver engine....
« Reply #123 on: November 14, 2010, 22:30:26 pm »
Thanks Zach and Stef  Wink
qubek
« Reply #124 on: November 15, 2010, 16:54:34 pm »
I also recommend using the thermostat, because I don't have one. I doesn't fit with my exhaust and I didn't have time to solve this problem when I was assembling the engine.
I regret that and I will try to find a solution. It's not just that takes longer for the engine to worm up. The problem is that in some conditions, the oil temperature drops and the engine is to COLD.
As for the CB update kit, it seems strange that CB came up with a solution better than an original design. Sure, CB is one of those companies that try to develop products and I respect them for that (it's rare in our hobby), but still, research and development teams in leading carburetor manufacturers like Webber and Dellorto should be.... more experienced in this matter. Why didn't they adopt the solution, if it is that good?
« Reply #125 on: November 15, 2010, 17:50:35 pm »
Who knows... I know IDF's are notorious for plugging idle jets though, and the update kits help the problem.
GreenTom
« Reply #126 on: November 15, 2010, 18:13:02 pm »
As I remember the same solution with horizontal discharge tubes were in zenith carbs?
I used the ubdate kit with my dellortos with really god resoults on the street, streep and dyno.
The jest doctor which is sold with the kit does its job grate as Zach says.
Aircooled Performance Gear
Quick Stick Performance
www.QuickStickVW.com
« Reply #127 on: November 17, 2010, 00:56:46 am »
Thanks Tom  Wink
GreenTom
« Reply #128 on: November 17, 2010, 07:52:15 am »
Thanks Tom  Wink
No problem. The DRLA kit which I have came with 1.5 main jet and 165 air correction tube.
If you have standadr valves  (35,5x32) you'l have a little bit hassitation between progression and main circuit during typical road driving (which can be limited with propper carb adjustement but you'll feel it even though). During 1/4 mile You won't notice it. With bigger valves 40 up the ride will be a hell of a funn Cheesy
Just be patient with card adjustement.
good luck
cheers
Tom.
« Reply #129 on: November 17, 2010, 20:47:36 pm »
 Wink
« Reply #130 on: November 26, 2010, 02:31:53 am »
Another random question, wich kind of quality air filter can I use ?
I like the look of the Flat4... but I'm always wary with Flat4 stuff...
...or K&N ??
 Wink
« Last Edit: November 26, 2010, 02:34:37 am by Nico86 » Logged
fredy66
« Reply #131 on: November 26, 2010, 03:53:47 am »
...or K&N ??
 Wink
kn looks beter
arabia slugs
« Reply #132 on: November 26, 2010, 11:59:44 am »
I like the look of these 2 engines (Philip's one on the first picture, don't remember for the second pic). Flat4 filters have a great look, but do they work fine ?
qubek
« Reply #133 on: November 26, 2010, 16:29:00 pm »
Why can't you buy Flat 4 filters, use only the housings and then put some K&N filtering elements inside? Especially that, as far as I remember, the complete K&N filters for IDFs/DRLAs are quite expensive and - on the other hand - I would be surprised if you couldn't buy the filtering part separately. Probably not in a Beetle shop, but the one that offers K&N filters for general public, "tuners" etc.
I share your concern about the quality of air filters that we can usually buy for Beetles. I drive quite a lot on different kinds of roads and some of those filters just don't work. I am not surprised - a lot of people in our hobby underestimate the importance of air filters (or just don't care - take a look into the topic about the filters for IDAs) and for them it's the price that counts more.
volkskris
« Reply #134 on: November 26, 2010, 17:44:23 pm »
I know a Belgian guy sells alu aircleaners with k&n filters. they look really nice imo.
http://www.german-performance-parts.be/
The Action Is Go
« Reply #135 on: November 26, 2010, 18:47:47 pm »
The second pic is one of my engines with original early Kadron aircleaner covers with no elements inside.
« Reply #136 on: November 26, 2010, 19:30:21 pm »
Clean engine ! Cool
Interesting things there, thanks for the link.  Wink
« Last Edit: November 26, 2010, 19:47:53 pm by Nico86 » Logged
« Reply #137 on: November 26, 2010, 19:46:24 pm »
Just saw the price of the Flat4 stuff  Shocked so I guess I can't be wrong with K&N that cost half the price : http://www.jegs.com/i/K%26amp%3BN/599/56-1170/10002/-1
I will possibly try to made custom old-looking cleaners with K&N elements, cheap air cleaner bodies and some grill.
« Last Edit: November 26, 2010, 20:14:02 pm by Nico86 » Logged
« Reply #138 on: November 29, 2010, 20:46:08 pm »
A few last things to figure out...
- Can I use stock nut crank pulley ? (it will be Berg EQ or same style)
- What paint can I use for the case ? HT paint ? Need to put it on an oven ? It will be black or grey, I still have to decide...
- And another stupid question I want to be sure about : no paint on the heads right ?
« Last Edit: November 29, 2010, 20:58:09 pm by Nico86 » Logged
streetvw
« Reply #139 on: November 29, 2010, 23:56:20 pm »
my 1776 with DRLA's and oval K&N filters
my brothers 1776 with IDF's and square K&N filters
both looked good IMHO but it's all down to taste
« Reply #140 on: November 30, 2010, 23:46:24 pm »
Thanks for the pics  Wink
« Reply #141 on: December 05, 2010, 20:22:57 pm »
 Wink
« Reply #142 on: December 05, 2010, 20:25:00 pm »
- yes, i wouldn't know why not.
- VHT case paint, like felix used. oven or not doesn't seem to matter.
- why would you want to paint the heads? they will also get hotter than the case...
« Reply #143 on: December 05, 2010, 20:44:11 pm »
Thanks Died  Wink
« Reply #144 on: December 05, 2010, 22:31:36 pm »
i was in a rush, hence the short post.
if you want you can also get a pulley bolt that lets you use the 3/8" ratchet directly:
but since it might be fabricated by empi, sourcing an original one may be wiser.
if you're having difficulties locating VHT case paint, try a (local) motorcycle shop, preferably a Harley Davidson (enthusiast) shop.
or try eBay if there are any french seller for that stuff.
good luck!
« Reply #145 on: December 05, 2010, 22:47:47 pm »
Thanks Died  Wink
Here's a JayCee one with a nice price : http://www.vwparts.net/JC1017.html
If a stock nut works with a EQ style pulley I will use a german one. Maybe I don't need the Berg EQ damper with my engine, I'll maybe use a more classic aluminium one (CB or Bugpack).
I've found VHT paint in England there : http://www.cbsonline.co.uk/paint-82-c.asp since I can't order it in the US.
« Last Edit: December 06, 2010, 00:31:14 am by Nico86 » Logged
« Reply #146 on: December 19, 2010, 00:32:16 am »
I found this exhaust system, what do you think ? Seems to be the only merged header with a stock size.
http://www.cbperformance.com/catalog.asp?ProductID=1634
« Reply #147 on: December 19, 2010, 00:34:31 am »
It's been used here : http://www.cbperformance.com/Mar2007.asp
« Reply #148 on: December 19, 2010, 16:53:52 pm »
I thought you were retaining your heater Huh   Also, most merged headers don't allow for a thermostat to be fitted.
« Reply #149 on: December 19, 2010, 17:08:52 pm »
Yes I keep the heating boxes, I was thinking about mounting this CB header without the J-tubes Huh (cut and welded a little to fit on the heating boxes). So I could keep heating and thermostat/flaps system.
I'm currently runing like this on my stock engine, but with a non-merged stock size header.
« Last Edit: December 19, 2010, 17:14:36 pm by Nico86 » Logged
