November 03, 2026, 01:48:20 am
| | |-+  Engine and parts help... mild road engine project
Pages: 1 ... 4 5 [6] 7 8 ... 16 Print
Author Topic: Engine and parts help... mild road engine project  (Read 275369 times)
« Reply #150 on: December 19, 2010, 18:08:25 pm »
I love that little 1-3/8" merged, but it would be tons cooler if it worked with heat.
« Reply #151 on: December 19, 2010, 18:20:46 pm »
The hardest part is to have both bottom tubes to fit with the heaters outputs. It seems that the J-tubes connections are far under the cylinders compared to standard headers.
« Last Edit: December 19, 2010, 18:22:50 pm by Nico86 » Logged
« Reply #152 on: December 20, 2010, 04:13:36 am »
That sounds like a lot of work/money for a little header. Adding heater boxes would make the 1&3 pipes longer, so it wouldn't be equal length anymore. Some proper 40x35.5 heads would solve a lot of problems Smiley Or choosing a smaller cam Wink
« Last Edit: December 20, 2010, 04:20:46 am by Zach Gomulka » Logged
« Reply #153 on: December 20, 2010, 04:52:40 am »
Another random question, wich kind of quality air filter can I use ?
I like the look of the Flat4... but I'm always wary with Flat4 stuff...
...or K&N ??
 Wink
How about these?
http://cbperformance.com/catalog.asp?ProductID=550
« Reply #154 on: December 20, 2010, 12:27:03 pm »
Cam will be smaller  Wink I'm almost done with choosing the parts, I will start buying it after Christmas/new year. I will see later for the header, I have a lot to do first !
« Reply #155 on: December 20, 2010, 12:28:13 pm »
Yes, thanks for the link  Wink
« Reply #156 on: December 26, 2010, 14:33:25 pm »
Guys, what's the difference between the Equalizer and the Achiever Berg pulleys ?  Wink
« Reply #157 on: December 26, 2010, 16:23:56 pm »
Equalizer weighs more.
« Reply #158 on: December 26, 2010, 18:13:46 pm »
 Wink
« Reply #159 on: December 26, 2010, 18:32:53 pm »
Hey Nico, the Equalizer is about 6lbs. and the Achiever is about is about 3 1/2lbs. I've always ran the Equailizer, right now I'm running a NOS Santana Pulley, but going back to my Achiever. according to Berg, it equalizes the weight from front to back and gives you stronger launches at the line cause of the momentum. Hope this helps.
Ted
« Reply #160 on: December 26, 2010, 18:56:53 pm »
Thanks for the infos Ted.
On a mild project like mine, is it usefull to use a heavy equalizer pulley ? Or a more classic billet pulley is better ?
« Reply #161 on: December 26, 2010, 19:17:05 pm »
I look at it in a realistic way, if you going to run it at the track, and want to compete, I'd say yes, but if your more a street guy, then yes, a lighter one. Unless you just want to run a Berg pulley, thats your choice. Myself, I like the look, but also see the track once in awhile. My motor is built more for performance, maybe to much, buts thats just me. I like POWER.  Grin
Ted
« Reply #162 on: December 26, 2010, 19:43:46 pm »
Thanks Ted  Wink
« Reply #163 on: December 26, 2010, 19:52:15 pm »
If you're running a stock non c/w crank and a lightened flywheel it's not a bad idea to use one.
« Reply #164 on: December 26, 2010, 20:18:24 pm »
Will be fine yes  Wink
« Reply #165 on: December 28, 2010, 01:07:18 am »
Need some infos about DPR flywheels, I'm interested with the 12 Volt 200mm 12lbs, 8 Dowelled, Balanced $120 here : http://www.dprmachine.com/Html%20Files/flywheels_1.htm
They start working with german VW flywheel ? Lightweigthed to 12lbs is ok ?
« Reply #166 on: December 28, 2010, 01:49:51 am »
I don't know if they start with a German flywheel but I'm curious to find out as I need one for my car.
« Reply #167 on: December 28, 2010, 02:50:14 am »
Yes, he does use the German flywheels. I'm using his crank and flywheel set-up on my current motor that has been wedgemated. Very good work. I don't think he likes the Chinese stuff. German only.
Ted
« Reply #168 on: December 28, 2010, 22:30:01 pm »
Great, I think I will get one from him, it's a good price. French VW shops usually lightweight flywheels to 5.5 or 5.6kg, so I guess 12lbs (=5.44kg) is good.
« Last Edit: December 28, 2010, 22:53:49 pm by Nico86 » Logged
« Reply #169 on: December 31, 2010, 19:56:45 pm »
Also need help with the clutch.
What I'm thinking about :
- Stock mounting hardware : cross shaft, clutch bearing and bearing clip etc...
- Daikin 200mm super disc http://www.vwparts.net/AC141150.html
- Kennedy 200mm pressure plate http://www.vwparts.net/KEPPSIPLATE.html but what model 1700Lbs, 2100Lbs, 2600Lbs, 3000Lbs ??
  Or a 200mm stock pressure plate ? http://www.vwparts.net/311141025EBR.html but I don't know about the quality. For $30 more I'd rather get a Kennedy.
And a Happy New Year to the Loungers  Cool
« Last Edit: December 31, 2010, 20:10:57 pm by Nico86 » Logged
« Reply #170 on: January 01, 2011, 02:07:15 am »
No more than 1700lb, but stock would work ok for your combo, too. I chose the 1700lb in aluminium because I wanted a free revver Cool But it is much more expensive.
« Reply #171 on: January 01, 2011, 02:20:23 am »
Thanks Zach. A stock Sachs or LUK is $190, so a Kennedy 1700lbs will be fine.
« Reply #172 on: January 01, 2011, 04:29:57 am »
Wow, my aluminium one was only a little over $200...
« Reply #173 on: January 01, 2011, 14:13:55 pm »
There are cheaper clutch kits but the brand is Empi... so I guess it's from China. There is also Amortex that's cheap, that's a co-branding with Sachs but it's made in Brazil.
« Last Edit: January 01, 2011, 17:44:07 pm by Nico86 » Logged
« Reply #174 on: January 01, 2011, 20:51:37 pm »
Yes, I agree with Zach a stock or a 1700lb Kenndy at the most with a Daiken disk will be more than efficient. Cool set-up so far!
Ted
« Reply #175 on: January 01, 2011, 22:32:14 pm »
Thanks Ted  Wink
« Reply #176 on: January 06, 2011, 21:28:51 pm »
Lifters will be SLR Wiesmann : http://www.vwparts.net/SLR24.html with joined oil grooves.
« Reply #177 on: January 06, 2011, 21:31:55 pm »
Good choice. Did you talk to Steve about a cam?
« Reply #178 on: January 06, 2011, 22:25:49 pm »
Yep he gives me a few infos  Wink. He said the W110 is fine with the rest of the engine specs and 40IDF, it will fall in between the XV280 and the XV290.
« Reply #179 on: January 06, 2011, 22:34:49 pm »
nice lifters! good price too
