November 02, 2026, 22:57:35 pm
Get 'R Done
5
6
Topic: Get 'R Done (Read 158831 times)
Re: Get 'R Done
Reply #120 on:
December 07, 2011, 08:35:54 am »
Quote from: tikimadness on December 06, 2011, 22:55:11 pm
Cool dude. Would be nice to see you drive that engine this summer.
Michael
Exactly, get it ready for SCC, than we can drive to there, no bugin next year, so SCC here we come
Last Edit: December 08, 2011, 11:05:18 am by Eddie
Re: Get 'R Done
Reply #121 on:
December 08, 2011, 11:03:32 am »
Harry, just a small question where can I get a magnet like you used on your pickup tube?
I am looking for one.
Re: Get 'R Done
Reply #122 on:
December 08, 2011, 12:58:21 pm »
Mine is a Berg part. Maybe you can get one at Kaag Kevers. They do a lot of Berg stuff.
Re: Get 'R Done
Reply #123 on:
December 08, 2011, 13:14:13 pm »
NEAT, harry, very neat!
keep up the good work!
DVK ~
Re: Get 'R Done
Reply #124 on:
December 08, 2011, 13:27:33 pm »
Ok thanks Harry, will contact kaag than.
Regadrs Edgar
Re: Get 'R Done
Reply #125 on:
December 08, 2011, 16:10:52 pm »
Quote from: 67-indeed/DVK on December 08, 2011, 13:14:13 pm
Thanks Died !
Stupid me, i forgot to compare the pistonboss-height between Mahle and Wiseco. Cylinders are back to the machine shop for shortening at the bottom. (Less shims/good).
Last Edit: December 08, 2011, 16:24:57 pm by Harry/FDK
Re: Get 'R Done
Reply #126 on:
December 08, 2011, 22:07:22 pm »
Very Clean work Harry!
JeePee/DVK
Re: Get 'R Done
Reply #127 on:
December 10, 2011, 08:38:31 am »
Hi Harry,good to see you are back in the shop.
See you at the strip of SCC?
Re: Get 'R Done
Reply #128 on:
December 12, 2011, 19:56:47 pm »
Thanks Ed, Jesse and Jeepee. I'm hoping for SCC, but i will have to be confident off all the crap i'm doing. With the bus for sure, hope we can go Convoy.
Now i have zero deck on the cylinders 1/3 so Steve did his work. I have a small touch to the top with the Wiseco pistons, so just for security i will use the thinnest shim (0,26mm/0.010 " sanded) under the cylinders and use my used sanded/annealed coppershims between the cylnders and heads.
After fully torque of the flywheel, i just didn't like the endplay at all, so i had the flywheel machined on the transmission side instead of the bearing. Just as Felix/DFL, i crushed 2 o-rings, not good, so i glass-beaded the o-ring groove in the flywheel and then polished with 3M pad. Pics later.
Harry
Still don't like the endplay of the flywheel, so tomorrow off to the machine-shop again.
December 14: Again. December 15: Again. Lathe-Lease
Ps. Thats my empty wallet in the background...
Last Edit: December 19, 2011, 18:01:53 pm by Harry/FDK
Re: Get 'R Done
Reply #129 on:
December 15, 2011, 21:22:46 pm »
Not much going on, i set up endplay, crushed/ damaged 3 o-rings and still don't like the "feel" of it so i didn't went too tight... Alex's tool is just great ! Then worked the humps on the bottomside of the cylinders one more time before VHT paint. I went for lightweight pistonpins from CB but they have to be shortened on BOTH sides to fit the Wiseco's. The pins have a conical step on the inside, so you have to shorten them on both sides. Then check the insides for teflon-button diameters. It only can be done on a lathe with liquid cooling, this is real tool-steel. They sound like a bell.
Harry
Last Edit: December 15, 2011, 21:24:29 pm by Harry/FDK
Paulus
Re: Get 'R Done
Reply #130 on:
December 15, 2011, 22:01:52 pm »
Hi harry,
Its nice to see that you are going to finish the engine! its going to be a beast!!
Greets,
Paul
Less is More !
Re: Get 'R Done
Reply #131 on:
December 16, 2011, 01:24:22 am »
I'm crushing (fly-wheel) o-ring after o-ring, no matter what i do. (heat,cold, moly, teflon spray whatever). It's driving me nuts.
Re: Get 'R Done
Reply #132 on:
December 16, 2011, 02:08:03 am »
Did you get your endplay set? if not set it without the O ring,and get it so you are happy with it,then add the o ring and see if it changes
Re: Get 'R Done
Reply #133 on:
December 16, 2011, 18:16:09 pm »
Re: How many times did you find a crushed flywheel o-ring
« Reply #8 on: Today at 18:08:14 »
Quote from: Harry/FDK on Today at 12:36:57
Quote from: richie on Today at 02:04:35
what brand o ring? and what brand flywheel? can you show us what it looks like still in the flywheel groove after you took the flywheel off?
Thanks Richie. Victor-Reinz 0-ring, german flywheel, pics will follow. I have a hunch what causes the problem...
Crankshaft end has a smooth radius, the flywheel however has been machined deeper on the o-ring side. On the bad pic you can see a small black dot on the bottom side of the o-ring groove. This section cannot mate with the crank perfectly so i think this is causing my o-ring problem, and gives me different readings for endplay when i turn the crank. Hope this makes sence.
Harry
PS, i checked some no brand o-rings today, most have "hairs" inside/outside that can cause many people the same problem.
Thanks for your interest Richie.
PS. this is another flywheel i used for the picture to make things a little clearer.
Last Edit: December 19, 2011, 18:04:22 pm by Harry/FDK
Re: Get 'R Done
Reply #134 on:
December 16, 2011, 18:25:29 pm »
Just to have some peace of mind i took the shortblock apart and doing some more homework.
Re: Get 'R Done
Reply #135 on:
December 17, 2011, 09:02:25 am »
Quote from: Harry/FDK on December 16, 2011, 18:25:29 pm
Oh no..
Re: Get 'R Done
Reply #136 on:
December 18, 2011, 14:53:22 pm »
Good to see work starting again here
I really need to get back on mine too!
Re: Get 'R Done
Reply #137 on:
December 18, 2011, 20:58:14 pm »
« Reply #18 on: Today at 20:53:54 »
Quote from: richie on Today at 01:53:38
Quote from: Harry/FDK on December 16, 2011, 18:08:14 PM
Why? so are you saying that the flywheel was machined in the area the crank fits into deeper that normal? was the end of the flywheel machined to compensate for this? to keep the correct distance for end play.
If so the o ring is now moving further up the end of the crank when you fit the flywheel and trying to twist itself around,do you fit it with the crank end dry?a little oil would help,its not ment to sit up that far on the crank end in my opinion,be carefull if you "round off " the end of the crank to keep it even,I ave had no problems for a long while,just using the regular Elring supplied o ring that comes in ther gasket sets.
Hopefully you find the sloution and can finish up your engine soon
Richie, youre correct. The flywheel has been machined deeper because the balancer didn/t like the mating of both surfaces. Normally i had never a problem with Victor Reinz / Elring gasket sets with the 0-ring supplied. Enough boring you all, back to my other topic Get 'R Done.
Thanks again all.
Harry
Last Edit: December 19, 2011, 18:05:15 pm by Harry/FDK
Re: Get 'R Done
Reply #138 on:
December 18, 2011, 22:01:07 pm »
Quote from: Eddie on December 17, 2011, 09:02:25 am
Oh no..
No problem Ed, now i can check Silverline mainbearings as well...
Re: Get 'R Done
Reply #139 on:
December 22, 2011, 23:36:49 pm »
Messed up posting, shortblock together with Silverline bearings for crank. This set worked out as good as Mahle, just the scotch treatment and all measurements were perfect.
Last Edit: December 22, 2011, 23:56:07 pm by Harry/FDK
Re: Get 'R Done
Reply #140 on:
December 22, 2011, 23:38:59 pm »
Second attempt. Flywheel has been re-machined, we are 3/100 mm 0ff and zero on the balancer, so now endplay and o-ring issues... More pics later.
Harry
Last Edit: December 23, 2011, 09:35:45 am by Harry/FDK
Re: Get 'R Done
Reply #141 on:
December 23, 2011, 02:39:19 am »
Tight endplay set. 0.05/6...
Last Edit: December 23, 2011, 09:36:34 am by Harry/FDK
Re: Get 'R Done
Reply #142 on:
December 23, 2011, 10:02:34 am »
Why such a tight endplay?
Re: Get 'R Done
Reply #143 on:
December 23, 2011, 13:10:46 pm »
Quote from: Jesse/DVK on December 23, 2011, 10:02:34 am
No matter what combination of shims i use, it's either slightly to loose or on the tight side. I will check again after run-in.
Re: Get 'R Done
Reply #144 on:
December 23, 2011, 14:58:32 pm »
Wow, a swiss cheese flywheel! How much does it weigh?
DVK ~
Re: Get 'R Done
Reply #145 on:
December 23, 2011, 22:09:49 pm »
Quote from: 67-indeed/DVK on December 23, 2011, 14:58:32 pm
4.8 KG-ish, so streetable. It's just a different approach from Jakob Spring compared to Ahnendorp.
Last Edit: December 23, 2011, 22:13:07 pm by Harry/FDK
Re: Get 'R Done
Reply #146 on:
December 26, 2011, 18:38:35 pm »
Sanding one more time the cyl. washers and copper rings with 1000 wet/dry and WD40. Cold/shrinked the copper washers in the heads. Cleaned everything, RTV on cyl/bottom and heads. Then pulled a stud from the case-saver #3 and can't get the fucker out. Tons of heat, doesn't work, now loctited a threaded end in and wait for tomorrow. Godda"<_ed. I don't want to drill...and Helicoil. Not enough meat. Are the inserts M12 ?
Last Edit: December 26, 2011, 21:56:17 pm by Harry/FDK
Re: Get 'R Done
Reply #147 on:
December 26, 2011, 19:06:48 pm »
... + Midlife Crisis Pic...
Last Edit: January 25, 2014, 13:05:55 pm by Harry/FDK
Re: Get 'R Done
Reply #148 on:
December 26, 2011, 21:18:46 pm »
Drilling for M8 Helicoil would be M10...Leave the casesaver (M12) or not? Godvergloeiendegodverdomme.
Last Edit: December 26, 2011, 21:54:17 pm by Harry/FDK
Re: Get 'R Done
Reply #149 on:
December 26, 2011, 23:10:20 pm »
So, Help !
5
6
