September 15, 2026, 17:57:07 pm
Bad Habit
Get 'R Done
5
6
Topic: Get 'R Done (Read 153002 times)
Re: Get 'R Done
Reply #150 on:
December 27, 2011, 00:19:52 am »
Factory case saver? M12
heres factory later case[m12 with 8mm stud],CB case saver[american thread for 10mm stud] and a case saver for early cases that didnt use them[m14 for 10mm stud]
I dont totally understand what you did? you pulled the stud out of the case saver? or broke the stud in the case saver?
Re: Get 'R Done
Reply #151 on:
December 27, 2011, 13:15:22 pm »
Hi Richie, Factory case saver M12. (i pulled the stud out of the case saver on half torque/ never happened to me before). I managed to tap the case saver all the way in to M10, loctited a thread-end in it and waiting for everything to set. Hopefully with a lot of heat surrounding it, it will come out.
19:30: And that's it... Threaded end broke off, even with a ton of heat and "gentle" treatment.
Last Edit: December 27, 2011, 20:23:41 pm by Harry/FDK
Re: Get 'R Done
Reply #152 on:
December 28, 2011, 19:25:29 pm »
Somebody upthere must like me... Pffff.
Re: Get 'R Done
Reply #153 on:
December 29, 2011, 07:02:53 am »
Cool Harry!
Re: Get 'R Done
Reply #154 on:
December 31, 2011, 19:53:13 pm »
Quote from: Jesse/DVK on December 29, 2011, 07:02:53 am
Cool Harry!
That action was another coffin-nail...
Last Edit: January 02, 2012, 17:35:16 pm by Harry/FDK
Re: Get 'R Done
Reply #155 on:
December 31, 2011, 20:00:56 pm »
For you non-Callook-cooling guys, this is a LOOSE fit of the CSP shroud. I'm very happy with it, and i've seen a lot worse in polyester building. This kit needs just a day to be perfectly trimmed. The fabricator left enough meat to BE trimmed. You will have to do some simple modifications to your pulley "tin" and rear "tin", if you want to keep a Berg Equalizer (like me). Thanks Gunter. Here we go.
Last Edit: January 01, 2012, 13:26:34 pm by Harry/FDK
Re: Get 'R Done
Reply #156 on:
December 31, 2011, 20:15:39 pm »
Part II
Re: Get 'R Done
Reply #157 on:
December 31, 2011, 20:19:45 pm »
Part III.
Last Edit: January 01, 2012, 13:27:10 pm by Harry/FDK
Re: Get 'R Done
Reply #158 on:
January 02, 2012, 17:40:49 pm »
Part IV [ Attachment: You are not allowed to view attachments ]
Re: Get 'R Done
Reply #159 on:
January 02, 2012, 17:42:51 pm »
Part V (T1 Tins or T3 Tins?). What are your opinions ?
Last Edit: January 02, 2012, 17:47:02 pm by Harry/FDK
Re: Get 'R Done
Reply #160 on:
January 02, 2012, 18:27:43 pm »
If you don't plan on using the "sled" tins by 1&3 and the opposing tins on 2&4, then use the type 3 "cool" tin. I prefer to use the type 1 style though. Tins fit tighter that way.
Re: Get 'R Done
Reply #161 on:
January 02, 2012, 18:32:13 pm »
Quote from: Zach Gomulka on January 02, 2012, 18:27:43 pm
Zach, can you explain this matter a little bit more please.
Re: Get 'R Done
Reply #162 on:
January 02, 2012, 20:32:56 pm »
Use the type 1 tins,but you need to use all the end pieces as well that fit around the exhaust area and deflect the air around a little,the front 2[the pieces that go around from the flywheel area to under the push rod tubes on a stock engine] need to be cut up to allow the header to fit,the rear 2 sometimes need a little trimming around the exhaust port to clear,similar to what you had to do to the csp shroud
Re: Get 'R Done
Reply #163 on:
January 02, 2012, 20:43:24 pm »
Thanks Richie. I still have a lot of T1 tin available. Maybe use it as a template and make it from aluminum, or fabricate to combine the T1 with T3's .... There's a Italian guy who posted some interesting pics as well for cooling the cyl/heads, but i can't find his topic.
Last Edit: January 02, 2012, 21:35:35 pm by Harry/FDK
Re: Get 'R Done
Reply #164 on:
January 04, 2012, 15:35:26 pm »
Good work Harry
Re: Get 'R Done
Reply #165 on:
June 08, 2012, 21:28:02 pm »
A lot has happened and i'm still alive, working on this project now. Jubi should be finished the coming winter. Tomorrow Kustom Culture.
Last Edit: January 25, 2014, 13:00:54 pm by Harry/FDK
ugly duckling
Re: Get 'R Done
Reply #166 on:
June 20, 2012, 04:44:37 am »
NICE BIKE YA GOT THERE HARRY
GET R DONE MY FRIEND.
www.dprmachine.com
www.4inbore.com
jeffsvwspeed@gmail.com
Re: Get 'R Done
Reply #167 on:
June 20, 2012, 17:34:48 pm »
Quote from: ugly duckling on June 20, 2012, 04:44:37 am
Thanks UD !!!
Re: Get 'R Done
Reply #168 on:
June 21, 2012, 08:22:21 am »
Heeee Harry good to see you still alive...
long time since you posted..
Everything ok?
a bike noooo....
Re: Get 'R Done
Reply #169 on:
June 25, 2012, 20:53:25 pm »
whats he purpose of the welding on the cooling fins on the head?
nice build just read through it all
Re: Get 'R Done
Reply #170 on:
September 03, 2012, 20:10:38 pm »
Quote from: andy198712 on June 25, 2012, 20:53:25 pm
According to UD, it makes a more durable head. (less vibration i guess).
Anyway the Jubi bug will be moved back to it's homeland. (sans engine). I'm thinking of planting the finished engine in the KG. Or sell everything VW related. Maybe it's time to move on.
Last Edit: September 03, 2012, 22:07:40 pm by Harry/FDK
Re: Get 'R Done
Reply #171 on:
March 10, 2013, 22:12:18 pm »
Quote from: Eddie on June 21, 2012, 08:22:21 am
Everything ok?
a bike noooo....
2 Bikes already, the Jubi has gone back to Germany and it looks like shit already. I just have to part from it... The KG will be finished first with the T1 engine.
5
6
