August 13, 2026, 04:23:17 am
2276 questions
6
Topic: 2276 questions (Read 126227 times)
Re: 2276 questions
Reply #30 on:
May 27, 2007, 13:49:08 pm »
Now another one:
i plan to assemble my engine to zero deck and then use copperhead shims to set the deck height
i have 57 cc chambers, web 86c
with the 0.06 gaskets; i would have a cr of 9.4
with the 0.04 gaskets, it will be 9.9
I would like to keep the dh as little as possible to have a more efficient burn, and maybe cooler running engine
should i worrie to run 9.9 on pump gas? 9.9 is better for the cam i think..
i dont think i will have valve clearance issues this way either ? i ll see when i mock it up
what gaskets are the best for me?
thanks guys!
Frank LUX
Back...Soon...hopefully!!!
Re: 2276 questions
Reply #31 on:
May 27, 2007, 14:16:57 pm »
9.9 is not alot of CR for such a Motor/Cam...
I would at least go 10.5CR...my 02Cents...
Frank
Re: 2276 questions
Reply #32 on:
May 27, 2007, 17:35:46 pm »
.040"... and hopefully your pistons wont kiss the heads
Re: 2276 questions
Reply #33 on:
May 27, 2007, 21:20:38 pm »
0.06 You can always become a Bad Boy.
My Humble Opinion.
Re: 2276 questions
Reply #34 on:
May 28, 2007, 10:00:16 am »
what do you mean?
i wanna build it right from the first time; or at least try to
i just dont want to ping the hell out of it;
i dont think that 0.02 will make a difference regarding valves kissing the heads, or does it?
i guess i can only see if its mocked up..
If i can safely run pump gas, i ll go for the 0.04 s i think
cheers, Peter
Re: 2276 questions
Reply #35 on:
July 24, 2007, 21:03:16 pm »
hi guys,
another issue:
i dropped the crank in the case along with the cam,
and at some points, the crank almost touches the camlobes
its a 82 dpr and cam is 86 c
should i grind the crank a bit? i think touching the lobes is a nono right?
here s a pic, kinda blurry though
Re: 2276 questions
Reply #36 on:
July 24, 2007, 21:05:53 pm »
a pic of the cam on the gear...
i think i mounted it good, but not 100 % sure...
Re: 2276 questions
Reply #37 on:
July 25, 2007, 11:37:38 am »
hey guys
i think i need 1 mm clearance, right?
did somebody have to do this also? i dont know if its common practice;
if i have to clearance, i ll have to take some material from the cheek near the journal..i still have a few mms for grinding there...
what do you think?
Re: 2276 questions
Reply #38 on:
July 25, 2007, 12:53:02 pm »
some extra pics of how i want to do it...
i want to sand down the yellow part on the cam first, then see what clearance i get and then if i need more, sand a bit of the crank with a dremel..
i have to chamfer the lobes a bit anyway, 0.5 mm wont do any harm right? i think this way, i allready can achieve the clearance...
can you tell me also if the gear is mounted correctly on the cam? i used the gold colored washers for a straight up timing..sounds ok?
Another BIG thank you!!!
Re: 2276 questions
Reply #39 on:
July 25, 2007, 19:13:27 pm »
hey guys, an update:
i sanded the cam and crank down like the picture above, and i have 1 mm clearance now;
i made sure that nothing became hot..
i only needed to do this on on place, so the work was no biggie..
1 mm should be enough right?
bye!
lowfastbus
WUNDERWAFFE
Re: 2276 questions
Reply #40 on:
July 25, 2007, 21:04:08 pm »
I don't know how much you took off, but don't you think you ruined your balance with that...
Just thinking?
Jelle
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
Re: 2276 questions
Reply #41 on:
July 25, 2007, 22:18:24 pm »
Hi Jelle!
i dont worry to much about that,
i ll have to balance everything anyway...
what do you guys think about the 1 mm?
Re: 2276 questions
Reply #42 on:
August 23, 2007, 20:04:22 pm »
hey guys,
i removed 5 g from this piston;
please look at the pic tell me that i didnt screw up
Cheers, Peter
SMO
Typ 1 -61
Re: 2276 questions
Reply #43 on:
August 28, 2007, 22:31:59 pm »
Hello ruff !
Interesting reading here
Some of my friends needed to machine work the cam because small clearance between crank/rod and cam.
Install the rods too, you can have some problems there too...
What kind of crank and rods do you use ?
Cam gear installation looks good if you have the mark on cam gear in line with the straight "cut" on the cam.
Iīm building a 2332cc engine with CB auto linea case 9,5mm deck height. CB super race crank 84mm, scat 5,7" rods
and i have much space in my case, donīt need to sand at all.
But i hade some problems with my rod journals, varying thickness of the journals "clevite", so i need to buy 2 kit to match
8 journal halfs, now i have 0,05-0,06mm clearance on the rod journals, if i had used the fist set i should have a clearence at 0,12mm at one rod... not good.
The thickness of the journals varying between 1,540mm - 1,575. The thickness All my journals are now between 1,560mm and 1,575mm
Regards
Magnus SWE
Re: 2276 questions
Reply #44 on:
August 29, 2007, 18:37:23 pm »
hey dude.
my crank is a dpr and cb 5.5 h beams..
I will run the piston...should be ok
still alot of work to be done:
balance everything,
tap and plug the galleys,
check oil clearance cam, rods,
check rodbolts for stretch,
measure deck height correctly
grind cam bolts,
i m getting depressed when i think about it
Re: 2276 questions
Reply #45 on:
January 13, 2008, 17:15:23 pm »
my friends,
recieved my parts from the balancer...
so some progrees has been made..
everything balanced, case plugged, oil clearance brought to 0.07 for main and rod journals, cyls honed, new arp bolts
I m finally getting somewhere
too bad my house requires a lot of my spare time
Re: 2276
Reply #46 on:
February 01, 2008, 20:31:59 pm »
not IDAs , but i think they are cool anyway
with these stacks
SMO
Typ 1 -61
Re: 2276 questions
Reply #47 on:
February 14, 2008, 23:31:02 pm »
Hi !
Almost done with your engine?
Add some pics if you have.
My engine is almost done now, some work left with the fan house..
have some pics here ...
http://ausbrechervwmange.blogspot.com/
// Magnus SWE
Re: 2276 questions
Reply #48 on:
February 15, 2008, 12:13:37 pm »
Hello Magnus!
Engine is not ready at all
still have to buy some stuff...
oil cooler, throttle bodies etc ...
and i need to find a socket for my gland nut to get my flywheel off from balancing..
they seem hard to find... i think its 48.1 mm or something US size, i think 1 7/8 or 1 15/16
ordered a month ago but still waiting
but my house is almost finished ..time to work on the mill again
Re: 2276 questions
Reply #49 on:
February 15, 2008, 12:54:04 pm »
good looking engine dude!
lowfastbus
WUNDERWAFFE
Re: 2276 questions
Reply #50 on:
February 15, 2008, 19:57:00 pm »
Hey Peter,
Is this a special gland-nut?? If not I have a socket that fits onto a stock one....
You can come and pick it up if you want.
Jelle
WUNDERWAFFE
The Knuckle Buster
Re: 2276 questions
Reply #51 on:
February 15, 2008, 20:34:35 pm »
Hi Jelle,
just looked in the bugpack catalog and its a 1 7/8 socket i need...
thanks !!!
Re: 2276 questions
Reply #52 on:
March 26, 2008, 12:13:32 pm »
Hello guys,
when i was removing weight from one piston, i did not check if i removed the weight equally under the pin bosses,
so i dont know if the piston balanced well on itself...
dumb dumb i know
do you guys know a way how to measure the balance?
i removed about the same on each side, but i dont know for sure...
maybe problem in high revs?
Re: 2276 questions
Reply #53 on:
March 26, 2008, 20:10:19 pm »
It's not reciprocating weight, so don't worry as long as the weight matches the other pistons. And, of course, as long as you haven't removed too much weight form just one side!
airstuff
Re: 2276 questions
Reply #54 on:
March 26, 2008, 21:35:44 pm »
Quote from: ruff on March 26, 2008, 12:13:32 pm
Hello guys,
dumb dumb i know
what tool did u use to remove weight from pistons,I used to drill it out
Re: 2276 questions
Reply #55 on:
March 27, 2008, 12:14:35 pm »
hello,
i did it with a dremel
airstuff
Re: 2276 questions
Reply #56 on:
April 30, 2008, 11:19:47 am »
Hey Ruff,
Any progress here?
Re: 2276 questions
Reply #57 on:
April 30, 2008, 16:06:00 pm »
Hey dude,
thanks for asking!
still some work needs to be done:
piston grinding to get even DH
and then setting the rocker geometry,
making a new muffler,
and then a lot of those small jobs like modifying the tins and so on..
still waiting for the stacks for my jenveys
cheers, Peter
Re: 2276 questions
Reply #58 on:
May 02, 2008, 12:28:12 pm »
Hey guys!
another q i have about pulleys:
do they have to have a tight fit on the crank?
i know with my equaliser i can slide it over the crank with ease...
Re: 2276 questions
Reply #59 on:
May 02, 2008, 20:59:26 pm »
Quote from: ruff on May 02, 2008, 12:28:12 pm
Hey guys!
yes it should be a tight fit. If it "slides on" you will have problems. It will wallow pulley or crank or both out once you run the engine. Not a good idea to run it like that. Typically, Berg pulleys are a very tight fit (have to heat to get it on the nose... like timing gear), so I would suspect it is your crankshaft. Some firms can "knurl" the nose of crank for a tigheter fit. Have you miked it?
6
