October 12, 2026, 08:08:44 am
| | |-+  center pull linkage explanation
Author Topic: center pull linkage explanation  (Read 35510 times)
« on: October 02, 2010, 15:33:17 pm »
i've collected 2 center pull linkage for the future engine , one look older(left (maybe it's a racetrim one) and the second is more newer (right(bugpack)
ithere's a difference between the 2 center pull  ,check the pict  under
The oldest seems more right(straight), less oblique, and higher
the problem is when i've put the center pull on the case  ,the newer is closer to the fan and far away from the distributor ,and if i put the older he's closer to the distributor and far away from the fan , i would like to know if you have the same problem with yours
i would like to put the racetrim one on my engine to have the correct period parts for this one
so light me thx
« Last Edit: October 24, 2010, 02:42:48 am by speedwell » Logged
« Reply #1 on: October 02, 2010, 15:34:59 pm »
 Wink
« Reply #2 on: October 02, 2010, 15:44:25 pm »
here's the newer on the case you can see how closer he's to the fan  Shocked
and the older is far
« Last Edit: October 02, 2010, 15:47:03 pm by speedwell » Logged
« Reply #3 on: October 02, 2010, 15:47:53 pm »
newest
older
« Reply #4 on: October 02, 2010, 15:49:59 pm »
distance from the distributor caps
newer
older
« Reply #5 on: October 02, 2010, 17:26:53 pm »
Check to see which one pushs on the arms of the carbs with less bind, You can always grind a little on the pads on the center peice to move in or out.
« Reply #6 on: October 02, 2010, 23:17:04 pm »
dude what are you worried about there is plenty of clearence there with both mounts,
I use an original DDS center piece with a homemade swivel piece and Yes it does come close to both the dizzy and fanhousing BUT if you are pulling the carb arms then the clearence will only INCREASE as you pull the cable/push the pedal - do you get what I mean  Undecided
xavier
« Reply #7 on: October 24, 2010, 00:29:20 am »
If not a Race Trim it comes from the same mould! It looks identical to my NOS one.
Painted or not painted? Mine is raw finish. Do not know if there was a painted version?
Xavier
« Reply #8 on: October 24, 2010, 02:46:26 am »
xavier , mine is raw finish too , as i asked you beforecan you send some pictures of your NOS one and the lenght of the arms
thx
fabs
xavier
« Reply #9 on: October 24, 2010, 14:52:23 pm »
Check your mails... Grin
Xavier
« Reply #10 on: October 24, 2010, 15:02:16 pm »
Xavier
thx xavier
Jokke
« Reply #11 on: August 05, 2025, 19:19:09 pm »
Has anyone figured out what make the ”older” model is? I just happened to get one and would like to know
Jokke
