September 23, 2026, 14:47:34 pm
| | |-+  height difference between DCNF and Zentih NDIX?
Author Topic: height difference between DCNF and Zentih NDIX?  (Read 5867 times)
alex d
« on: October 22, 2010, 12:17:42 pm »
does any of you guys have a DCNF and a NDIX to measure how tall they are? I might have a height challenged engine project in my future Grin
« Reply #1 on: October 22, 2010, 16:52:30 pm »
The Zenith is a lot taller!
alex d
« Reply #2 on: October 23, 2010, 10:58:40 am »
damnit! I think that rules out my crazy but period-correct idea  Grin
lawrence
« Reply #3 on: October 24, 2010, 07:44:12 am »
Easy solution to the problem. IDAs Grin
"Happiness is a Hot VW!"
alex d
« Reply #4 on: October 25, 2010, 14:40:43 pm »
yeah, that's easy they are not going to fit  Grin
alex d
« Reply #5 on: October 26, 2010, 12:53:38 pm »
I'm checking bugsprays, wich have the same bolt pattern too, but they seem to be quite tall too, grrrrrrrrr  Angry
« Reply #6 on: October 27, 2010, 00:59:47 am »
Bugspray is even taller than the Zenith, I'm pretty sure. DCN's and DCNF's are the shortest performance VW carb I know of.
Lightning
« Reply #7 on: November 14, 2010, 21:48:04 pm »
My DCNF 40's are a total of 115mm tall, of which 25mm are usually inside the air filter. I have them assembled on some Scat manifolds which have the flange end up app. 85mm above the 'shelves' in the engine compartment. Have put a 5mm plastic plate between manifolds and carbs.
On the pictures you see an intermediate alu-block of 25mm thickness which is there to get the air filters aligned with the engine compartment. The Scat manifolds are straight, they don't correct the offset of the engine, so this plate was necessary to get the air filters in. Total height of everything from the manifold flange is 213mm.
« Reply #8 on: November 15, 2010, 15:28:34 pm »
on a type3 DCNF's fit and IDF's or dellorto's fit on short manifolds?  Wink
