October 13, 2026, 10:09:21 am
| | |-+  What filters for my IDA?
Pages: [1] 2 Print
Author Topic: What filters for my IDA?  (Read 27041 times)
Blob
« on: November 25, 2010, 08:08:59 am »
Hi
What filters are the best for my 48IDA?
I am useing the engine for steet. But I don´t what brand/type of filters that will be the best.
So far I have only found K&N and Ramflo.
I have two types of stacks. The original stacks and some who are wider, about 98mm outside at the top. But are there any filters that will fit wide stacks? I think the stacks are called "Pro-Stacks", but I am not sure.
If anybody have some for sale, new or used at a good price, you are very welcome to let me know. Smiley
I have just read that some have tried that the foam-style filters, and that they were being suck in to cabs.
So I could sound like that K&N style is the way to go.
Anybody who have some other experiences?
« Last Edit: November 25, 2010, 08:43:59 am by Blob » Logged
Kaferdog
« Reply #1 on: November 25, 2010, 09:00:57 am »
Try these..!
http://www.aircooledengineering.com/products.htm
« Reply #2 on: November 25, 2010, 09:57:34 am »
None are fine Wink
Blob
« Reply #3 on: November 25, 2010, 10:06:24 am »
Yes I know a lot of people are driving without, because they think it look´s cool.
But I have decided that I want to run with filters. Smiley
« Reply #4 on: November 25, 2010, 10:13:06 am »
i bought some filters a few years ago, from proformance i think it was.
don't have a pic though, but i know other people (e.g. Sarge) run/ran them too.
they're mesh with a rubber edge that slides onto the stack. no increase in height either.
Blob
« Reply #5 on: November 25, 2010, 10:23:46 am »
But how good are the Mesh filters? I have never seen them in real life, but at the pictures it look´s like they will only remove "big" stones.
How good are the filter funktion, when it is dusty?
Zündfunke
« Reply #6 on: November 25, 2010, 13:03:26 pm »
You´re talking about these...
I think they´re only good to keep birds and bees away from your motor.  Grin
BURN OUT Syndrom
« Reply #7 on: November 25, 2010, 13:06:13 pm »
those are the ones, and it was shaun geers.
guess that's what they'll be doing then  Wink
JS
« Reply #8 on: November 25, 2010, 13:41:17 pm »
I've heard horror stories about 20% horsepower loss with the Geers type... Fairytales or fact?
Signature.
glenn
« Reply #9 on: November 25, 2010, 14:20:52 pm »
I'm running Uni filters.
Glenn
www.DasVolks.com
Long Island's Aircooled Club
« Reply #10 on: November 25, 2010, 14:26:05 pm »
no idea, but i can't see why they would?
mesh filters are far less "distortive" than foam filters...
Blob
« Reply #11 on: November 25, 2010, 14:37:12 pm »
Just my thought..
I have read somewhere that some have had problems with the foamtype, being sucked into the stacks. Any of you who have tried that?
So there is 3 options:
K&N, Foam-style and Mesh.
« Last Edit: November 25, 2010, 14:39:29 pm by Blob » Logged
Zündfunke
« Reply #12 on: November 25, 2010, 15:02:01 pm »
...Ram Flow:
http://image57.webshots.com/457/0/45/10/2381045100087888626SxmKZa_ph.jpg
BURN OUT Syndrom
Jesse/DVK
'64 2176cc
« Reply #13 on: November 25, 2010, 15:20:24 pm »
I have foamfilter, no problems at all and easy to remove when the engine bay is showed  Cheesy
Blob
« Reply #14 on: November 25, 2010, 15:21:44 pm »
I can´t open the link. Sure the link is right?
Zündfunke
« Reply #15 on: November 25, 2010, 15:27:02 pm »
BURN OUT Syndrom
« Reply #16 on: November 25, 2010, 17:04:33 pm »
Aircooled.net sells foamies with a inside spring installed so they won't get sucked in.
glenn
« Reply #17 on: November 25, 2010, 19:02:55 pm »
That's what i have.
Glenn
www.DasVolks.com
Blob
« Reply #18 on: November 25, 2010, 19:09:41 pm »
I have received some very interesting information about K&N and clones. http://shoptalkforums.com/viewtopic.php?f=1&t=133791&p=1042182#p1042182
I have never seen the mesh-style, only pictures, so I don´t know how good they are. I just think they look so coarse.
So I think that i will use some foam filters.
stealth67vw
« Reply #19 on: November 25, 2010, 19:14:39 pm »
Geers claims dyno proven zero hp and flow loss.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
JS
« Reply #20 on: November 25, 2010, 21:17:49 pm »
If one looks at the aerodynamical properties of a stack with and without the filter it seems incredible that there is no difference in air flow. But if it´s proven, it´s proven.
Signature.
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #21 on: November 26, 2010, 03:09:36 am »
  Ummmm IDA's don't have filters.........
« Reply #22 on: November 26, 2010, 17:26:41 pm »
In certain off road classes/divisions, they do.
 Grin
banditina
« Reply #23 on: November 26, 2010, 18:57:20 pm »
i have this one and i thik that work good!
glenn
« Reply #24 on: November 26, 2010, 19:15:05 pm »
IDAs, Berg linkage, Bosch 010 and mechanical fuel pump... I like it.
Glenn
www.DasVolks.com
banditina
« Reply #25 on: November 26, 2010, 19:30:02 pm »
VERY TNX.. and the A1 dynomax muffler? hihihihiihiih Grin
glenn
« Reply #26 on: November 26, 2010, 21:33:58 pm »
I went Berg with dual QPs
Glenn
www.DasVolks.com
« Reply #27 on: November 27, 2010, 00:16:36 am »
Will these fit without decklid modifications? i.e. fully closed & no interference???
« Reply #28 on: November 27, 2010, 02:55:56 am »
Hello.
In general it is correct that those mesh filter on the stacks kill power. But I have also seen engines that absolutely did´nt care. Dont ask me why, because I dont know.
Foam filters definitely rob some power. Typically about 10 hp per 200 hp. When these filters are used, it is ESSENTIAL!!! that the engine gets dynoed/jetted WITH the filters or it WILL run rich.
With the K&N style filters there are normally not much of a difference with and without filters. Yes, the K&N style filters are not that good UNLESS you remember to oil the filter units. Then they increase efficiency by about 35% without sacrificing flow.
ACE´s filters are really good and does not rob much power if any.
In Blobs case I think the first question needs to be "how much room is there?" After that we/he can begin thinking of types of filters.
Jason Foster
« Reply #29 on: November 27, 2010, 04:40:58 am »
 Grin
  Ha....  just being a butt
Pages: [1] 2 Print
