February 21, 2026, 19:33:02 pm
Popsco
67 karmann ghia
6
7
Topic: 67 karmann ghia (Read 271586 times)
wolfswest
Re: 67 karmann ghia
Reply #180 on:
July 08, 2024, 21:01:04 pm »
C'mon, lot's of stuff to share Glauco. Keep us entertained please!
Glauco
Re: 67 karmann ghia
Reply #181 on:
July 09, 2024, 10:36:35 am »
Quote from: wolfswest on July 08, 2024, 21:01:04 pm
I will, but I didn't take that much pictures of all the work I've put in to her. But you should be putting your car up here, it's a shame not to share that beauty!
Glauco
Re: 67 karmann ghia
Reply #182 on:
July 09, 2024, 11:18:36 am »
not sure where to start, so I'll just take it part by part.
first up. The DCNF's.
when I bought them they came with a set of long SCAT manifolds, and altough they are great, I really wanted purple manifolds
looks a lot better if you ask me. And I was lucky to find a paint that matches the NOS linkage perfectly (more on that later)
It took me a lot of research to find out what to do with the carbs before they are ideal for VW engines. altough most of the mods aren't nescesary, I still wanted to do my best to make them as good as I could.
a common problem is overflowing when cornering hard. A DCNF has the air vent on the inside of the lid, so when you corner hard fuel can flow directly in the bowls.
So I filled it op with Belzona
also note the ball float valve, stock they come with a needle. All the ferrari guys are changing them to ball float valve (also with there problems, but you have to chose a side...)
Last Edit: July 09, 2024, 11:21:55 am by Glauco
Glauco
Re: 67 karmann ghia
Reply #183 on:
July 09, 2024, 11:31:47 am »
because you have to have a breather for the fuel bowls I made a snorkel that comes up high enough
the butterflies came with standard nuts, witch restrict flow (very minimal, but still). needed to be addressed.
not the best picture because now they sit a little bit lower still, but you get the idea
grooved venturies made from scratch:
I wanted a special stack and designed it myself and have my brother 3D print it to test, but haven't printed them in the right material yet because I'm working on something different. I want to incorporate a variable stack length in combination with a rpm activated switch on my MSD, but it sits really low on my priority list.
The test part:
Glauco
Re: 67 karmann ghia
Reply #184 on:
July 09, 2024, 12:29:39 pm »
I also installed a choke delete kit and replaced the needles with new ones.
the lid came with a original stack, witch I had to delete
Lastly I adapted the lids to accept a AN-6 connector because my whole fuel system is already AN-equiped.
after that I fully dismantled them again and got them ultrasonically cleaned before rebuilding them with a revision kit
Glauco
Re: 67 karmann ghia
Reply #185 on:
March 16, 2025, 20:09:22 pm »
Would have hoped to be giving some bigger updates by now, but the car itself is still at the painter
Only thing I got at home at the moment is the engine and the wheels. I also have a stock front beam that just returned from powder coating ready to be assembled with some brand new Empi zero offset dropped spindles. More on that later.
The engine:
the plan is to build a 78x88 with FK8 someday. Already have most of the parts, like a old 044 performance heads, as21 case coming out of a 1 owner 50k miles 1302, engle fk8, 78mm crank and Biral 88m cylinders with slipper skirt. Not sure if I'll use the slipper skirts, but that's for later.
The engine now is still a 1641 with DIY headjob. Nicolas built it for me and it drives like a dream. Didn't need anything, but I wanted to backdate it some more to really give it the 70s vibe I'm going for.
Starting with some more DDS-goodies.
Also replaced the oil pump cover with a DDS one I got from Dem. Clyde's buggies breather made room for a gene berg breather tower.
Oil lines were black and felt that stainless with red and blue would fit it better. Engine thin is now power coated and the generator is replaced with a dynamator to complete the look
Glauco
Last Edit: March 17, 2025, 11:14:21 am by Glauco
Glauco
Re: 67 karmann ghia
Reply #186 on:
May 13, 2025, 13:53:39 pm »
wanted to be further in the process than I am today, but some things you have no control over. Car still hasn't returned from the bodyshop, but we're making progress. big step forward is the completion of the engine. Some minor details that need addressing, but for the most part it is what I envisioned.
I changed the carbs from 40IDF's to DCNF's, but for some reason they just looked to dull. So I drew up a set of stacks and Dem printed them for Me. But because I didn't want to loose the oldschool look to much I ended up painting them anodized purple like the rest of the DDS parts on my engine:
finished the oil lines as well, will be connected to the filter/cooler plate via quick disconnect fittings.
Glauco
Glauco
Re: 67 karmann ghia
Reply #187 on:
May 13, 2025, 14:02:32 pm »
Because there isn't that much to do without the car being here I ended up starting I job I didn't want to do at all, the wheels.
My Fuchs started life as cheap SSP wheels with the wrong shape and paintjob. When I first got them I did a halfass job getting the look right, but I always knew I had to redo them, now was the time.
stripped the paint and redrew all the lines to get the radius like a real Fuchs
had shaped every spoke with 180grid sandpaper until I was happy with the shape and than started sanding them down with 180, 240, 300, 400, 600, 800, 1000, 1200, 1500, 2000, 3000, 5000 and then polishing them in 5 steps
built a turning jig to sand and polish the lip as well, so that will be next. after that getting the lines right for painting.
Glauco
Glauco
Re: 67 karmann ghia
Reply #188 on:
May 13, 2025, 14:08:36 pm »
not very much to update on the body.
but now and than I get some pictures. Not as much as I want to, but you cant rush perfection I presume...
Door gaps are on point
nose grills are closed
Most of the welding I did 15 years ago are more or less OK and didn't need that much work. But there were some spots that needed redoing, now is the time.
front end and roof are in epoxy again
if all goes as planned (witch it won't) she'll get paint somewhere later this month. But again, that's something I heard a time or 2 before...
Glauco
Glauco
Re: 67 karmann ghia
Reply #189 on:
May 13, 2025, 14:10:18 pm »
some more pictures
Glauco
Re: 67 karmann ghia
Reply #190 on:
May 13, 2025, 14:13:29 pm »
more
Glauco
Re: 67 karmann ghia
Reply #191 on:
February 13, 2026, 16:00:47 pm »
I'm back, after again a long pause.
Was hoping to get the car back way sooner, but ended up collecting the car at the beginning of February.
Car is painted and back in the garage. I'll post pictures later, but going to try to keep the timeline correct.
Here she is:
in the last 2 weeks I took some time to address some problems with the suspension that needed addressing. Front beam is replaced with a NOS stock beam with new bearings and dropped spindles. Need to check if the height is OK like that or if I need to pull out a (half) leaf.
the passenger side IRS mount was crooked by 3mm, so that needed fixing as well. also had a bent koni shock, so a set of new ones is installed.
Steve67
Re: 67 karmann ghia
Reply #192 on:
February 16, 2026, 07:59:11 am »
the new colour looks great, is it Porsche bahama yellow or something else?
Last Edit: February 16, 2026, 09:50:00 am by Steve67
Glauco
Re: 67 karmann ghia
Reply #193 on:
February 16, 2026, 09:01:32 am »
Quote from: Steve67 on February 16, 2026, 07:59:11 am
the new colour looks great, is it Porsche bahama yellow ore something else?
Thanks, Porsche Bahama Yellow indeed. Was planning to go for the Porsche signal yellow (instead of the RAL-Signal Yellow I mistakenly put on 14 years ago), but ended up choosing for the Bahama Yellow instead.
Glauco
Re: 67 karmann ghia
Reply #194 on:
February 19, 2026, 11:02:35 am »
So as I said, before I could get to the fun work of putting shiny bits on, there where some minor issues that needed fixing.
rear suspension is in and ready to go.
setup as of now is:
Porsche 924/944/squareback (24.5mm) torsion bars
Porsche 944 adjustable spring plates
brand new Koni adjustable shocks (on the softest setup)
"käferbar" system
Mohr Racing transmission mount (might change the rubbers to rubbers mounted on the forks in the future)
1 inch narrowed 944 steel trailing arms (checked for straightness, because I did these 10years ago myself)
Type 3 automatic left length Sway-A-way cv-axles with brand new CV-joints
944 discs with working handbrake
944 anti-roll bar
freshly rebuilt AT-code transmission with Quiafe diff.
6
7
