October 11, 2026, 11:53:45 am
67 karmann ghia
6
7
8
Topic: 67 karmann ghia (Read 338114 times)
wolfswest
Re: 67 karmann ghia
Reply #180 on:
July 08, 2024, 21:01:04 pm »
C'mon, lot's of stuff to share Glauco. Keep us entertained please!
Glauco
Re: 67 karmann ghia
Reply #181 on:
July 09, 2024, 10:36:35 am »
Quote from: wolfswest on July 08, 2024, 21:01:04 pm
I will, but I didn't take that much pictures of all the work I've put in to her. But you should be putting your car up here, it's a shame not to share that beauty!
Glauco
Re: 67 karmann ghia
Reply #182 on:
July 09, 2024, 11:18:36 am »
not sure where to start, so I'll just take it part by part.
first up. The DCNF's.
when I bought them they came with a set of long SCAT manifolds, and altough they are great, I really wanted purple manifolds
looks a lot better if you ask me. And I was lucky to find a paint that matches the NOS linkage perfectly (more on that later)
It took me a lot of research to find out what to do with the carbs before they are ideal for VW engines. altough most of the mods aren't nescesary, I still wanted to do my best to make them as good as I could.
a common problem is overflowing when cornering hard. A DCNF has the air vent on the inside of the lid, so when you corner hard fuel can flow directly in the bowls.
So I filled it op with Belzona
also note the ball float valve, stock they come with a needle. All the ferrari guys are changing them to ball float valve (also with there problems, but you have to chose a side...)
Last Edit: July 09, 2024, 11:21:55 am by Glauco
Glauco
Re: 67 karmann ghia
Reply #183 on:
July 09, 2024, 11:31:47 am »
because you have to have a breather for the fuel bowls I made a snorkel that comes up high enough
the butterflies came with standard nuts, witch restrict flow (very minimal, but still). needed to be addressed.
not the best picture because now they sit a little bit lower still, but you get the idea
grooved venturies made from scratch:
I wanted a special stack and designed it myself and have my brother 3D print it to test, but haven't printed them in the right material yet because I'm working on something different. I want to incorporate a variable stack length in combination with a rpm activated switch on my MSD, but it sits really low on my priority list.
The test part:
Glauco
Re: 67 karmann ghia
Reply #184 on:
July 09, 2024, 12:29:39 pm »
I also installed a choke delete kit and replaced the needles with new ones.
the lid came with a original stack, witch I had to delete
Lastly I adapted the lids to accept a AN-6 connector because my whole fuel system is already AN-equiped.
after that I fully dismantled them again and got them ultrasonically cleaned before rebuilding them with a revision kit
Glauco
Re: 67 karmann ghia
Reply #185 on:
March 16, 2025, 20:09:22 pm »
Would have hoped to be giving some bigger updates by now, but the car itself is still at the painter
Only thing I got at home at the moment is the engine and the wheels. I also have a stock front beam that just returned from powder coating ready to be assembled with some brand new Empi zero offset dropped spindles. More on that later.
The engine:
the plan is to build a 78x88 with FK8 someday. Already have most of the parts, like a old 044 performance heads, as21 case coming out of a 1 owner 50k miles 1302, engle fk8, 78mm crank and Biral 88m cylinders with slipper skirt. Not sure if I'll use the slipper skirts, but that's for later.
The engine now is still a 1641 with DIY headjob. Nicolas built it for me and it drives like a dream. Didn't need anything, but I wanted to backdate it some more to really give it the 70s vibe I'm going for.
Starting with some more DDS-goodies.
Also replaced the oil pump cover with a DDS one I got from Dem. Clyde's buggies breather made room for a gene berg breather tower.
Oil lines were black and felt that stainless with red and blue would fit it better. Engine thin is now power coated and the generator is replaced with a dynamator to complete the look
Glauco
Last Edit: March 17, 2025, 11:14:21 am by Glauco
Glauco
Re: 67 karmann ghia
Reply #186 on:
May 13, 2025, 13:53:39 pm »
wanted to be further in the process than I am today, but some things you have no control over. Car still hasn't returned from the bodyshop, but we're making progress. big step forward is the completion of the engine. Some minor details that need addressing, but for the most part it is what I envisioned.
I changed the carbs from 40IDF's to DCNF's, but for some reason they just looked to dull. So I drew up a set of stacks and Dem printed them for Me. But because I didn't want to loose the oldschool look to much I ended up painting them anodized purple like the rest of the DDS parts on my engine:
finished the oil lines as well, will be connected to the filter/cooler plate via quick disconnect fittings.
Glauco
Glauco
Re: 67 karmann ghia
Reply #187 on:
May 13, 2025, 14:02:32 pm »
Because there isn't that much to do without the car being here I ended up starting I job I didn't want to do at all, the wheels.
My Fuchs started life as cheap SSP wheels with the wrong shape and paintjob. When I first got them I did a halfass job getting the look right, but I always knew I had to redo them, now was the time.
stripped the paint and redrew all the lines to get the radius like a real Fuchs
had shaped every spoke with 180grid sandpaper until I was happy with the shape and than started sanding them down with 180, 240, 300, 400, 600, 800, 1000, 1200, 1500, 2000, 3000, 5000 and then polishing them in 5 steps
built a turning jig to sand and polish the lip as well, so that will be next. after that getting the lines right for painting.
Glauco
Glauco
Re: 67 karmann ghia
Reply #188 on:
May 13, 2025, 14:08:36 pm »
not very much to update on the body.
but now and than I get some pictures. Not as much as I want to, but you cant rush perfection I presume...
Door gaps are on point
nose grills are closed
Most of the welding I did 15 years ago are more or less OK and didn't need that much work. But there were some spots that needed redoing, now is the time.
front end and roof are in epoxy again
if all goes as planned (witch it won't) she'll get paint somewhere later this month. But again, that's something I heard a time or 2 before...
Glauco
Glauco
Re: 67 karmann ghia
Reply #189 on:
May 13, 2025, 14:10:18 pm »
some more pictures
Glauco
Re: 67 karmann ghia
Reply #190 on:
May 13, 2025, 14:13:29 pm »
more
Glauco
Re: 67 karmann ghia
Reply #191 on:
February 13, 2026, 16:00:47 pm »
I'm back, after again a long pause.
Was hoping to get the car back way sooner, but ended up collecting the car at the beginning of February.
Car is painted and back in the garage. I'll post pictures later, but going to try to keep the timeline correct.
Here she is:
in the last 2 weeks I took some time to address some problems with the suspension that needed addressing. Front beam is replaced with a NOS stock beam with new bearings and dropped spindles. Need to check if the height is OK like that or if I need to pull out a (half) leaf.
the passenger side IRS mount was crooked by 3mm, so that needed fixing as well. also had a bent koni shock, so a set of new ones is installed.
Steve67
Re: 67 karmann ghia
Reply #192 on:
February 16, 2026, 07:59:11 am »
the new colour looks great, is it Porsche bahama yellow or something else?
Last Edit: February 16, 2026, 09:50:00 am by Steve67
Glauco
Re: 67 karmann ghia
Reply #193 on:
February 16, 2026, 09:01:32 am »
Quote from: Steve67 on February 16, 2026, 07:59:11 am
the new colour looks great, is it Porsche bahama yellow ore something else?
Thanks, Porsche Bahama Yellow indeed. Was planning to go for the Porsche signal yellow (instead of the RAL-Signal Yellow I mistakenly put on 14 years ago), but ended up choosing for the Bahama Yellow instead.
Glauco
Re: 67 karmann ghia
Reply #194 on:
February 19, 2026, 11:02:35 am »
So as I said, before I could get to the fun work of putting shiny bits on, there where some minor issues that needed fixing.
rear suspension is in and ready to go.
setup as of now is:
Porsche 924/944/squareback (24.5mm) torsion bars
Porsche 944 adjustable spring plates
brand new Koni adjustable shocks (on the softest setup)
"käferbar" system
Mohr Racing transmission mount (might change the rubbers to rubbers mounted on the forks in the future)
1 inch narrowed 944 steel trailing arms (checked for straightness, because I did these 10years ago myself)
Type 3 automatic left length Sway-A-way cv-axles with brand new CV-joints
944 discs with working handbrake
944 anti-roll bar
freshly rebuilt AT-code transmission with Quiafe diff.
Re: 67 karmann ghia
Reply #195 on:
March 03, 2026, 18:25:52 pm »
keep up the good work. anxious to see how it will come out.
Re: 67 karmann ghia
Reply #196 on:
March 04, 2026, 07:05:49 am »
Nice,
Do you have some pictures mounting the adjustable springplates?
Regards eddie
Glauco
Re: 67 karmann ghia
Reply #197 on:
March 04, 2026, 09:30:00 am »
Quote from: Eddie DVK on March 04, 2026, 07:05:49 am
Nice,
Regards eddie
I can post some pictures, but once you get the Porsche bushings off they fit exactly like stock vw's. they have the same overall dimensions. the benefit of Porsche spring plates over aftermarket ones is that you can't see they're adjustable, interesting in Belgium for MOT...
I have a second set on the shelve, I'll take pictures tonight.
Glauco
Re: 67 karmann ghia
Reply #198 on:
March 04, 2026, 12:12:45 pm »
I have them to, but what did you do to get them fit. Put a ring behind it or did you grind the frame a bit.
Glauco
Re: 67 karmann ghia
Reply #199 on:
March 04, 2026, 13:44:49 pm »
Quote from: Eddie DVK on March 04, 2026, 12:12:45 pm
If I remember correctly (did this 10 years ago) I did clearance the shock towers a little and shaved a little of the eccentric bolt. I also shortened the 2 bolts that lock the 2 plates together to clear the tires.
To adjust the height I made a special wrench that fits between the chassis and the spring plate. originally I used the 944 spring plate caps, but later switched to 181 caps. they look stock but beefier and clear the housing.
Glauco
Re: 67 karmann ghia
Reply #200 on:
March 05, 2026, 07:05:41 am »
Thanks, that is the information I want to know.
The new colour is spot on.
Regards Eddie
Glauco
Re: 67 karmann ghia
Reply #201 on:
March 05, 2026, 09:37:19 am »
Quote from: Eddie DVK on March 05, 2026, 07:05:41 am
Regards Eddie
My pleasure. And thank you
Glauco
Glauco
Re: 67 karmann ghia
Reply #202 on:
July 06, 2026, 13:02:38 pm »
where to start since the last update..?
I really wanted to go to EBI with the car so the last few weeks should have been filled with KG-madness. Sadly my dad past away a few weeks ago so I had lost the courage for a few weeks to do anything on the car.
because of all the work my dad and I put into the car, the only right thing to do was to get it done asap. In a way the car helped me cope with the los.
Long story short, I made it to EBI, had a very fun weekend and got some cool compliments.
But for me there are some major hurdles to be taken in the next few weeks to get the car to where I can be extra proud.
friday morning the car had 15km's on it before the departure to chimay, witch is about 200km from my house.
despite it using 20l/100km and leaked oil from what I think is the crank case seal, the car performed flawlessly.
there is a slight colour difference on the front hood and rear valance that need to be addressed by the painter asap, but nothing that can't be fixed.
some moneyshots:
migier
Re: 67 karmann ghia
Reply #203 on:
July 07, 2026, 08:36:00 am »
Congrats Glauco!!
The KG really looks great !!
WünderWaffe Automobile Klub
Re: 67 karmann ghia
Reply #204 on:
July 08, 2026, 06:51:36 am »
Have been looking at your car at EBI, it looked really great.
Glauco
Re: 67 karmann ghia
Reply #205 on:
July 08, 2026, 09:10:56 am »
Quote from: migier on July 07, 2026, 08:36:00 am
Congrats Glauco!!
Quote from: Eddie DVK on July 08, 2026, 06:51:36 am
thanks! I'm very happy with the outcome, but like I said, there are some things to do now.
- First thing is finding the oil leak and fixing it. I'm afraid it's coming from the main seal, so might have to pull the engine out again.
- Also need to adjust the carbs, it's using to much fuel, way to much
- If the engine is coming out I might as well take it to Nicolas (weirs) to get it finetuned and be ready for many miles to come
- Handbrake release came loose, need to fix that
- car is going straight, but could do with an alignment.
- also the interior needs finishing, I used the inserts of my old seats but they are the wrong shape, so that's something I'll take on in the next few weeks.
Thank you Fabian for the cool pictures
Re: 67 karmann ghia
Reply #206 on:
July 08, 2026, 17:58:07 pm »
Well done for getting it finished enough to make it to EBi
, many people would have given up with everything you had to deal with recently so good job
Glauco
Re: 67 karmann ghia
Reply #207 on:
July 09, 2026, 08:22:29 am »
Quote from: richie on July 08, 2026, 17:58:07 pm
thanks Richie!
Glauco
Re: 67 karmann ghia
Reply #208 on:
July 09, 2026, 08:32:02 am »
OK, yesterday was the first day I felt like tackling some hurdles.
First thing that needed to be fixed was the oil leek. My first assumption was that it was coming from the crank seal. But this is a new one, so I had my doubts.
Then it accrued to me that I deleted the doghouse oil cooler with a bypass plate. So I started with checking the doghouse cooler bypass plate first.
Turns out the top of the engine was covered with oil so my guess was right.
checked the plate and it was completely crooked.
after an hour of flat sanding it came out a lot better
mounted it with (again) new rubbers hoping the problem is fixed.
Glauco
Re: 67 karmann ghia
Reply #209 on:
July 15, 2026, 09:24:09 am »
productive couple of days. Handbrake lever wasn't working like I wanted, so needed to be addressed.
I really wanted to keep the chrome lever, I already put a stock vw mechanism inside to make it function better, last part to tackle was the tensioning mechanism. I cut of the part of a stock lever and replaced the bracket on the chrome lever with die stock one. Cable length is a little bit to long because I made the adapter a little bit too short, might change that if it ever is troubling...
with the rubber mounted (after I check if the handbrake works OK) you will never see the difference, but for me it as important to have it right...
Also mounted new cables as it was the only part left untouched on the entire brake system. 25 year old me couldn't care less for new handbrake cables costing 30euros or so.
used the original clips to keep them in place. Wasn't sure it was going to work with the Porsche to vw adapter, but it turned out great.
Last Edit: July 15, 2026, 09:26:58 am by Glauco
6
7
8
