September 21, 2026, 09:49:23 am
Bad Habit
Deburring all sharp and rough edges on inside engine case?
Topic: Deburring all sharp and rough edges on inside engine case? (Read 6372 times)
January 13, 2011, 02:12:35 am »
Good idea or waste of time ?
Frenchy Dehoux
Re: Deburring all sharp and rough edges on inside engine case?
January 13, 2011, 04:55:21 am »
When I build motors I always look for sharp edges and round them off and polish other areas to keep the oil to flow back. Also check the lifter bores to make sure they do not have too much play side to side. And many other area prior to assembly
Frenchy
Last Edit: January 13, 2011, 16:36:31 pm by Frenchy Dehoux
Doctor Detail ( Retired )
Dominick Luppino
January 13, 2011, 16:19:58 pm »
Great idea! Gee how long have you been playing with VWs
January 13, 2011, 16:50:49 pm »
Doing it for the last 2 weeks. Rough edges, casting flash etc. On the flywheelside i found that the bottom 3/8 plug almost fell out due to
Had to tap to M18 x 1.5 before i actally had solid meat to hold the bolt... (This is a new mag case).
January 13, 2011, 18:19:57 pm »
Did that to my case last week. Check this thread for more:
http://cal-look.no/lounge/index.php/topic,8007.0.html
January 13, 2011, 20:30:49 pm »
Quote from: Dominick Luppino on January 13, 2011, 16:19:58 pm
I am just a old body man Dominick ! Still trying to learn. Hell you have probably forgot more about vw motors than I know.
January 13, 2011, 20:55:44 pm »
Quote from: Zach Gomulka on January 13, 2011, 18:19:57 pm
Thanks zack! I forgot that post and thanks to ALL that posted the pictures and great info.
Fasterbrit
January 13, 2011, 22:54:41 pm »
Deburring a case to remove sharp machined edges is a must. Sharp edges are stress risers that promote cracking. I have just pulled appart a low mileage mag case that has been bored and stroked without any attention to sharp edges and the bearing saddle at no 1 main has two hairline cracks about half an inch long each. Not good!
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
