September 22, 2026, 12:00:43 pm
| | |-+  Diederick's '67
Pages: 1 ... 8 9 [10] 11 12 ... 14 Print
Author Topic: Diederick's '67  (Read 255298 times)
« Reply #270 on: May 13, 2009, 23:41:17 pm »
you gotta wait and see, dude Wink
oh, i guess you mean lots of 'bikkelen'?
« Reply #271 on: May 14, 2009, 22:37:20 pm »
alright, i got to work on the front beam like a true monkey would Wink
big ass hamer and a chisel as well as a dremel tool did the job. the pitman arm ended up a bit higher so i'll probably have to have my front wheels aligned again... too bad i apparently damaged the thread of one of the joints on trailer arms, can't get the nut on. so i'll have to renew that one i guess... Sad
also got to work on the dash, it took some cutting but this is the general idea.
a few of my gauges plus a little bit of the 70ies cassette radio Grin
i didn't really want show, but it's nice to see i'm at least doing something.
p.s. the tachometer looks to be lower, but that's because i haven't finished cutting the speedo hole. it's actually still sticking out  Tongue
« Last Edit: May 14, 2009, 23:03:50 pm by 67-indeed/DVK » Logged
« Reply #272 on: May 16, 2009, 17:57:49 pm »
getting closer to a finished front end.
« Reply #273 on: May 16, 2009, 18:57:35 pm »
where are those turn signal houses Huh to the painter  Roll Eyes Roll Eyes to have a java green  coat   Roll Eyes Roll Eyes............. Grin Grin
« Reply #274 on: May 16, 2009, 19:40:07 pm »
i felt like taking stuff apart... Cheesy
Wink
well, if you're looking at such a detail you might notice even the doors are missing?? Wink
« Reply #275 on: May 16, 2009, 19:45:45 pm »
Wink
to dark  Grin Grin
Jesse/DVK
'64 2176cc
« Reply #276 on: May 17, 2009, 21:19:11 pm »
Nice work today dude Smiley.
« Reply #277 on: June 17, 2009, 17:35:37 pm »
i'm installing my CB rear disc brakes at the moment and i've got one issue with the axle nut:
with the disc installed i torque the axle nut to 250 ft/lbs and the disc is then stuck! no movement possible, not even if i put a wheel on and try to spin it... after that didn't work, well i'm sure i should be able to turn the torqued disc just like a drum, i tried doing it by hand: 47 ft/lbs (650 kg/cm) made it very difficult to turn but i could put the pin in and the next step, next hole for the cotter pin meant torquing the axle nut at about 14ft/lbs (200 kg/cm)
now it feels pretty good, i can tighten it more by hand which is a weird idea, but at least i can spin the disc. i doesn't have any sideplay really and i can get the cotter pin in. but it doesn't seems weird hardly having it torqued...
but wouldn't i mess up the bearing if i overtighten it?
i'm talking about the CB 5x130 rear disc kit - ROTO HUB with parking brakes:
http://cbperformance.com/catalog.asp?ProductID=714
« Reply #278 on: June 17, 2009, 19:28:13 pm »
does anyone know? i put the wheel on and apart from looking sweet n slick it feels just like the stock wheel on the left rear side which is still attached to the original drum...
« Reply #279 on: June 18, 2009, 00:03:50 am »
Did you put the spacer that comes in the kit in the bearing cap?
« Reply #280 on: June 18, 2009, 08:00:19 am »
hi gary, thanks for responding.
no, they didn't ship me a spacer. they told me at CB that i should've come in a bubble wrap pack. but ones i told them which parts i have, they said i have all parts.
but, the spacer should go between the disc and axle nut and as you can see from the second image the thread looks find and doesn't need to be spaced out.
i didn't install the first washer and o-ring behind the stock spacer. when i took of the bearing seal retainer cap, the gearbox oil flooded the place so i quickly grabbed the bracket, large o-ring, paper gasket, retainer shim, axle seal and bearing cap. i can't remember finding a stock oil deflector!! is that made of rubber?
it makes sense that the axle needs to be spaced out under the bearing cap as the disc is now pushed in too far and ends up stuck. please let me know if you have any suggestions!
« Reply #281 on: June 18, 2009, 17:33:40 pm »
Hi Diederick did you install this spacer shim behind the bearing cap? it is used because the Caliper Bracket is thicker then the backing plate, without it being installed when you tighten the axle nut it will pull the axle and bearing outward and can make it bind and not turn the spacer is designed to keep force the bearing into the axle tube seat. hope this helps the shim in red needs to be installed it comes in the CB Brake Kit.
« Last Edit: June 18, 2009, 17:36:30 pm by Shubee2 (DSK) » Logged
« Reply #282 on: June 18, 2009, 18:08:19 pm »
yes i did gary. but thanks for noting Smiley
i sent the rotors out to get machined. when you look at the back side, there is a flange or hub that goes over the axle shaft. on the outside of that shaft there was 5mm length/clearance until it ran into the reinforcement of the back side etc. I measured the distance from the oil deflector to the bearing cap and it was 7.5mm. So I'm having my rotors turned down to 8mm and I'll get them back tomorrow. this way the back side of the rotor will turn out a bit more like the old drum.
i hope you understand Wink
« Reply #283 on: June 18, 2009, 20:39:27 pm »
Dude glad to see the car coming along but I have mentioned my thoughts on CB brakes before  Roll Eyes They are RUBBISH!!!!!!!!!!!!!!!! They never fit properly  Angry I have just had a load of trouble with their dropped spindles - My friend brought some disc brake dropped spindles and I tried fitting the calipers and gues what - Thats right they didn't fit  Roll Eyes The "bosses" where the two bolts go were approx 3mm thicker than stock VW items meaning the caliper was over to one side! so off to the machine shop again - my advice don't use CB brakes!
« Reply #284 on: June 19, 2009, 16:45:19 pm »
I picked up the rotors today, they were cut more than I asked but they fit great. Got a caliper on, even though they supply shims with the kit I didn't need to. If I did the caliper would hit the disc. But they fit fine! You can hear the pad "sand" the disc when I spin the wheel, but I guess that's because I haven't connected the hoses yet. My old brake lines where hardline and I had to cut them to remove the discs, so I'll get some nice new hoses.
« Reply #285 on: July 29, 2009, 14:01:57 pm »
still in progress
hardly any time to finish it lately, hence the delay.
« Reply #286 on: July 29, 2009, 14:10:20 pm »
 Shocked Shocked , very nice progress and look very good  Cool
« Reply #287 on: July 29, 2009, 14:35:09 pm »
thanks fabs, i still have some jobs to do. including replacing more trim parts with black and swapping my window rubbers. etc.
just need some frickin time  Undecided
enfin, merci  Grin
« Reply #288 on: July 29, 2009, 14:46:10 pm »
Did you get all the Gauges Wired up? I noticed you have the fuel and volt where the press and temp were going?
« Reply #289 on: July 29, 2009, 15:02:48 pm »
still in progress
Now that looks a little better  Wink Smiley
« Reply #290 on: July 29, 2009, 15:17:46 pm »
cheers dude, i've got some more tricks up my sleeve too  Grin
will post more when i'm done.
on the gauges; i have to replace my trailer harness because of the thickness of the wires but i found a nice one which i'll buy this saturday. tape it to the old one and pull it through the car. then i can hook up the gauges. yes, i didn't fit the oil gauges yet as there is no need for those just yet. and i've got some crazy idea on where to mount the other gauges, but i'll have to contemplate on it very well before i will... Smiley
but i'm hoping to take it to at least one show this summer  Roll Eyes
then, i can quietly take it back in and start on the interior revamp and horsepower  Cool
Trond Dahl
« Reply #291 on: July 29, 2009, 15:42:26 pm »
Nice details Diedrick, the wheels came out reallly nice! Like the instruments also! Car looks really good
Race car 9.49/236kmt@SCC 2017
« Reply #292 on: July 29, 2009, 16:00:05 pm »
What a difference!
« Reply #293 on: July 29, 2009, 16:08:59 pm »
thanks guys, this really motivates me to get a lot done this saturday - that is if i'm not too hung over :-P
and zach, i do have some interior/upholstery queries i need to contact you about at some point  Wink
p.s. if anyone has some cool BLACK frames of that same size please let me know. these don't quite fit the theme anymore .
« Reply #294 on: July 29, 2009, 16:16:47 pm »
I already told you Died's... just say no to TMI  Wink Grin
I'd be glad to help!
« Reply #295 on: July 29, 2009, 17:32:31 pm »
is it done yet?  Grin
from what i can see it looks all good.
Dave Rosique
nobodyouno
« Reply #296 on: July 29, 2009, 17:43:48 pm »
looks good Died!!
The wheels look really nice.
~DR.
« Reply #297 on: July 29, 2009, 20:02:53 pm »
Way cool Died,the "fuch's" are lookin' good and those gauges too.
And I love the painted headlightrings.
job well done.  Wink
« Reply #298 on: July 30, 2009, 14:32:13 pm »
I have a pair of Plate frame for yathat Mr Rosique might just recognise  Wink They will look awsome
Ps it just needs one piece windows, a black hood handle and remove the rest of the window trims  Wink Smiley
« Reply #299 on: July 30, 2009, 14:34:56 pm »
i will do the latter 2. but one piece windows scare me off...
black hood handle, hood trim, logo, wipers, vent wings etc are all waiting to be bolted on. i'll have another go this saturday.  Grin
let me know about those plate frames dude. if you could measure them for me... my plates are 15cmx30cm
thanks so much for the kind words everyone  Smiley
« Last Edit: July 30, 2009, 14:42:27 pm by 67-indeed/DVK » Logged
