September 24, 2026, 05:00:20 am
12mm plugs
Topic: 12mm plugs (Read 9959 times)
Matty c
12mm plugs
April 16, 2011, 10:16:32 am »
Hi fellas, does anyone know the best 12mm spark plugs to use with a scintilla mag?
Uncle Keith
Thanks, Matty
67heaven
Matty c
Re: 12mm plugs
April 16, 2011, 12:10:50 pm »
I forgot to mention it's a 2110, fk87, ida's, 10:1 c/r
Thanks, matty
67heaven
Re: 12mm plugs
April 16, 2011, 14:06:09 pm »
3/4" reach?
Matty c
Re: 12mm plugs
April 16, 2011, 14:33:15 pm »
Indeed it is sir.
Thanks, Matty.
67heaven
Joel Mohr
Re: 12mm plugs
April 16, 2011, 15:47:19 pm »
NGK d8EA
SEE YA AT THE RACES!!!
Re: 12mm plugs
April 16, 2011, 15:52:57 pm »
Agreed!
Here are two useful web resources regarding NGK plug specifications s and crossreferencing with other makes:
http://www.spark-plugs.co.uk/pages/technical/x-ref.htm
www.ngksparkplugs.com/techinfo/spark_plugs/partnumberkey.pdf
rick m
Re: 12mm plugs
April 16, 2011, 16:15:03 pm »
Running NGK D8's in my new motor as well. If you are using any of the CB heads that are CNC Ported, be sure to check the spark plug depth before assembling the motor. I had to use a .060 spacer under the spark plug to get it where it is supposed to sit. Someone apparently did not get the CNC setting correct for spark plug depth. I have friends here in Arizona that have a shop and caught the problem. I am sure it was on a limited run of heads until they were notified but be safe and check your heads before running your engine.
Rick M
Rick Mortensen
Driving Hot VWs since 1970
Matty c
Re: 12mm plugs
April 16, 2011, 16:45:43 pm »
Thanks everyone, as luck would have it I have a new set of d8ea's in my toolbox! What were the chances
Matty
67heaven
Re: 12mm plugs
April 16, 2011, 19:13:02 pm »
If you run a radio/stereo in your car, you may want to consider running spiral wound wires and resistor plugs to cut down on the interference that may occur.
NGK DR8ES would be the resistor option.
TxT
bilboa2
Re: 12mm plugs
April 17, 2011, 00:09:59 am »
why are my(44x37.5) 044's d7ea ? lower #, hotter plug ? colder # higher, champion opposite ? feed a fever, starve a cold, ?
Ron Greiner
DKP II
Re: 12mm plugs
April 17, 2011, 02:24:24 am »
iBill, The 7 is hotter then the 8's I used to run the D7EA plugs in my 2084 cc motor, you shouldn't need that cold of a plug (D8EA) for a street motor
Last Edit: April 17, 2011, 02:26:04 am by Ron Greiner
RhoadsVW
Re: 12mm plugs
April 17, 2011, 02:33:34 am »
I always ran the D7EA NGK plugs. Never a problem. The D8EA in a streert car will have a problem fouling sometimes. Dave Rhoads
Der Renwagen Fuhrers
Dominick Luppino
Re: 12mm plugs
April 17, 2011, 03:06:35 am »
Quote from: RhoadsVW on April 17, 2011, 02:33:34 am
I have been using D8EA plugs on the street for years with no problems...
Matty c
Re: 12mm plugs
April 17, 2011, 10:07:19 am »
Thanks again guys for your input, as I have a spare set of d8ea I will go with them, if I have a problem of fouling I'll try something else.
How about gap, what do you recommend
Thanks again, Matty
67heaven
Re: 12mm plugs
April 17, 2011, 12:36:26 pm »
Matty,
The mags like a tight gap, try .020" to .022".
TxT
Matty c
Re: 12mm plugs
April 17, 2011, 16:36:16 pm »
Thanks Tom
67heaven
bilboa2
Re: 12mm plugs
April 17, 2011, 17:03:47 pm »
joel mohr, what's the story on the triple electrode choice and the hp gain? ... oops , top secret ? going to fallon and finally vac, clean, wax, get ready for uph shop appointement for carpet. Might go to top gun raceway this afternoon if doug has ken's car ready for test and tune. Finally get to drive my car without it cutting out a 4800,felt great but thought it was wires through the firewall, ground, then ken leaves a sticky note that says to to doug, there is an adjustment screw on top of dist for the REV LIMITER...oops, we had dynoed it with a different fan shroud but same style computronix init and remembered to adjust. Maybe will take a high rpm plug ck, and take a pic and show it..? bill
