September 23, 2026, 01:17:37 am
| | |-+  Glove box ideas?
Author Topic: Glove box ideas?  (Read 4378 times)
youngnstudly
« on: May 18, 2011, 06:04:02 am »
I am installing a couple airplane gauges inside of my glove box (actually I am replacing the glove box with a panel I made) and my original plan was to install 3 gauges...but I soon realized I couldn't see the last gauge due to the distance from the drivers seat to the end of the glove box. I need some ideas of how I can "fill the void". My backup plan is to either place an emblem of some sort in the "empty" space, install a light (shown in pic) with a few toggle switches, or just  some toggle switches (I'm thinking 6 total, 3 in a row and 3 more below the first 3). My only problem with installing the  toggle switches is I had other plans for locating them elsewhere, and I feel like the light is sort of a cheap looking accessory that I don't need (or do I?). I still haven't figured out if I will paint this panel in satin black or use the same dark gray (charcoal) vinyl that I am using for my carpet binding. Paint will scratch and nick, and the vinyl can be wiped off easy with a little vinyl dressing. Ideas? Thanks!  Smiley
-Andy
I know the stainless trim rings aren't "clocked" correctly, but I just threw the parts together to give you guys an idea of what I have so far
« Reply #1 on: May 18, 2011, 07:55:31 am »
Here is a pic of my gages in my glove box. The 3-gage pod you can buy. And they are slightly angled toward the driver for easy seeing. Works for me! Something to think about. I think I saw a 4 gage pod on there website.
Ted
71CALRIPPER
« Reply #2 on: May 18, 2011, 08:06:24 am »
Ted
Now that is Smart !!
youngnstudly
« Reply #3 on: May 18, 2011, 17:18:43 pm »
Ted, I thought about using those but I have square gauges first of all, secondly I wanted something that was a little different (a more original idea). I can see both of the gauges perfectly as it sits, but the third gauge was the problem so I welded the hole up and now I have a empty spot. I'll probably just put the toggle switches in that area. Thanks for the reply.
Andy
