October 13, 2026, 04:38:18 am
| | |-+  WHERE DID YOU MOUNT YOUR COIL????????????????????????
Pages: [1] 2 Print
Author Topic: WHERE DID YOU MOUNT YOUR COIL????????????????????????  (Read 18309 times)
65bug
« on: May 26, 2011, 23:30:42 pm »
Hey guys,
       Ok, so I am almost ready to mount my Bosch Blue Coil. I really like my open space now with no air ducts on my shroud! Where do you guys think I should mount my coil? Where did you mount YOUR coil. Pics would be awesome! Here's a pic of mine!
« Reply #1 on: May 27, 2011, 00:40:21 am »
Coil? COIL? We don't need Coils!
MAGS don't need no stinking COILS! LMAO
« Last Edit: May 27, 2011, 16:04:58 pm by TexasTom » Logged
65bug
« Reply #2 on: May 27, 2011, 01:07:27 am »
LOL, alright you wise guy! But I run a Mallory Unilite and I love it. MAGS.........................MAGS?HuhHuhHuh?...........................WE DONT NEED NO STINKIN MAGS................................ THIS IS THE YEAR 2011!!!!!
           Tongue Tongue Tongue Grin Cheesy Wink
glenn
« Reply #3 on: May 27, 2011, 01:21:48 am »
Stock location.
Glenn
www.DasVolks.com
Long Island's Aircooled Club
« Reply #4 on: May 27, 2011, 01:23:57 am »
Run a wire through firewall and mount behind rear seat.
« Reply #5 on: May 27, 2011, 02:22:31 am »
Case mount. Made my own.
youngnstudly
« Reply #6 on: May 27, 2011, 02:39:40 am »
Same here. This pic is after I fully shaped and polished the bracket.
This is the rough cut of my bracket after adding the helicoils and hot rod drilling it.
I like this idea also though! I don't know where you can get a longer coil (spark plug) wire by itself, but I do know that you can get a firewall "bulkhead" mount for going through the firewall. It's a slick deal when done correctly IMO.
-Andy
« Reply #7 on: May 27, 2011, 03:11:38 am »
Buy a set of plug wire's from someplace like summit raceing and get a set of wire for a V6 and cut them to length
65bug
« Reply #8 on: May 27, 2011, 03:17:19 am »
See TT, lots of us still use coils Shocked Shocked Tongue Thanks for the input and pics!!!! Hmmmm, still trying to decide here! I got alot of wires that will need to be streeetched to reach the coil!
      I like that top o' shroud mount too!
« Reply #9 on: May 27, 2011, 03:25:59 am »
65,
What type of linkage will  you use?
If you absolutely REFUSE to run a MAG, the case maount behind the dist. are what I normally prefer.
They can be fabbed out of sheet metal or aluminium as shown above. I ran one once on the backside of a 'CatHouse' fan shroud ...
I like to keep the coil inside the engine compartment, just in case testing is in order ... you never know ... call me a pessimist, but it happens!
MAGS? No I've NEVER had a problem with THEM! LMAO  Grin Wink
TxT
« Reply #10 on: May 27, 2011, 03:48:15 am »
Another Idea is to weld a tube on both side's of fan shroud and run wire through it and mount coil on back side of shroud? Just a idea !
« Reply #11 on: May 27, 2011, 03:54:16 am »
Danny,
How about mounting it inside the fresh air outlet section of the shroud ... like on a Thing piece, since it doesn't have the outlets ... all you would see is the top with the connections sticking out.
Could it be done? I think so ... It'd be clean.
TxT
« Reply #12 on: May 27, 2011, 03:58:47 am »
Splan lucy ? Dont understand?
« Reply #13 on: May 27, 2011, 03:59:36 am »
My weed googles are foggy !!
65bug
« Reply #14 on: May 27, 2011, 04:02:41 am »
Thanks you guys! Those are some cool ideas Danny! Tom, my linkage is the dreaded Cb hex bar linkage! I "MAY" go and buy the CSP centerpull linkage. That's what I really wanted. However, I hate to waste what I have right now. I am trying to finish up my room addition on my house Roll Eyes
     If I go the cb then I guess anywhere is possible. With the CSP right above the case may be a no go. Not sure yet. Still trying to decide....... My coil wire is a good length, so I can get a little creative. I just wanted some room up front this time for my big hands!
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #15 on: May 27, 2011, 04:23:35 am »
 Mines mounted right here with these two button heads
  Here it is from the bottom,
65bug
« Reply #16 on: May 27, 2011, 04:30:51 am »
Jason,
        WOW! Thanks for the photos there! Very nice spot indeed! IT looks way out of the way there!
kingsburgphil
« Reply #17 on: May 27, 2011, 05:01:33 am »
In the interim, I mounted the MSD coil close and vertical. Future plans will have it mounted on the interior parcel tray. With the coil wire
going thru a grommet on the firewall and a AN bulkhead fitting thru the fan housing.
Russell
« Reply #18 on: May 27, 2011, 08:49:55 am »
If your building a proper cal look car as Txt say Use a mag, far cooler than a big red thing......., if not a stock black Bosch coil in normal place
Best Regards
Russell
Martin
Cash Converter....
« Reply #19 on: May 27, 2011, 08:52:20 am »
i love my mag....... Wink
Martin
www.taylormachine.co.uk
OFF/500
« Reply #20 on: May 27, 2011, 08:54:22 am »
Wish I had a mag – anyone want to swap a Vertex with matching tach for my MSD 6-AL digital set-up + tach?
Martin
Cash Converter....
« Reply #21 on: May 27, 2011, 08:55:46 am »
Nope....... Tongue
lol
Martin
OFF/500
« Reply #22 on: May 27, 2011, 09:28:36 am »
I didn't bother reading the entire thread... but you should consider running a mag!
 Wink
181
« Reply #23 on: May 27, 2011, 09:53:55 am »
I like stock..
vaughn bros
« Reply #24 on: May 27, 2011, 10:00:32 am »
Mine is a quick and dirty.
« Reply #25 on: May 27, 2011, 12:27:17 pm »
Spare piece of hardware store angle aluminum worked for me. Just don't over tighten ... squish. oops!
HEY! Who are you calling a buttonhead???  Lips Sealed
65bug
« Reply #26 on: May 27, 2011, 15:03:48 pm »
Wow! Thanks for all the feedback and pics! Very cool! There are some awesome motors! When I built my first 2165 motor I was not too worried about how it looked. This tiime I want it to look cleaner!
       Well, I did not know that a original cal-look car has to have a mag or black coil. Even though I grew up and am a cal. native. My first cal-look bug was a 59 rag top in 1981.
       Do you think my original black 1965 cal. plates will make up for the red distributor? Grin Wink
« Reply #27 on: May 27, 2011, 16:36:43 pm »
 Grin
65bug
« Reply #28 on: May 27, 2011, 22:23:09 pm »
Speedwell,
    WOW! That is "OFF THE HOOK" Cheesy Cheesy [ Attachment: You are not allowed to view attachments ] like the kids in the neighborhood say! Alright, I made my decision. Please let me know what you guys think!
Thanks              PS  I am off to get a plug!
« Reply #29 on: May 27, 2011, 23:56:29 pm »
That's cute, but I'd have gone with a Mag ...  Wink LOL
Pages: [1] 2 Print
