June 10, 2026, 04:07:06 am
Latest Member: mvptkfjb
| | |-+  What spare wheel ?
Author Topic: What spare wheel ?  (Read 16252 times)
Straight Time
« on: June 10, 2011, 22:18:04 pm »
Just wondering what spare wheels everyone is running ? The size of wheel and tyre combo.
I have oem Gas burners but no spare wheel . Keeping in mind we probably all have skinny fronts wide rears , what is a good compromise in tyre size for a spare ?
obviously not too big as needs to fit the wheel well.
Just curious before I go and buy one.  Cool
No retreat, No surrender !
normac67
« Reply #1 on: June 10, 2011, 23:31:29 pm »
  I have a 145SR Michelin mounted on my Flat-Four BRM. I can run it on the front or the back if I have to.
        Norris
« Reply #2 on: June 11, 2011, 02:22:54 am »
I have a steel 5-lug Porsche wheel and 155 tire. 5.5" rim. I put the hubcap on so it looks cool.
« Reply #3 on: June 11, 2011, 03:16:28 am »
Spare? ... SPARE? We don't need no stinking SPARE.
 Grin
« Reply #4 on: June 11, 2011, 05:18:55 am »
Straight Time, you can either get another Gasburner wheel and mount a 145 or whatever size your front tires are. Or, use a steel wheel with the right lug pattern (don't know if yours is four or five lug). I'm in the process of doing the steel wheel option for my car.
« Reply #5 on: June 11, 2011, 05:51:57 am »
I have a 155R 15 on a Flat-4 BRM.  I have only used it twice, but it sure came in handy.  Once on the back and once on the front.  It got me home and it is still fresh enough to use again if needed.  If you drive long distances it's good to have a spare.  I had to use it in 2000 on my way back from Denver.  Thank God I had a spare...
Straight Time
« Reply #6 on: June 11, 2011, 08:24:30 am »
Thanks all for advice.
Just wondering if got a flat on the rear and had to use the spare , would there be any adverse effects on the axles or any other components due to one side of the car having a smaller rolling radius ?
Thanks again.
« Reply #7 on: June 11, 2011, 13:24:49 pm »
Nope, having a open diff makes up for that.
A 165 on a 5.5 rim is the max that will fit in the well.
Wout
« Reply #8 on: June 11, 2011, 14:21:17 pm »
14" fuchs
gr
Wout
Aircooled vw's for life!
Straight Time
« Reply #9 on: June 11, 2011, 22:15:59 pm »
Thanks for the advice guys  Wink
« Reply #10 on: June 12, 2011, 02:00:59 am »
I originally bought a 165 for my spare, very close copy of a Firestone, and it didn't want to go in the well. My 155 goes in snugly. Depends on the tire, I guess.
« Reply #11 on: June 13, 2011, 04:38:41 am »
Could be. I was just able to jam a 165 on a 5.5" rim in my old 67. It was a VERY tight fit.
Now I use a 145 on a 4.5, same as I have on the front, and it will work on the rear in a pinch. It does have a bit of room to flop around in the well though.
kingsburgphil
« Reply #12 on: September 09, 2011, 01:51:23 am »
I think this will work for a spare (finally).
« Reply #13 on: September 09, 2011, 02:16:51 am »
Looks nice Phil. How much did Coker get you for? I got my 165's from Jeg's, they were $12 a tire cheaper and $25 less to ship than Coker, and they were shipped from the same place! Where was that XZX made? The ones I got today were made in Serbia, my others were made in France.
kingsburgphil
« Reply #14 on: September 09, 2011, 04:16:32 am »
The 145 XZX say's made in France. By the time I paid for shipping, state & local taxes, "hand" mounting and balancing I chewed thru a little over two bills.
My second choice was some 'Wing Ding' brand which I'm sure are perfectly good tires, but frankly I tired of making excuses for something everybody looks at.
I didn't know Jeg's sold tires too,  guess everyday's a school day.
« Last Edit: September 09, 2011, 04:28:52 am by kingsburgphil » Logged
« Reply #15 on: September 09, 2011, 04:43:42 am »
For my Mexican Beetle, I use one of my Yokohama 165/15 snow tires.  That didn't fit, so I broke out the angle grinder and hacked off a bit of the tread on the corner.
My other car with the wide Fuchs has an original 4½" Fuchs with one of the Mexican Beetle's original 155s.  Or, "PISSBORIS" as KS proclaimed when he saw it.  Smiley  This tire is exactly the same dia as my rear 215/60/15s, so the ZF is happy when I need it.
Tom, I used to be like you.  Guess how I changed my mind?
« Reply #16 on: September 09, 2011, 06:22:26 am »
My 165's were $184 each. That hurt.
« Reply #17 on: September 09, 2011, 07:33:59 am »
I think we should explain: if I recall correctly, on the sidewall it has something like P 155 80 R 15...Am I right?  Cheesy
« Reply #18 on: September 09, 2011, 14:24:42 pm »
145-15 Pirelli Rolle on Magnesium BRM.
johnl
« Reply #19 on: September 09, 2011, 15:56:32 pm »
I have a 15x4.5 Porsche style rim with a 165x15 for the spare.  This is done to closely match the 15x5.5 Porsche style rims on each corner.  The problem I experience is the fit is just to tight and the car has never been hit.  I lowered the pressure to about 15#, but it is still tight.  If I ever need it the 15# will get me to a location where I can add more.
kingsburgphil
« Reply #20 on: September 10, 2011, 03:11:56 am »
I've been caught lubing spare tire wells with spray silicone....helps save those lower back muscles  Wink
« Reply #21 on: September 10, 2011, 04:10:13 am »
Indeed!
« Reply #22 on: September 10, 2011, 06:15:35 am »
So -- -- let me get this straight --- I have to get a spare tire to cover this up
Does that mean I also have to get a jack?Huh
dannyboy
« Reply #23 on: September 10, 2011, 12:40:47 pm »
i got a can of tirefix Wink
8.77@156.8mph
O/FF 60
« Reply #24 on: September 10, 2011, 18:55:53 pm »
That's what I used to do.  But when the hole's bigger than your thumb.......
« Reply #25 on: September 10, 2011, 20:23:14 pm »
And a tool kit !
What good is a spare without the jack and lug wrench to change it ?
Black Sheep
less is more
« Reply #26 on: September 10, 2011, 22:04:51 pm »
I have a 155 in there coz it works on the front end and is pretty close to the 26 diameter I run out back .
But whatever you do get a spare in there , when my 67 was recently hit head on by an idiot driver i believe the spare took most of the impact ,
I shudder to think what it would have been like without it  Shocked
13.03 @ 98mph
« Reply #27 on: September 12, 2011, 18:48:39 pm »
Like this...   Cry
Black Sheep
less is more
« Reply #28 on: September 12, 2011, 20:29:03 pm »
Or with  Roll Eyes
The 67 was stationary and was hit at an estimated 35 -> 40 mpg , these old dubs can take it , just rather it didn't have too  Sad
« Last Edit: September 12, 2011, 20:37:59 pm by Black Sheep » Logged
13.03 @ 98mph
« Reply #29 on: September 12, 2011, 21:13:27 pm »
 Mine wasn't traveling near that fast... 20-25mph max.
