July 24, 2026, 11:02:40 am
| | |-+  Crazy Idle ( Please Help )
Author Topic: Crazy Idle ( Please Help )  (Read 9252 times)
71CALRIPPER
« on: June 28, 2011, 08:02:15 am »
Sorry guys really need help  Embarrassed
The bug I intend to drive to EBI has gone nuts on me, she was happily sitting at around 850-900 on tick over, but then after a week she suddenly decided that 1500 was her happy place and sat at idle, I couldnt think what to do as I was on my way some where so I gave the lickage more throttle cable to bring the idle down.
I am going to check the timing tonight but is there anything else I can check on a pair of 48 IDFs...?
« Reply #1 on: June 28, 2011, 12:26:25 pm »
the idle stop screws?  Mixture, air leak
« Reply #2 on: June 28, 2011, 12:27:18 pm »
Loose manifolds?
CSP throttle linkage?
65bug
« Reply #3 on: June 28, 2011, 12:27:47 pm »
check all linkage nuts and bolts/hex screws. Sounds like something cam loose! Wink
« Reply #4 on: June 28, 2011, 13:36:22 pm »
Spray alittle W-D40 around base of manifold while running and see if idle jumps up, if so ya might have a intake leak.
« Reply #5 on: June 28, 2011, 14:25:24 pm »
I'm thinking intake leak also...
fredy66
« Reply #6 on: June 28, 2011, 17:02:27 pm »
x2
arabia slugs
Larry S
« Reply #7 on: June 29, 2011, 01:29:15 am »
X3
Leaking manifolds/gaskets will do that, we used the WD-40 trick over the years and it works.
Good Luck
Larry
« Reply #8 on: June 29, 2011, 09:43:17 am »
what trick is that, larry?
i soaked the gaskets in grease if that's what you mean.
« Reply #9 on: June 29, 2011, 09:48:28 am »
You spray WD40 or start gas around the the base of intakes while the engine is running and if you have a leak you will instantly notice a jump in the rpms.
« Reply #10 on: June 29, 2011, 09:50:51 am »
The trick he talks of is to find intake leaks... spray WD-40 around the base of the intake... it the engine revs up when you do this. Take the intake of and fix the leak.
I usually use a Engine Start Aerosol to look for leaks, works the same way.
« Reply #11 on: June 29, 2011, 09:56:17 am »
thanks fellas, learned yet another thing. hopefully i'll never have to use it  Wink
Kaferdog
« Reply #12 on: June 29, 2011, 11:57:10 am »
You can also spray WD down the throat also...Idle will jump up if theres a leak
« Reply #13 on: June 29, 2011, 11:58:34 am »
You do VW's long enough and I'm sure you will Wink
« Reply #14 on: June 29, 2011, 12:12:01 pm »
does that mean I gotta give this hobby up soon? Wink
« Reply #15 on: June 29, 2011, 12:27:32 pm »
Since you have learned it all  Wink
Wout
« Reply #16 on: June 29, 2011, 12:28:29 pm »
Sometimes they do it with brake cleaner also
gr
Wout
Aircooled vw's for life!
« Reply #17 on: June 29, 2011, 14:47:49 pm »
I don't think it matters what kind of liquid you spray. You can even use water.
The idea is that the liquid momentarily plugs the leak.
kingsburgphil
« Reply #18 on: June 30, 2011, 04:11:58 am »
I'm not real comfortable using highly volatile sprays like ether or brake clean. Besides the obvious fire risk,
the intake can pick up the vapors and fool you. On some engines I even used propane to find leaks. But I
prefer to use an ultrasonic leak detector (Snap-On) or my favorite,  a mechanics stethoscope with a piece
of hose as a probe. Which by the way is really good at detecting bad idler pulley/belt tensioner bearings,
on pass. cars. Works when holding a long screwdriver to your mastoid bone isn't practical.
Oh' almost forgot...verify your ignition timing is correct and stable  Grin
« Last Edit: June 30, 2011, 04:16:48 am by kingsburgphil » Logged
