September 24, 2026, 07:12:59 am
| | |-+  Late fan/Early 40hp housing
Author Topic: Late fan/Early 40hp housing  (Read 7273 times)
Taylor
« on: July 11, 2011, 22:44:25 pm »
  I thought I read on here that this was possible but after a 40min search I can locate it.  I have to run an early shroud instead of my Thing shroud because my motor is too narrow.  Any help would be appreciated. thanks Taylor
« Reply #1 on: July 12, 2011, 00:09:40 am »
I think Sarge does?
« Reply #2 on: July 12, 2011, 08:06:45 am »
an oval shroud and a 912 oil cooler will serve you well!
« Reply #3 on: July 12, 2011, 14:46:39 pm »
When using the round early 40hp shroud with the rectangular indentation at the top, you need the 131 119 031 fan... not the 113 119 031 B which is slightly wider and used on the doghouse shroud.  The Porsche cooler requires a fair amount bashing inside the shroud (there's a piece of tin ducting at the top of where the cooler sets inside the shroud that needs to be "moved") to fit properly.  Have fun! Wink
« Reply #4 on: July 13, 2011, 01:38:17 am »
That's interesting. I never would have thought the indentation would be an issue since it's above the fan...
« Reply #5 on: July 13, 2011, 02:08:40 am »
I think JHU posted years back he was able to make the 031B late fan fit 36 or 40 HP
Taylor
« Reply #6 on: July 13, 2011, 02:50:56 am »
Bingo!  Thanks Jim I found the thread.  It was JHU
« Reply #7 on: July 13, 2011, 04:15:23 am »
my brain is still good for something  Roll Eyes
fish
« Reply #8 on: July 13, 2011, 13:50:04 pm »
Taylor, can you post a link for us?
thanks
Mike Maize
« Reply #9 on: July 13, 2011, 13:59:14 pm »
Taylor can you post the link to the thread if you get a minute?
« Reply #10 on: July 13, 2011, 14:04:59 pm »
This must it given Taylor's wanted ad for a porsche gen pulley  Wink
Taylor
« Reply #11 on: July 13, 2011, 18:21:48 pm »
http://cal-look.no/lounge/index.php/topic,5386.0.html
sorry guys,  for the betterment of the search function here it is and when I try it ill post pics Grin
