September 22, 2026, 22:17:29 pm
Centrelines and CSP discs- do they fit?
Topic: Centrelines and CSP discs- do they fit? (Read 5864 times)
H67bug
May 14, 2007, 17:14:27 pm »
Does anyone know if zero offset centrelines fit and clear CSP front discs (wide 5 pattern)?
If not do you happen to know what work is required?
Many thanks
axam48ida
Re: Centrelines and CSP discs- do they fit?
May 28, 2007, 05:18:46 am »
I know the bubble centerlines would not clear a CB brake kit. My friend had to massage to caliper and the the he finally machined the halfs down and ran a thinner pad,
I have the CSP's and just to run a stock wheel I had to massage them also
good luck
I heard the bad brakes with wilwood calipers will clear just about anything
Tobi/DFL
May 28, 2007, 13:27:37 pm »
Hi, if the zero offset centerlines are those called "bubbles" then it doesn´t fit as far as I know.
Gunter
May 28, 2007, 18:46:03 pm »
just returned from France
and worked out the wheels and nuts
it turned out to work well with our solution
glad to be of assistance
Gunter
