October 12, 2026, 13:34:26 pm
| | |-+  My 65 race car
Pages: 1 ... 8 9 [10] 11 12 ... 32 Print
Author Topic: My 65 race car  (Read 708416 times)
« Reply #270 on: August 08, 2012, 11:51:53 am »
Basically you would cut off the tubes going to the torsion housing on your Arms and make a new mount of a couple of new added tubes nearer the main cage hoop
Hers a 4 link set up that may give you a idea of what i am talking about
Andy Sykes
« Reply #271 on: August 08, 2012, 12:02:49 pm »
ok cheers being a bit thick how does the length of arm work?
cheers andy
« Reply #272 on: August 08, 2012, 13:57:31 pm »
cheers andy
Unfortunately I am far from an expert,so proberly going to get told I am wrong,but the changes in geometry of a short arm are huge compared to a long arm while moving through its arc,and when the power is applied a longer bar puts the power further forward in the car which I am led to bleieve will make the car react better,less prone to wheeling and less violent,there is alot more to it than that but I am still learning Smiley
cheers richie
Andy Sykes
« Reply #273 on: August 08, 2012, 14:00:54 pm »
ok that makes sense Smiley
cheers andy
Andy Sykes
« Reply #274 on: August 08, 2012, 18:06:39 pm »
Looking at those I think I do need a re think when I first did the rear I wasn't planing the Pauter power lol
Cheers andy
dannyboy
« Reply #275 on: August 08, 2012, 19:05:59 pm »
ffs its starting again youve only been working back on it a day  Roll Eyes Grin
8.77@156.8mph
O/FF 60
« Reply #276 on: August 08, 2012, 19:36:27 pm »
Cheers andy
 Smiley
Maybe sit down with pen and paper and decide exactly what you want to achieve with it now,and then see what spec the rest of it needs to be to do that and more,always leave some extra in there because we always want to go faster later on than we think now Wink
Some things to think of
Will the drivetrain take the abuse and power?
have I got enough tyre and are the wheels strong enough?
are the gear ratios suitable for what i am trying to do and match the engine rpm?
is the fuel system enough to supply what i need and 25% more for later?
have I got enough ignition to fire the fuel needed?
does the turbo move the air I need at the right rpm?
is the intercooler able to cool  the intake temps it will see?
Will it stop when I finally do a full pass Shocked Grin
cheers richie
Andy Sykes
« Reply #277 on: August 08, 2012, 21:31:45 pm »
And your suprised lol
Andy Sykes
« Reply #278 on: August 08, 2012, 21:41:42 pm »
Cheers andy
 Smiley
cheers richie
Yes you are correct exactly what I need to do when I started I was planning 300 since then you can see what's happened
Will the drivetrain take the abuse and power? Gearbox yes cvs 930s not sure
have I got enough tyre and are the wheels strong enough? Unknown to me split 8" compromotive Fuchs
are the gear ratios suitable for what i am trying to do and match the engine rpm? Geared to 155 @ 7000
is the fuel system enough to supply what i need and 25% more for later? It will be 2000hp pump so 1000 on meth
have I got enough ignition to fire the fuel needed? Coil per cylinder so I hope so ?
does the turbo move the air I need at the right rpm? It looks ok to me twin scroll Borg Warner bullseye 366
is the intercooler able to cool  the intake temps it will see? That im sure of custom one with the same core as a 1200 bhp v12 Lamborghini
Turbo conversion but mine you can fill directly with ice
Will it stop when I finally do a full pass Shocked Grin I think so Stroud chute and gears brakes all round but who knows
I need to spend the day planning the final rear suspension and probably loads more questions
Cheers andy
« Last Edit: August 08, 2012, 22:05:58 pm by fast65 » Logged
Andy Sykes
« Reply #279 on: August 13, 2012, 16:53:57 pm »
so this bit is dannys fault for asking me to get his NOS filled up at websters, the rear suspension is now being made there i think this guy knows exactly what hes doing Smiley
http://www.webster-race-engineering.co.uk/ and hes ten minutes from my front door
http://performancetrends.com/download.htm
when you download the suspension analyser you can see how a slight change shifts things on a car
cheers andy
« Last Edit: August 13, 2012, 17:24:54 pm by fast65 » Logged
Andy Sykes
« Reply #280 on: August 13, 2012, 22:31:42 pm »
electrics baby
Cheers andy
dannyboy
« Reply #281 on: August 13, 2012, 22:54:42 pm »
 Cool Cool
8.77@156.8mph
O/FF 60
Andy Sykes
« Reply #282 on: August 16, 2012, 12:03:35 pm »
started the thank less task of removing the underseal from the arches  Cry
removed the trim that holds the seal in place looks nice and clean
cheers andy
Andy Sykes
« Reply #283 on: September 15, 2012, 18:08:46 pm »
So apart from doing a lot of talking and asking questions on suspension to Webster and Hauser not much has happend I do at least have a much better understanding of what I need and what will work in a beetle from these guys. Other news the turbos has gone bigger for the new engine as the Borg Warner 366 was going to be too small so Mr Keene has sold me this  Grin
HX52 twin scroll with 100mm billet compressor  Grin
Cheers andy
Andy Sykes
« Reply #284 on: September 19, 2012, 18:27:18 pm »
So Stupid idea 10.71
I can't get my car into webster or hauser until january Jeff Hauser spent a fair bit of time with me explaining four link and how it all works but not on a beetle like it does on a live axle lol, so made sense to stay IRS. So that started me thinking again
This is the final plan I promise lol
996 rear end so I can use 996 drive shaft (tiptronnic) as they are shorter and the inner should fit the 930 output it looks a bit wide in the picture but the box has to come higher and from what I've measured today so fit fine
Basically I'm going to make a frame and motor plates for the transmission and mount the IRS to that luckily there are a lot of tuning parts for the rear of the 996 so I can make the whole rear end adjustable
Cheers andy
« Last Edit: September 19, 2012, 20:08:18 pm by fast65 » Logged
dannyboy
« Reply #285 on: September 19, 2012, 18:31:34 pm »
quality mate fricken love it  Cool
8.77@156.8mph
O/FF 60
13bussing
« Reply #286 on: September 19, 2012, 20:30:13 pm »
 Shocked Shocked thers no stoping you is ther.
« Reply #287 on: September 19, 2012, 20:39:57 pm »
Is it bolt on?  Smiley
Eddie DVK
« Reply #288 on: September 20, 2012, 07:19:47 am »
x2
Regards Edgar
Andy Sykes
« Reply #289 on: September 20, 2012, 08:10:21 am »
lol it will be by the time ive finished Smiley
« Reply #290 on: September 20, 2012, 08:18:58 am »
May I ask how much it weight compared to a "ordinary" IRS? I think you should focus on weight and balance in a car with the kind of HP that you plan on having. Borrow corner scales and move things around until you`re happy.
-BB-
Andy Sykes
« Reply #291 on: September 20, 2012, 08:29:09 am »
-BB-
I haven't got any scales here but Im guessing about 10kg-12kg and I will be using the strange brakes i have. So should be very close to standard irs with drum/disc brakes a would guess and yes im going to get the corner weights done and get the car set up suspension wise before it even sees a track. I will be putting the battery and dry sump up front and the fuel tank of course.  And the turbo is going over the transmission so i think that may help as the 930 box is very heavy compared to a vw box
cheers andy
AntLockyer
« Reply #292 on: September 20, 2012, 10:10:11 am »
I thought this was going to end up with a floating motor and live 'axle'  Shocked
12.618 @ 104.87mph
Andy Sykes
« Reply #293 on: September 20, 2012, 17:38:20 pm »
I still have no idea hows its going to turn out but one has to try lol
so a little bit done today
i think the exhaust header may be an issue so i will need to take that into account. The bell housing of the transmission will be on a motor plate but the rear im not sure i think i may use the standard mount?
fingers crossed a bit more tmw
cheers andy
Andy Sykes
« Reply #294 on: September 21, 2012, 15:51:15 pm »
bit more done today Smiley
defo need a bit more practice at TIG but not bad for a sparky lol
and the CVs fit the gear box result Smiley
the track at the moment looks like 140mm
cheers andy
Andy Sykes
« Reply #295 on: September 23, 2012, 14:39:04 pm »
Poped into the workshop today to cut the rear off the chassis i cant do this during the week as its far to loud for the guys in the office  Roll Eyes
so thats it no going back now lol
cheers andy
Fasterbrit
« Reply #296 on: September 23, 2012, 20:44:59 pm »
Wow! I hope you have some datums  Shocked
www.air-kraft.com
www.marcomansiperformance.com
Andy Sykes
« Reply #297 on: September 23, 2012, 20:54:59 pm »
Lol sure have and a spare chassis to measure just in case Smiley
Andy Sykes
« Reply #298 on: September 24, 2012, 18:01:41 pm »
my solution to hold the rear end on
7 M16 12.9 bolts
3 x 16mm Dowels
im trying to make the whole transmission and engine removable i have a few ideas to disconncet the cage that will need to be tied in.
transmission end
cheers andy
Andy Sykes
« Reply #299 on: September 25, 2012, 19:26:35 pm »
Bit more done machined and welded in the dowels
Bit of mocking up
Cheers andy
« Last Edit: September 25, 2012, 19:30:27 pm by fast65 » Logged
