October 12, 2026, 13:34:26 pm
| | |-+  My 65 race car
Pages: 1 ... 9 10 [11] 12 13 ... 32 Print
Author Topic: My 65 race car  (Read 708415 times)
AntLockyer
« Reply #300 on: September 26, 2012, 07:15:07 am »
What's the extra hoops for? tying into the cage?
12.618 @ 104.87mph
« Reply #301 on: September 26, 2012, 08:17:48 am »
I would reconsider how you use bolts in the attachment of this cage. You are now relying on the strength of the bolt to keep the back end on. In other words they get a lot if not all the stress.
If you bolt it sideways (90° to the center axis of the car) it will rely on the clamping force between the cage and the tabs you weld on the chassis. Then the bolts will only have to maintain the clamping force.
And if you spreed the bolts as far apart as possible it will become stronger with every mm you gain.
Just an opinion from a engineering standpoint, but carry on, you must have a lot of fun!
Andy Sykes
« Reply #302 on: September 26, 2012, 14:33:17 pm »
hi they are for mounting the suspension Smiley
cheers andy
Andy Sykes
« Reply #303 on: September 26, 2012, 14:35:11 pm »
Hi i get what your saying how much twisting force would you think would be there i cant think there would be a huge amount, the cage for the trans will also be tied into the cage in the car  there's also 160 mm + of CSA of bolts and dowls there there won't be that much on the flywheel
any help is good
cheers andy Smiley
« Last Edit: September 26, 2012, 18:20:54 pm by fast65 » Logged
cedric
« Reply #304 on: September 26, 2012, 19:53:53 pm »
Nice work...keep on Going Shocked
Andy Sykes
« Reply #305 on: September 28, 2012, 17:04:35 pm »
so had a few days off the acr had do to some real work Sad
trails fit of the rear end looking good so far Smiley
fingers crossed a bit more this weekend:)
cheers andy
Andy Sykes
« Reply #306 on: September 30, 2012, 15:25:12 pm »
managed to escape over to the workshop for a few hours to do a bit more mocking up as i still wasnt convinced i was going to fit this lot under the wings. I had to machine down the 996 hubs dam they are hard lol
pressed in some studs
strange rotors now fit Smiley
very slight change in plan as becouse of the ET of the wheels i want to use im going to have to directly mount the arms to the transmission cage a little bit more work and lots more measuring but worth the effort
cheers andy
« Last Edit: September 30, 2012, 15:34:20 pm by fast65 » Logged
Andy Sykes
« Reply #307 on: October 01, 2012, 20:01:12 pm »
Started of the cage disconnection parts
I've got to bore a hole in and thread it not sure if this will work but got to start someware lol
Cheers andy
Fasterbrit
« Reply #308 on: October 01, 2012, 21:31:00 pm »
Very interesting setup. I guess I should pull my finger out and remember to post out your parcel Wink
www.air-kraft.com
www.marcomansiperformance.com
Andy Sykes
« Reply #309 on: October 02, 2012, 19:29:26 pm »
Lol just let me know when it's on the way so I can prepare to postman,
Not much done today having to divert my efforts to constructing some more offices at work
But managed a bit finished the second cage part
And started on the motor plate
Little steps keep chipping away lol
Cheers andy
Andy Sykes
« Reply #310 on: October 04, 2012, 17:26:34 pm »
spent ages measuring and checking and measuring tacking and moving but its about there
still loads to do and more tube to be added but getting there
cheers andy
Andy Sykes
« Reply #311 on: October 05, 2012, 16:55:31 pm »
bit more done new turbo turned up even though i dont look happy im a miserable git and it was heavy lol sense of scale next to my big head
billet 100mm compressor Smiley
popped arounf to weldfab to borrow there tube bender
and popped a few more tubes in place
bit more over the weekend fingers crossed
cheers andy
Fasterbrit
« Reply #312 on: October 05, 2012, 20:47:51 pm »
Hey Andy, glad the turbo arrived safely Wink
I'm digging your suspension approach. I bet it'll go around corners well! Are you going to poly bush the suspension arms?
Cheers, Matt
www.air-kraft.com
Andy Sykes
« Reply #313 on: October 05, 2012, 21:11:41 pm »
Cheers, Matt
Cheers matt I'm chuffed with the turbo Smiley I'm not sure yet if to poly bush or machine up some bearing mounts for some spherical and roller bearings to take out any movement . I think the later at the moment but you know how I change my mind lol
Cheers andy
« Last Edit: October 05, 2012, 21:15:28 pm by fast65 » Logged
Fasterbrit
« Reply #314 on: October 05, 2012, 21:32:52 pm »
You change your mind??? Never!  Grin
www.air-kraft.com
Andy Sykes
« Reply #315 on: October 06, 2012, 16:34:28 pm »
bit more done took ages setting the plate square to the car in all planes but got there in the end including setting fire to my hoodie with me in it lol
thats not coming out now
and the turbo ahs found it new home just were the old one was going to fit Smiley
bit more tmw then fingers crossed i can fully weld everything later in the week
cheers andy
Andy Sykes
« Reply #316 on: October 07, 2012, 18:03:08 pm »
so little vist to the workshop and welded some parts in place
that is 100% not going to move
3 hardened 18mm dowls
7 M18 x 2.5 12.9 cap screws
welded the plate to the frame
and few other parts the need a bit of tigging while i was at it still need more practice at TIG but pratice makes perfect i need lots of practice
both side on ive got to do a lot of measuring to make sure i get the geometry  the same but im happy it looks like it may even work
im going to tie the rear cage to here on the main hoop
from here
when ive got some more tube and also adjust the angle of the top mounts
cheers andy
« Last Edit: October 07, 2012, 21:14:58 pm by fast65 » Logged
Andy Sykes
« Reply #317 on: October 08, 2012, 17:37:17 pm »
been busy boy today rear suspension is about there i think
spend a few hours removing underseal and finding small holes to fix
then thought i better offer up some of the fluid systems
dry sump has got to go a bit lower so i can fit the bonnet
more tmw
cheers andy
Andy Sykes
« Reply #318 on: October 09, 2012, 18:16:42 pm »
so mind changing again today but dont panic nothing major i think im going to movr the oil cooleer and drysump to near middle of the car as i can plus without cutting the front of the car it wasnt going to be easy to fit, and i also needed somewhere for the battery
got to make a domed cover for this bit
made a mount for the turbo a tacked in place
and machined the cage disconnection part
cheers andy
Andy Sykes
« Reply #319 on: October 10, 2012, 18:58:53 pm »
Just hours of welding up holes ( boring )
Cheers andy
Fasterbrit
« Reply #320 on: October 10, 2012, 20:13:10 pm »
Awesome!!!  Cool
www.air-kraft.com
thehanz DVK
« Reply #321 on: October 10, 2012, 20:54:24 pm »
What to say..... Shocked. Like this thread
Andy Sykes
« Reply #322 on: October 11, 2012, 16:30:19 pm »
cheers guys thanks Smiley
started on redoing the wheelie bar and chute mount
another hairbrained idea
im going to fit a duct to remove the air that gets trapped under the front wings and expel it out the rear of the channel just got to remove all the wax oil i pumped in there years ago lol
cheers andy
« Reply #323 on: October 12, 2012, 14:43:48 pm »
Andy, have you welded up the wing bolt holes?  Shocked
Like the aero mods! I found that a front air dam worked well. Wink
Jonny Grigg
« Reply #324 on: October 12, 2012, 16:08:47 pm »
This is one of the best threads I have read in a while. Amazing. I started from the beginning last night. In awe- I love your approach to this- some great ingenuity. Keep the updates coming, I'm hooked!
No Compromise. O/FF111
Andy Sykes
« Reply #325 on: October 12, 2012, 16:35:10 pm »
cheers guys thanks for the comments Smiley im having an air dam made by a friend of mine who is and old school panel beater who restores old bentlys, so im looking forward to see what he comes up with
  today has been a good day, a fair bit done
made the front air scoop to direct air down the haeter channel
out
calipers on and mounted
and started on the suspension height sensor comes standard on a 966 thats a bit of luck Smiley
cheers andy
Andy Sykes
« Reply #326 on: October 12, 2012, 20:20:53 pm »
Oh yes sport I have welded up ten wing bolt holes putting them on with dzus fasteners
Cheers andy
« Reply #327 on: October 13, 2012, 09:40:31 am »
the sump tank and oil cooler must not be in the cockpit.  They need to be boxed in.
Andy Sykes
« Reply #328 on: October 13, 2012, 10:06:54 am »
Good job there not then lol
Ninho/DKM
« Reply #329 on: October 15, 2012, 10:26:05 am »
Ok,.... that's a F&$kn' amazing work.
1974 Superbeetle Porsche affected and influenced
1957 Gasser Project work in progress
1973 Thing type 181 Civil version (sold)
1959 Bug waiting attentions
1963 Surfin'Bird Street and Strip race Bug 1776cc Best E/T 14,769 at Hills Race#10
www.Surfinbirdbug.blogspot.it
www.Ninho-Reloaded.blogspot.it
