October 12, 2026, 16:12:14 pm
My 65 race car
11
12
13
14
32
Topic: My 65 race car (Read 708744 times)
Re: My 65 race car
Reply #330 on:
October 15, 2012, 10:30:49 am »
Quote from: Lids on October 13, 2012, 09:40:31 am
the sump tank and oil cooler must not be in the cockpit. They need to be boxed in.
And please make sure you box in the oil sump etc really well. A few drops on your slicks and all hell can brake loose.
-BB-
Andy Sykes
Re: My 65 race car
Reply #331 on:
October 15, 2012, 16:40:09 pm »
Quote from: Ninho/DKM on October 15, 2012, 10:26:05 am
Ok,.... that's a F&$kn' amazing work.
cheers thanks
Andy Sykes
Re: My 65 race car
Reply #332 on:
October 15, 2012, 16:42:39 pm »
-BB-
[/quote]
thats worries me to even a slight leak back there could be a slight issue, so it was d-day today would it fit with 10" slicks the answer is just lol but i still have about5mm i can back space them yet so may well do that yet.
got to adjust this though lol needs to come up a bit good job its only tacked in
so looks like i can start welding it all up for good tmw
cheers andy
Fasterbrit
Re: My 65 race car
Reply #333 on:
October 15, 2012, 16:55:17 pm »
Sweet
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
Andy Sykes
Re: My 65 race car
Reply #334 on:
October 16, 2012, 20:17:49 pm »
Quote from: All Torque on October 15, 2012, 16:55:17 pm
Sweet
Cheers Matt thanks
Spent a few hours today practicing TIG welding using the pedal and then put it to work
As you can see I'm not master at it but happy so far
Andy Sykes
Re: My 65 race car
Reply #335 on:
October 17, 2012, 19:14:53 pm »
Just more welding
This TIG welding lark takes some practice lol so if keep going I may get better by the end of the job lol
Cheers andy
Andy Sykes
Re: My 65 race car
Reply #336 on:
October 18, 2012, 14:44:17 pm »
its on the floor woo hoo
next job is making the adjustable top arms to adjust the toe and camber as you can see its about 8 deg a bit over the to lol
pretty happy how its turned out i will have to shorten the drive shafts i wasnt that lucky it was close but not that close
cheers andy
AntLockyer
Re: My 65 race car
Reply #337 on:
October 18, 2012, 19:47:26 pm »
Looks great, nice one.
12.618 @ 104.87mph
Fasterbrit
Re: My 65 race car
Reply #338 on:
October 18, 2012, 20:00:56 pm »
With 8 degrees of negative camber, your on the wrong forum. Restowagen for you from now on!
www.air-kraft.com
Re: My 65 race car
Reply #339 on:
October 18, 2012, 20:09:49 pm »
Andy
why does it have so much camber? surely the porsche it came from didn't have that much? so if you get the geometry the same as the posrche& mount the arms in the same place as the porsche you wont need adjustable ends? also 2 things that are bothering me looking at all the pics,
1.ride height, what have you done to allow it to increase ride height? when you add 500lbs of engine and ancillaries its going to be on the floor
and 2. how are you going to get a header in there? the point were 1&3 tubes come out of the heads looks like its going straight into the suspension arms?
it was difficult enough on mine to get those 2 tubes out,needing to actually go through the suspension,around the cv & hub and then underneath
and mine has much more room around it that yours.
I like the fact you are thinking so outside the box
but there are somethings that just have to be done the conventional way,the exhaust port is on the end of the head so it has to come out there
Can you put a front wing on for me please? I want to see how it looks with that front suspension, thanks
cheers richie
Andy Sykes
Re: My 65 race car
Reply #340 on:
October 18, 2012, 20:14:44 pm »
Quote from: All Torque on October 18, 2012, 20:00:56 pm
Fuck and I'm keeping the trim I'm on a downward slope lol
Andy Sykes
Re: My 65 race car
Reply #341 on:
October 18, 2012, 20:32:25 pm »
Hi Ritchie
Thanks for your comments keep them coming I have tried to think of as match as I can lol
Quote from: richie on October 18, 2012, 20:09:49 pm
Andy
It would be a waste of time doing so as I want the rear end to be completely adjustable so the 8 deg of neg camber at the moment is as far as it can go at this height I also will be making the new arms to get rid of the rubber bushings to get zero toe change
I have some laser cut parts coming I need to weld in place for height adjustment
It will fit there's loads do room
those arm taper in at an angle
But that's too easy what would I think about at night lol
I sure will when I get them back from the guy making the front air dam I do have some standard ones I could try though
cheers richie
Cheers andy
Andy Sykes
Re: My 65 race car
Reply #342 on:
October 18, 2012, 21:19:56 pm »
Quote from: AntLockyer on October 18, 2012, 19:47:26 pm
Cheers thanks
Re: My 65 race car
Reply #343 on:
October 18, 2012, 22:47:09 pm »
Are you getting ex flanges from pauter with your engine? I think they are cut for 2inch primaries so that will be your header size,the radius on a 2inch tube is big and you need 2-3 inches of straight coming out of the exhaust port so how close is that going to put the header to the suspension arms? it may just be an optical illusion looking at your pics so I hope you are right but it looks really tight to me.
Why couldnt you get the ride height and camber correct already,is there something in the way preventing it? I understand wanting to build in some adjustability but surely you need to have it close to start with?
Suggestion:
A longer coilover would proberly help the ride height issue
cheers richie
A stock wing on the front just to see would be perfect,thanks
Andy Sykes
Re: My 65 race car
Reply #344 on:
October 19, 2012, 09:00:00 am »
Hi Riche it is going to be tight i have about 8 " i moved the suspension about that much to get 0 camber at ride height i couldnt land were i wanted to yes in the ideal world setting as close to 0 would be good but its no big problem the GT3 runs a slight camber not 8 deg though lol and yes longer coil over would be a better solution i may stick with that idea. As to a picture with stock wings ive weled th holes up so cant fit one lol but this is with the CSP wider wings, with a stock wing the wheel is in the standard position i.e not tucked
cheers andy
Andy Sykes
Re: My 65 race car
Reply #345 on:
October 19, 2012, 16:21:17 pm »
started on making the adjustable tie rods today a trip to the bearing shop for these
machine up a housing
just eight more to make now lol
cheers andy
Re: My 65 race car
Reply #346 on:
October 19, 2012, 16:35:05 pm »
Quote from: fast65 on October 19, 2012, 09:00:00 am
cheers andy
I am a little confused,are you setting this up for drag racing or circuit racing?
thanks for the pics with the wings on,so it is the same width front track as stock?
cheers richie
Re: My 65 race car
Reply #347 on:
October 19, 2012, 16:49:34 pm »
Andy -- Absolutely fantasic build --- You have gone far out of the box and it looks great --May I suggest some additional small gussets on the tie rod ends -- just a little something something to keep the end to the shaft
Harold
http://selvedgeyard.com/
Andy Sykes
Re: My 65 race car
Reply #348 on:
October 19, 2012, 18:36:58 pm »
Quote from: richie on October 19, 2012, 16:35:05 pm
cheers andy
cheers richie
Drifting is my new plan
Cheers andy
Andy Sykes
Re: My 65 race car
Reply #349 on:
October 19, 2012, 18:38:35 pm »
Quote from: Fiatdude on October 19, 2012, 16:49:34 pm
Harold
Cheers thanks for comments
and yes that's a good plan adding the gussets it's now a job on the list
Cheers andy
Re: My 65 race car
Reply #350 on:
October 19, 2012, 18:43:19 pm »
Why are you using axial bearings? Wouldent normal heimjoints be better prepared for the pulling/pushing forces?
Andy Sykes
Re: My 65 race car
Reply #351 on:
October 19, 2012, 18:55:54 pm »
I saw it as there will be more axle/torsional load more than tensile load ?
Cheers andy
Last Edit: October 19, 2012, 19:29:33 pm by fast65
Andy Sykes
Re: My 65 race car
Reply #352 on:
October 19, 2012, 19:51:57 pm »
You've got me thinking so thanks
I think I will add a radial bearing as well in the middle of the two axle bearings that should cover it
Cheers andy
fastbus
Re: My 65 race car
Reply #353 on:
October 19, 2012, 21:08:36 pm »
Hi Andy,
man, you have put some serious time in to that baby. You must have a very understanding missus.
I'm looking forward to seeing this on the track and in the pits at sometime in the future!
Inspirational work at its best!
Good luck with it fella!
13.66@102mph in my old T3 crew cab builders truck!
13.01@109mph in my bug so far!
Andy Sykes
Re: My 65 race car
Reply #354 on:
October 20, 2012, 17:07:14 pm »
Quote from: fastbus on October 19, 2012, 21:08:36 pm
Hi Andy,
Cheers thanks very much, most of the time the wife has no idea what I'm doing at work, I only give the game away when I come home with holes in my clothes and smelling of burning lol
Cheers andy
Andy Sykes
Re: My 65 race car
Reply #355 on:
October 20, 2012, 17:14:00 pm »
Not much achieved today I went tool shopping not done that for while but it will save me time on the build so I don't have square all the cuts up now
Makes a nice cut
Blanks are all ready to make the rod ends
And I can also use it upright when you have fitted the table that's going to very useful when I come to make the header
I've been thinking about the thrust bearing I got and think I would be better using conical bearings I think that will cover all angles
Cheers Andy
Re: My 65 race car
Reply #356 on:
October 20, 2012, 18:16:12 pm »
I have been thinking too, Since these arms are not parallell I think you will get binding with normal bearings. Heimjoints still looks like the solution to me. Nice saw!
Andy Sykes
Re: My 65 race car
Reply #357 on:
October 20, 2012, 18:29:26 pm »
Hi the reason I don't think the helm joints will work is, if you imagine the hub in front of you the helm joint will allow movement left to right and right to left, the arms move in an arc as you know I don't think there is any side wards movement, and there is also no whiteness marks on the rubber bushes showing that, that's why after you pointed out maybe not just an axle force I think conical it works for wheels lol
Cheers andy
Martin
Cash Converter....
Re: My 65 race car
Reply #358 on:
October 20, 2012, 18:57:17 pm »
Quote from: fast65 on October 19, 2012, 16:21:17 pm
cheers andy
Andy, they are thrust bearings and cant take any side loading, they can only support axial pressure.
A Rose joint or Helm Joint is whats needed in this application.
Martin
Martin
www.taylormachine.co.uk
OFF/500
Andy Sykes
Re: My 65 race car
Reply #359 on:
October 20, 2012, 19:04:13 pm »
Thanks for your replies but I still can't get out of my head if I use hell joint on the top two arms it will then move from side to side
Or am I over thinking it ?
Also the joints on the bottom to the hub are not fixed they are ball type joints
Cheers andy
Last Edit: October 20, 2012, 19:09:08 pm by fast65
11
12
13
14
32
