October 12, 2026, 19:34:12 pm
| | |-+  My 65 race car
Pages: 1 ... 16 17 [18] 19 20 ... 32 Print
Author Topic: My 65 race car  (Read 709343 times)
Andy Sykes
« Reply #510 on: April 14, 2013, 17:33:16 pm »
Bit more done Smiley
Starting to look like it may work Smiley
Cheers andy
Andy Sykes
« Reply #511 on: April 15, 2013, 17:09:39 pm »
shes back on the floor Smiley
and lots of room for tanks, batteries and coolers Smiley
cheers andy
fahrvergnugen
« Reply #512 on: April 15, 2013, 20:03:06 pm »
DAMN. Going this fast it will be ready next weekend. Great work Andy.
Andy Sykes
« Reply #513 on: April 16, 2013, 19:51:20 pm »
Don't worry I will soon change my mind lol, but I think I have found the steering rack Smiley fiat Smiley
Tiny bit too long
With a bit of re-engineering I think this will work nicely Smiley
Cheers andy
Andy Sykes
« Reply #514 on: April 17, 2013, 18:14:06 pm »
 Not much today that thing called work got in The way lol
It like this rack was made to be here lol centres work
The angle of dangle may be a pain Sad
But with a little tickle these will fit and no I'm not doing it like that its the mock up lol
Cheers andy
Andy Sykes
« Reply #515 on: April 18, 2013, 16:24:50 pm »
so the shocks came today and they are a bit sorter so that's good also slightly wider so I need to machine the hub carrier out to 55mm as its only 51mm so Cayman shocks don't fit a Boxster lol but im pleased so far how its worked out, thinking of fitting the dry sump tank, and battery at the front and making a fuel cell up to fit nicely
cheers Andy
fahrvergnugen
« Reply #516 on: April 18, 2013, 20:00:27 pm »
Looking good Andy.
Your wheelbase and front width are different compared to the boxter. Have you thought about the Ackermann geometry ? I am still not sure how to solve that at my car.
Paul.
Andy Sykes
« Reply #517 on: April 18, 2013, 20:25:41 pm »
Hi Paul
I haven't given it much thought to be honest as I'm only going in a straight line, but I will have every angle adjustable. I'm also going to limit the travel on front and rear
Cheers andy
fahrvergnugen
« Reply #518 on: April 19, 2013, 21:12:25 pm »
To much work just to go in a strait line Grin
The Ackermann Principe isn't adjustable, it has to do with the angle of your steering arms (on the Porsche struts). the ideal Angle is that when you draw a line, the crossing point of L and R is in the centre of the rear axle.
But if you're not using your steering wheel Grin
Paul.
Andy Sykes
« Reply #519 on: April 19, 2013, 21:18:49 pm »
No such thing as too much work lol
fahrvergnugen
« Reply #520 on: April 19, 2013, 21:22:15 pm »
 Grin Grin
I see the steering is on the front, did you change left and right?
Andy Sykes
« Reply #521 on: April 19, 2013, 21:28:56 pm »
Nope that's its normal place Smiley
Andy Sykes
« Reply #522 on: April 20, 2013, 16:28:16 pm »
Cheers guys thanks little bit more finalised a bit more braketry, I had some spare brackets so I've welded them on for dyno work to strap the car down.
Hopefully the tubing will come this week so I can start the induction Smiley
Cheers andy
Andy Sykes
« Reply #523 on: April 21, 2013, 17:43:51 pm »
had a little mess about this afternoon with the waste gates so far this is where they are going Smiley
cheers andy
Andy Sykes
« Reply #524 on: April 22, 2013, 19:48:14 pm »
Little bit done i think I need some more work here the angle looks a bit tight
And I like this picture lol
Cheers andy
Andy Sykes
« Reply #525 on: April 24, 2013, 17:48:42 pm »
Tiny bit more done mocking up the induction
Can't see the duck tape boost pipe connectors lasting long lol
Andy Sykes
« Reply #526 on: April 25, 2013, 16:03:21 pm »
Little bit more done mocking up from the turbos to the charge cooler
Cheers andy
« Last Edit: April 25, 2013, 16:05:35 pm by Andy Sykes » Logged
Martin
Cash Converter....
« Reply #527 on: April 25, 2013, 18:28:37 pm »
you dont need a charge cooler on meth
Martin
www.taylormachine.co.uk
OFF/500
Andy Sykes
« Reply #528 on: April 26, 2013, 19:32:45 pm »
Lol I know but I paid a fortune for it so I'm going to use it  Cheesy
Bit more, I may get this car done if I keep going lol
Fitted the tanks, I've fitted the battery and dry sump to the left of the car to try and help corner weights as I'm 100kg so I've got a bit to make up on that side lol
Steering all connected and is very smooth and tight Smiley
Not much lock but its not a fork truck Smiley
And I've changed my mind again most of the electronics is moving to the front so the wife will be pleased I'm going to remake the harness to go to the rear of the car looks like the kitchen table will be out of action for a while lol
Cheers andy
fahrvergnugen
« Reply #529 on: April 26, 2013, 20:47:52 pm »
Hi Andy,
Still going strong Cool
I know you told me you are only driving strait lines. But are the steering rod angles not just a little to small?
Keep up the inspiring work. Cheers, Paul.
Andy Sykes
« Reply #530 on: April 26, 2013, 20:55:16 pm »
Hi Paul
Not sure what you mean remember my day job is wires lol
Cheers andy
fahrvergnugen
« Reply #531 on: April 27, 2013, 20:51:50 pm »
Hi Paul
Cheers andy
This is what I mean. I don't like the angles, but I think I will be having the same problem.
Paul.
Andy Sykes
« Reply #532 on: April 28, 2013, 17:13:05 pm »
oh ok it seams to work on a jack lol
started to make the support mounts for the front wish bones thesw will move so I can adjust the castor angle as you cant do this on a boxster Smiley
to replace these used for mocking up
cheers andy
Martin
Cash Converter....
« Reply #533 on: April 29, 2013, 09:29:02 am »
so how much bump steer has it got now?
the castor angle on "moden" car struts is done on the top mount.
Martin
Martin
OFF/500
Andy Sykes
« Reply #534 on: April 29, 2013, 17:46:43 pm »
Hi Martin I don't think it will have any bump steer, yes normally you would adjust on the top. I have camber adjusters on the top and needed to make a mount for the bottom so two birds with one stone Smiley
Cheers Andy
Martin
Cash Converter....
« Reply #535 on: April 29, 2013, 18:23:00 pm »
Cheers Andy
what makes you think it wont have bump steer?.... you must have put bump steer gauges on it, removed the springs any cycled it through its travel measuring the bump, then place the rack in the correct place then...
ok so long as youve done that then.
First dibs on the motor when its draged out the wall...
Martin
Martin
OFF/500
Andy Sykes
« Reply #536 on: April 29, 2013, 18:25:18 pm »
Ha ha trick question lol
Andy Sykes
« Reply #537 on: April 29, 2013, 18:28:15 pm »
No realy the car is going to have all the suspension checked front and rear before any paint by a guy that knows his stuff, the rack is just tacked in place at the moment
Cheers Andy
Andy Sykes
« Reply #538 on: May 05, 2013, 17:11:57 pm »
MK1 of the caster adjuster
I think I'm going to cut out the triangular piece of metal on the chassis and replace with a flat piece do 4mm as the OG part has ridges
Cheers andy
« Last Edit: May 05, 2013, 17:14:19 pm by Andy Sykes » Logged
Andy Sykes
« Reply #539 on: May 11, 2013, 14:40:59 pm »
been a bit of a head scratcher this has as I realised I would be grounding the car if I used the bar on the bottom so ive scrapped that idea and mocked this up I think this is the solution I can get 10 deg of caster just got to find another home for the dry sump
ive also got to strip this lot down and work out how im going to fit the strange brakes to the front lol
cheers andy
