October 12, 2026, 13:15:41 pm
| | |-+  My 65 race car
Pages: 1 ... 23 24 [25] 26 27 ... 32 Print
Author Topic: My 65 race car  (Read 708341 times)
Andy Sykes
« Reply #720 on: April 04, 2014, 17:35:14 pm »
Started fixing a few bit down today
Hopefully the bearing and bolts for the transmission arrive soon so that can be done
Cheers Andy
Erlend / bug66
Global Moderator
SCC Event
« Reply #721 on: April 04, 2014, 19:20:55 pm »
It looks like the exhaust is fairly close to the coils on 3/4 side?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Andy Sykes
« Reply #722 on: April 05, 2014, 14:58:51 pm »
It's close but not that close
Andy Sykes
« Reply #723 on: April 07, 2014, 19:46:43 pm »
Billet de-tachible door hinges in production
Cheers Andy
Andy Sykes
« Reply #724 on: April 08, 2014, 17:54:30 pm »
bit more work on the hinges
very light non drip connectors for various locations to aid engine removal,
little idea I had for wiring the motor
cheers andy
spoolin70
« Reply #725 on: April 09, 2014, 07:17:21 am »
Hi Andy
Great progress, do you actually sleep  Cheesy
Are you going with the air box idea for the turbo's intake ? I was wondering if it was possible for two turbos that suddenly take a big gulp of air when spooling up to effectively empty the air box or would this just create a vacuum to pull more air in ?
Darren
Andy Sykes
« Reply #726 on: April 09, 2014, 19:54:20 pm »
Cheers thanks, it's not to every bodies taste, but what is ? lol I'm enjoying myself . I have some cast 4" bends on the way that I can make fit so I've scrapped the air box idea
Bit more on the hard lines for the oil
And finally got round to bolting the front flip,mount together to fit to the car so we can make the flip front fit nice Smiley
Cheers Andy
Taylor
« Reply #727 on: April 10, 2014, 02:13:44 am »
Does the picture show you pulling vacuum from the 3/4 valve cover?
Andy Sykes
« Reply #728 on: April 10, 2014, 07:37:22 am »
Yes it does, but i think it's the wrong side I need to swap the covers over and fit another fitting for the turbo drain
Cheers Andy
Martin
Cash Converter....
« Reply #729 on: April 10, 2014, 09:05:49 am »
you should be pulling Vac from the crank Case, the idea is put neg pressure behind the rings. but you'll have to shield it so it doesn't suck up the oil thrown off the crank.
Martin
www.taylormachine.co.uk
OFF/500
Andy Sykes
« Reply #730 on: April 10, 2014, 18:18:54 pm »
Hi Martin
I was thinking best place was right hand rocker cover as that were the least amount of oil spray should be, and pulling a vacuum in the case will still happen from there as it would direct into the top of the case or am I
Missing something
Cheers Andy
peach_
« Reply #731 on: April 11, 2014, 00:59:13 am »
Hi Martin
Missing something
Cheers Andy
By doing that arnt you creating a less effective way of vacuuming? surely if you want to create a vacuum should you do it on both sides to create equal pressure on both sets of pistons? or just create it from the middle as martin suggested?
SAS RENN-WAGENS and proud
#CALLOOKDRAGS
Martin
Cash Converter....
« Reply #732 on: April 11, 2014, 09:18:36 am »
your trying to place the area under the pistons in negative pressure, as that's where all the pumping in occurring. Rather than try and drag the air up the push rod tubes, and around the head of the lifters. if you look down the pushrod tubes you'll see there isn't a lot of room.
I like the idea of a vac pump and would like to try one out at some point, but if your rings are sealing 95%+ then just a -12 breather on the case/heads back to the drysump tank works just fine. I have placed a map sensor on the crank case this year to monitor the pressure to give a good indication of ring sealing at the higher boost levels. trying to get an indication of how the cylinders are holding up to cylinder pressures were subjecting them too.
Martin
OFF/500
Andy Sykes
« Reply #733 on: April 11, 2014, 19:46:23 pm »
I get what you are saying, but im trying to pull a neg pressure in a box down a 3/4 " hose so my thinking is the best place is the place that has least amount oil flying about.
 I also get the push rod tube thing but I would guess the space on 4 push rods has more surface area than 3/4"  tube. I can't see putting the fitting in the centre of the block is going to make any advantage, As the presure has to be equal in the case to pull a neg pressure . I have a limited understanding of vacuum pumps and vacuum from my days working on vacuum packing machines so the above makes sense to me lol
Not saying your wrong just want the understanding
Cheers Andy
johandryselius
« Reply #734 on: April 12, 2014, 01:09:14 am »
Andy!
Love the hinges!! Smiley
Johan
1600cc Challenge Porsche 356:
9,4386@242,48km/h; 6,1229@193,15 km/h 1,50 60 foot @ Kjula Dragway 2022
1600cc Challenge Buggy:
9,5112@225,42 km/h; 6,0624@185,85 km/h 1,38 60 foot @ Kjula Dragway 2020
Europes quickest ProStock VW:
9,8538@218,80 km/h; 6,2569@176,24 km/h 1,35 60 foot @ BRC Tierp Arena 2014
Berger
www.bugrent.no
« Reply #735 on: April 12, 2014, 14:19:05 pm »
If you put vacuum on the valve cover, you will make it very hard for the oil coming from the rockers to return to the cranck case. I would never do that. I think venting the valv covers at all is a bad idea. Keep up the good work Smiley
This is my simple religion:
-Be cool
-Don't be an asshole
Andy Sykes
« Reply #736 on: April 12, 2014, 18:15:45 pm »
Thanks guys I guess I can tap the top of the pauter case to fit an -an16 fitting I'm mostly worried about sucking oil up ?
 just about finished it today
I've use 316 stainless for the hinge pin and sleeved the female part with 316 too to stop any wear on the hinge I will also do this on the door hinges
Cheers Andy
« Last Edit: April 12, 2014, 18:32:35 pm by Andy Sykes » Logged
Andy Sykes
« Reply #737 on: April 14, 2014, 19:43:15 pm »
MKII door hinges from 30mm billet taken 5 hours so far
They may get lighter yet
And transmission parts arrived today £720 don't go far
Send these off the Germany tmw Smiley
Cheers Andy
Andy Sykes
« Reply #738 on: April 15, 2014, 19:13:01 pm »
Hinges 98% done taken about 12 hours so far
I dread to think the amount of hours spent on this car so far
Cheers Andy
Andy Sykes
« Reply #739 on: April 16, 2014, 19:58:40 pm »
Started on the hardline for the turbos been waiting a while for the an6 to come todo the oil and water ( yes I said water lol )
And started on the pedal box this will take some time
Cheers Andy
Andy Sykes
« Reply #740 on: April 17, 2014, 17:08:53 pm »
bit more AN6 hardline arrived so I've finished the feeds and returns
bit more on the pedal box
that's it im off home
cheers andy
Andy Sykes
« Reply #741 on: April 23, 2014, 19:46:42 pm »
Little bit more done had to machine the compressor housing today
Billet compressor wheel
Trial fit with boost tape
Did a bit more on the pedal box stop and go bits machined them and needed to bend them a bit so made a former from an old Russian diving cylinder I've had for years
Turned out good I think
Cheers Andy
Andy Sykes
« Reply #742 on: April 25, 2014, 20:42:49 pm »
Bit more, been busy at my day job but you can fit a lot in, in 24hrs lol
4x4x8 bit of billet soon to be turned into a brake and clutch resevoir  i hope, I think it's going to take at least 14 hours.
Lots of material to remove yet maybe 4x4 was a bit big
Cheers Andy
Andy Sykes
« Reply #743 on: April 26, 2014, 19:24:29 pm »
Getting there slowly
Still more material to come off yet and tidying up and come up with the sight glass solution
Cheers Andy
Andy Sykes
« Reply #744 on: May 11, 2014, 19:51:59 pm »
Been busy at the mill so not much going on 4" velocity stacks arrived need cutting and welding but you get the idea
Then brick being leak tested
Towing eye in construction
Cheers Andy
Andy Sykes
« Reply #745 on: May 15, 2014, 20:14:36 pm »
Bit more on the peddal box
Cheers Andy
Andy Sykes
« Reply #746 on: May 16, 2014, 22:04:04 pm »
Bit more done today mostly exciting things from America lol
Fuel filter can't get over how big it is those fittings are an12 just shows how much fuel is going to flow
Bit more on the pedal box
Cheers Andy
Andy Sykes
« Reply #747 on: May 18, 2014, 18:50:43 pm »
Bit more
Cheers Andy
Andy Sykes
« Reply #748 on: May 19, 2014, 19:40:58 pm »
Little bit more
Steel m6 nut and bolt
Ti nut and bolt
So a massive 320 grams or 11 ounces saved lol
Last little bit of the peddal box just need a few bits welding up
Cheers Andy
Andy Sykes
« Reply #749 on: May 21, 2014, 22:28:16 pm »
So I decided to make my own hydraulic throttle yes a cable would be easier, but I had the idea so had to make it so lol
Cylinder rod and piston
You can only just see but that's the piston
That's one  end
Just got to make this end work
And some turbo bits
At least the are the real deal the tial ones I got turned out to be fake, very good fakes but fake lol
Cheers Andy
« Last Edit: May 21, 2014, 22:34:01 pm by Andy Sykes » Logged
