October 12, 2026, 16:12:11 pm
| | |-+  My 65 race car
Pages: 1 2 3 [4] 5 6 ... 32 Print
Author Topic: My 65 race car  (Read 708741 times)
Andy Sykes
« Reply #90 on: February 01, 2012, 15:02:43 pm »
no worries hi jack away i thought i was just one of my stupid ideas
cheers andy
Andy Sykes
« Reply #91 on: February 01, 2012, 15:47:23 pm »
all my 930 cv bits turned up today from the states Smiley
just got to get more drive shafts now
cheers andy
« Reply #92 on: February 01, 2012, 17:29:03 pm »
cheers andy
Sump heater was one of the things I thought about when I used to race years ago, but never got around to trying... Cheesy The car always seemed to go better when the oil was warm but the heads were cool!
« Reply #93 on: February 01, 2012, 23:09:44 pm »
Cant tell from the pic,but does the oil actually boil? it does with my heater
Richie, I'm curious about this! Is it to get the oil up to temperature without having to start the car and get heat into the heads, or to boil methanol out of the oil like Mike Lawless does? I thought the old car was on E85 and presumed the new one would be too. I didn't think there would be oil contamination issues like with methanol. Also, would you fit it into a regular deep sump or is the new car dry sumped like Andy is doing? I've not seen the new car in the flesh so I'm intrigued by it. Mine won't be anywhere near as wild but it's nice to see the reasoning behind these little things!
Andy, sorry for the hijack!
neil
Yep dry sump,but I will fit one to the regular wet sump on ther old car,both cars on methanol now,I use the heater to boil out the water & fuel from the oil overnight or in the morning,then I regularly switch it on to pre heat the oil before a run.I still used to see contamination with E85,just not as quickly
Mikes car is wet sump still as well
cheers richie
Andy Sykes
« Reply #94 on: February 02, 2012, 19:43:11 pm »
Rear stays are in for the seats just need tugging in now
Cheers andy
« Last Edit: February 02, 2012, 19:45:03 pm by fast65 » Logged
Andy Sykes
« Reply #95 on: February 05, 2012, 09:42:57 am »
Bruce is doing a top job of the prep making the aero catches fit nice
I spent a bit of time today going over the race technology kit reading how to mount etc
DL1
Video 4
One of the small hi res cameras
Just got to make it all work now lol
Cheers andy
Fasterbrit
« Reply #96 on: February 05, 2012, 10:56:02 am »
Dude, the inside of your car is going to look more Apollo 13 than race car  Grin
Just remember to keep your Gimbal pointed dead ahead and all should be fine. Unless of course you run out of battery power  Cheesy
www.air-kraft.com
www.marcomansiperformance.com
Andy Sykes
« Reply #97 on: February 05, 2012, 18:03:06 pm »
 Cheesy That's the plan I'm hoping apart from changing gears  Cheesy the rest will sort its self out hen I can watch my cock ups over and over again until I get it right
Cheers andy
dannyboy
« Reply #98 on: February 05, 2012, 20:02:49 pm »
make sure you got a cameara pointing in front so i can see myself in the next lane  Grin
8.77@156.8mph
O/FF 60
Fasterbrit
« Reply #99 on: February 05, 2012, 22:06:14 pm »
Good one!  Grin
www.air-kraft.com
Andy Sykes
« Reply #100 on: February 05, 2012, 22:21:25 pm »
Don't worry I've Got Dannycam in the back for you  Grin
dannyboy
« Reply #101 on: February 05, 2012, 22:52:56 pm »
you shuld deffo put one on your face to see what face you pull when it hooks up  Grin Tongue
8.77@156.8mph
O/FF 60
Andy Sykes
« Reply #102 on: February 05, 2012, 23:17:16 pm »
I think the mic will tell you all  Cheesy Cheesy
Andy Sykes
« Reply #103 on: February 07, 2012, 17:43:59 pm »
paint arrived a Bruce's today Smiley
i had an idea to increase the surface area of the oil heater pockets so made 4 today
i haven't test them yet i will do that tmw
my chute equipment arrived today
looks good apart from the release handle that looks like a fork handle so i will make a nicer looking one
The Hobbit was getting busy on the last few cage bits
nets in
cheers andy
Andy Sykes
« Reply #104 on: February 08, 2012, 15:28:49 pm »
not much done today but i made the chute release handle
justt needs tigging up now
cheers andy
Andy Sykes
« Reply #105 on: February 08, 2012, 19:31:26 pm »
All tigged up
I like it lol
Cheers andy
Andy Sykes
« Reply #106 on: February 09, 2012, 16:48:50 pm »
so trail fitted the release handle dosent look too bad Smiley
i did a bit of testing on the heater pockets to see if the heat was less concentrated at the tip and seams to work ok took about 30 mins to warm 1L of oil to 90 deg C
bruce is cracking on with the body work as well
firewall is nearly done too
some of the last bits have arrived
turbosmart fuel reg
and on the safety side a battery isolator i was going to fit the standard type but didnt like the look of it sticking out of the car so went for this
its controled via an external/internal push button so power can be turned off instantly and is MSA approved
cheers andy
Richyrich
« Reply #107 on: February 09, 2012, 23:58:50 pm »
Loving this build, great ideas and fantastic workmanship, keep up that good work buddy....
Andy Sykes
« Reply #108 on: February 11, 2012, 20:10:22 pm »
Cheers thanks
Getting to a good bit  Grin
Cage is going this colour
And parts are getting some treatment by Bruce at WRP
So I will take the engine out later this week and take to air cooled performance and fit the quaife into the G50 while the paint is going on
Cheers andy
« Last Edit: February 11, 2012, 20:15:41 pm by fast65 » Logged
Fasterbrit
« Reply #109 on: February 13, 2012, 09:41:50 am »
Hi Andy. Will your car make drag day? Cheers, Matt
www.air-kraft.com
Andy Sykes
« Reply #110 on: February 13, 2012, 23:05:25 pm »
Hi no I don't think it will be ready but I'm going to try started on designing the mounting plates for the bearing carriers
Cheers andy
« Last Edit: February 13, 2012, 23:07:12 pm by fast65 » Logged
Andy Sykes
« Reply #111 on: February 14, 2012, 18:50:00 pm »
a bit of progress today
new tool arrived so had to have a play with that lol
this as as far as ive got with the A arms until the 6mm plate comes
cheers andy
« Reply #112 on: February 14, 2012, 19:17:58 pm »
Andy,
can you tell me why they did the harness bar with a big arc in it,then had to make the seat supports long to reach,is there something I am failing to see that you needed the bar bent that way?it just looks like a straight bar would have saved some time and effort,and also weight?
The IRS arms interest me,is that hub alluminium? its hard to tell in that picture,how long are you making the arms?
Andy Sykes
« Reply #113 on: February 14, 2012, 20:08:32 pm »
Hi that bar was going to be the main hoop but on one of the bends the molly cracked as we bent it a bit too tight so we used it as the seat bar I did think the seat would end up a bit further back as well , I couldn't put a straight bar in anyway as I wouldn't fit in the seat if I did, I can't get in dannyboys car as his seat bar is straight  that's the trouble being 6'4" lol the a arms will work out standard length and the bearing hubs are aluminium
Cheers andy
dannyboy
« Reply #114 on: February 14, 2012, 20:10:38 pm »
you do look silly when sitting in my car  Grin Cheesy
a bit like bowser in mario kart Grin
8.77@156.8mph
O/FF 60
Andy Sykes
« Reply #115 on: February 14, 2012, 20:14:42 pm »
 Cheesy Cheesy Cheesy
But not as stupid as I look here
« Last Edit: February 14, 2012, 20:50:39 pm by fast65 » Logged
« Reply #116 on: February 14, 2012, 20:51:54 pm »
Thanks for the explanation,the 6ft4 bit would make a difference Grin If you are keeping stock length for the arms,why not use the stock arms?
Andy Sykes
« Reply #117 on: February 14, 2012, 21:13:18 pm »
Hi I have got some narrowed IRS arms but the car seams to sit too high with no camber, my thinking is if I make arms with 0 camber I can set the height of the front and rear without worrying about camber change as who knows how many tweaks I've got to do on the chassis to get the car right hope that make sense tell me if I'm being stupid ? Plus I like making things lol
Cheers andy
« Reply #118 on: February 14, 2012, 21:50:19 pm »
I still think you're too close to the steering wheel in that pic.  Ouch when your knees hit that bar!
Andy Sykes
« Reply #119 on: February 14, 2012, 22:13:06 pm »
Hi It's no as close as it looks my feet went on the pedals and my arse wasn't right back in the seat when we fitted the seat my knees would worse case go under the bar
Cheers andy
