October 12, 2026, 18:10:29 pm
| | |-+  My 65 race car
Pages: 1 ... 30 31 [32] Print
Author Topic: My 65 race car  (Read 709052 times)
Andy Sykes
« Reply #930 on: October 10, 2015, 20:45:09 pm »
So not exactly progress but more weighing the car and moving things, not much more to do until I start the wiring the only part of this I have certificates for
Fuel tank is 15kg
Oil is 12 kg
Battery 19 kg
Me 115kg
Andy Sykes
« Reply #931 on: October 21, 2015, 16:11:08 pm »
few updates made a start on the wiring, I got out what I'm using lol
made a few parts for the steering
fitted a drive shaft from a 997 3.8 twin turbo auto, the cvs are the same size a s a 930 and the shaft is 30 mm rifle drilled
cheers andy
« Last Edit: October 21, 2015, 16:21:47 pm by Andy Sykes » Logged
Andy Sykes
« Reply #932 on: November 09, 2015, 08:30:49 am »
Bit more machine a flywheel for a flouter plate can't say I enjoyed it far to much concentration lol
Made some more tube
Cheers Andy
« Reply #933 on: November 09, 2015, 15:56:05 pm »
Good job on the flywheel, and your welding looks like its getting better and better more you do Cool
Andy Sykes
« Reply #934 on: November 09, 2015, 19:26:11 pm »
Thanks it took me ages to do the flywheel thanks for the loan of the floater, one step closer. I keep practicing at this welding thing it's made a big difference since I got a Pyrex gas lens and my dad got me 3M speed glass mask I can see, now even electricians can weld now lol
Cheers Andy
« Reply #935 on: November 09, 2015, 20:43:28 pm »
Cheers Andy
They are really nice welds. What's the benefit to the Pyrex glass lens and speed glass?
Andy Sykes
« Reply #936 on: November 09, 2015, 21:23:51 pm »
With my new mask I can actually see what's happening so that has helped me with the control, as for the Pyrex gas lens I don't understand exactly but it make the gas flow in a better way, I can do the same thing with a standard cup and it weld ok but no way near a good as if use the other they aren't cheep but they work for me
Cheers Andy
« Reply #937 on: November 09, 2015, 22:24:58 pm »
Might treat my dad then Smiley
Andy Sykes
« Reply #938 on: November 15, 2015, 23:30:58 pm »
Made this little item today from Delrin so nice to machine
Awesome material
Cheer Andy
Andy Sykes
« Reply #939 on: November 22, 2015, 16:05:36 pm »
bit more
little by little and I may get this done
cheers andy
Andy Sykes
« Reply #940 on: November 26, 2015, 19:19:02 pm »
Bit more
Exhaust in production
Andy Sykes
« Reply #941 on: November 27, 2015, 18:38:09 pm »
Few more tubes
mr horsepower
« Reply #942 on: November 27, 2015, 22:54:32 pm »
Realy Work of art
Amazing craftmanship shown here
Keep on going andy
Gr henri
vwhelmot
« Reply #943 on: November 27, 2015, 23:59:36 pm »
Lovely tig work going on. I managed to distort a v band flange quite easily while welding one a while back. I'm also reading that they need some sort of gasket either copper or fibre to make them seal 100% too. True?
Andy Sykes
« Reply #944 on: December 02, 2015, 17:18:25 pm »
Realy Work of art
Keep on going andy
Gr henri
thanks I keep on going bit by bit paying for all stuff takes some time as well but I will get there
cheers andy
Andy Sykes
« Reply #945 on: December 02, 2015, 17:20:59 pm »
thanks you can get the gaskets, but I will seal mine with high temp Loctite silicone
cheers andy
Andy Sykes
« Reply #946 on: December 02, 2015, 17:26:54 pm »
both sides done now have make the tail pipes off into one tube
and started on the wiring
air shifter going in
cheers andy
Andy Sykes
« Reply #947 on: December 06, 2015, 16:35:18 pm »
so ive started on the electrical systems
that's just part of the engine and transmission harness
cheers andy
ianmac
« Reply #948 on: December 08, 2015, 23:19:24 pm »
That's a serious wiring loom  Shocked good work  Cool
Andy Sykes
« Reply #949 on: December 19, 2015, 17:12:34 pm »
The wiring and electronics should be the best bit as its my job
Air shifter testing I think I may need a spring return cylinder
https://youtu.be/LluUJvIK1gE
Andy Sykes
« Reply #950 on: March 20, 2016, 16:40:44 pm »
Well a few months off due to working most days but I've managed to do a bit today
spoolin70
« Reply #951 on: November 18, 2016, 14:21:38 pm »
Any updates Andy ?
Just seen your for sale advert and wondered if your build is still progressing?
Or is the engine sale to make way for something bigger  Grin
Darren
Chip
« Reply #952 on: February 08, 2017, 07:02:00 am »
Looks like you are parting this project out, sad to see it happen!  I also understand that priorities can change quickly and hope all is okay for you and those closest to you.
