November 02, 2026, 19:30:30 pm
| | |-+  My 65 race car
Pages: 1 [2] 3 4 ... 32 Print
Author Topic: My 65 race car  (Read 714558 times)
Andy Sykes
« Reply #30 on: December 15, 2011, 17:15:20 pm »
bit more mechanical work done today Smiley
cheers andy
Andy Sykes
« Reply #31 on: December 22, 2011, 19:50:54 pm »
Car is booked in for the cage to be tagged in the new year the charge cooler has now been modded for ice to go straight in Smiley so that should keep the temps down
also as ive added the dash2 ive found that race technology do an in car camera syetem that put the data from the ECU on the video so you can see were your mistakes are and what the cars doing after a run
<a href="http://www.youtube.com/v/O39VW0D6SxA" target="_blank">http://www.youtube.com/v/O39VW0D6SxA</a>
its mostly for circuit cars but i think it will be good for drag use as you have such a sort amount of time to see whats going on
cheers andy
Fasterbrit
« Reply #32 on: December 22, 2011, 20:25:02 pm »
Some fantastic fabrication going on there! It just seems to get better and better! Quick question: your chargecooler looks like it is ice fed from the top and doesn't run a circulation pump. If so, are you not worried about boundary layer heat formation? Do you have some cunning plans to avoid this scenario that I haven't yet spotted? Looking so trick mate, I love it already  Cool
www.air-kraft.com
www.marcomansiperformance.com
Andy Sykes
« Reply #33 on: December 22, 2011, 20:58:54 pm »
yep sure do
one off coolers going in here the cores are at 45 deg and will ahve a shallow scoop
pumps here
cheers andy
Fasterbrit
« Reply #34 on: December 22, 2011, 21:18:17 pm »
I had a feeling it was sorted Wink good work!
www.air-kraft.com
Andy Sykes
« Reply #35 on: December 23, 2011, 12:40:42 pm »
cheers thanks a few more pics
cheers andy
Andy Sykes
« Reply #36 on: December 23, 2011, 21:51:17 pm »
It's been like Xmas here today the wings I ordered from CSP turned up in two days Smiley
And my drive shaft parts have been finished or my range rover driveshaft idea
Cheers Andy
Andy Sykes
« Reply #37 on: December 24, 2011, 13:51:37 pm »
Trial fit of the drive shafts looks ok Cheesy
Cheers andy
tikimadness
« Reply #38 on: December 24, 2011, 17:40:21 pm »
That looks sturdy enough Grin
Do you know how much torq it can handle?
Michael
NIDGAFWYT
Andy Sykes
« Reply #39 on: December 24, 2011, 19:01:30 pm »
Michael
I'm not sure lets hope it's less than the motor makes lol
Cheers andy
Fasterbrit
« Reply #40 on: December 24, 2011, 20:28:51 pm »
Looks cool, but not sure those shafts look like they can handle 500 bhp. What size are the four bolts that connect to your adapters? Hopefully they are at least M10? Not trying to diss your project as I think it's ace, but you don't want to snap a drive shaft at speed! The wall would beckon!  Shocked
www.air-kraft.com
Andy Sykes
« Reply #41 on: December 24, 2011, 21:01:52 pm »
I get what your saying I did think of this but I'm sure they,jgfye will be ok, my cousin races comp safari land rovers with range rover props. I have used the standard bolt holes that are 8mm so it's m8 with 4 high tensile m8s, you've put doubt in my mind know lol I can soon make m10
Cheers andy
« Last Edit: December 24, 2011, 21:03:26 pm by fast65 » Logged
Fasterbrit
« Reply #42 on: December 25, 2011, 14:55:58 pm »
There is absolutely no way 400 - 500 hp and slicks is going to transmit thru 4x M8 bolts. I reckon the first time you 'hook up' properly you will snap those bolts like twigs. I doubt 4x M10 would survive for too long either. 930 Cvs run 6x M10 and are considered to be safe for 500+ ponies. I really don't want to cast doubt, but from an engineering perspective you have a weak link with potential to ruin an amazing car. Go for 'belts'n'braces' amigo - you don't want a weak link issue messing with your psyche!
www.air-kraft.com
Andy Sykes
« Reply #43 on: December 25, 2011, 18:16:27 pm »
I did have some shafts made 930 cvs one end and bus the other but I was worried about the bus CVs there's enough room on the RR drive shafts for me to make m10 and also 2  10mm dowls , what CVs are others running?
Cheers andy
Fasterbrit
« Reply #44 on: December 25, 2011, 20:02:23 pm »
Most big turbo cars favour 930 Cvs on both ends. You can buy 930 stub axles that fit straight on to TyPe one a-arms. They are cro-mo and very reasonably priced. Drive shafts can be bought in most lengths with 930 splines on either end. The dune buggy guys run them in the US all the time. Do an Internet search and you will find two or three suppliers stateside that will list everything you need. Can't remember exactly where mine came from as it has been a while. If you get stuck, I am pretty sure I have a spare pair of axles kicking around the workshop.
It might be worth trying your RR approach, but I would seriously look into the engineering aspect as there is a rediculous amount of force going thru those bolts. Plenty of type one six M8 bolt setups shear with only moderate hp, so it's a foregone conclusion that your setup will fail unless you radically beef up the bolted side of things. M10 and two M10 dowels may well work, but then a 930 Cv is going to be stronger in the long run. Hope this info helps dude. Matt
www.air-kraft.com
Andy Sykes
« Reply #45 on: December 25, 2011, 21:07:54 pm »
thanks for the reply matt i found the stubb axles on the samba at first i was using 944 alloy arms so had to stick with the smaller cv, i didnt think you could get the 930 stub axles but i think that may be the way forward if the stubs are any good
cheers andy
« Last Edit: December 25, 2011, 21:34:13 pm by fast65 » Logged
Andy Sykes
« Reply #46 on: December 27, 2011, 18:18:29 pm »
Thought I would add a few pics of the G50 going in
Cheers andy
Eric Ellis (57HotrodVW)
Just wait, you'll see...
« Reply #47 on: December 27, 2011, 19:09:23 pm »
Lots of cool stuff/trick work going into this build. Please keep the updates coming
Andy Sykes
« Reply #48 on: December 28, 2011, 16:38:57 pm »
Trial fitted the wider wings today looks like plenty of room for 8" slicks Smiley
Cheers andy
Andy Sykes
« Reply #49 on: December 29, 2011, 19:45:44 pm »
hi guys im planning on ordering these next month anys veiw good or bad before hand?
Fronts
Rears
Cheers andy
Ragtop
8.93 at SCC 2012
« Reply #50 on: December 29, 2011, 20:02:13 pm »
Awesome looking rims and also from what I understand good quality as well, keep up the good work
Andy Sykes
« Reply #51 on: January 04, 2012, 21:13:50 pm »
cheers thanks:) bit of an update, paint and engine build now booked in for this month and my 930 cv with cromo cages arrived today from the states, with dates coming together it feels like im getting there now Smiley
chers andy
Fasterbrit
« Reply #52 on: January 04, 2012, 23:00:19 pm »
Those wheels are the badger's nadgers  Cool
Great choice, it's going to look fantastic - pure class!
www.air-kraft.com
dannyboy
« Reply #53 on: January 04, 2012, 23:57:16 pm »
the fronts will be the rims i fit when funds allow  Cool
8.77@156.8mph
O/FF 60
Andy Sykes
« Reply #54 on: January 05, 2012, 20:50:17 pm »
Cheers thanks  Grin New date for my diary the cage is being inspected on the 19th for 8.5
Cheers andy
Andy Sykes
« Reply #55 on: January 09, 2012, 18:53:48 pm »
Slight change in wheels  Roll Eyes pick these up tmw  Grin
Cheers Andy
dannyboy
« Reply #56 on: January 09, 2012, 19:04:52 pm »
good choice andy super cool wheels Cool
8.77@156.8mph
O/FF 60
Fasterbrit
« Reply #57 on: January 10, 2012, 21:45:11 pm »
Can't believe Prosser let those rims go!  Shocked
Rare set of wheels and very cool Wink
www.air-kraft.com
Andy Sykes
« Reply #58 on: January 10, 2012, 22:31:13 pm »
I'm chuffed to bits with them
img]http://i71.photobucket.com/albums/i149/gluemixer/2f43bfdd.jpg[/img]
how do you like the 22 carrat plated nuts   Grin
cheers andy
Andy Sykes
« Reply #59 on: January 12, 2012, 16:27:22 pm »
woo hoo cage is tagged to 8.5
had to add a bar before Geoff came
as we hadnt boxed into the chassis on the rear due to the bulges in the floor for the charge cooler coolers
couldnt wait any longer had to just put a rim on to see what it will look like thats the 7" rim
with the wing on i dont think the 8" will be an issue Smiley
cheers andy
