August 12, 2026, 18:22:25 pm
My 65 race car
5
6
7
32
Topic: My 65 race car (Read 691635 times)
Andy Sykes
Re: My 65 race car
Reply #120 on:
February 18, 2012, 18:50:49 pm »
i got a whole day in the workshop to and ive nearly completed one A Arm
it all started here
then two
cutting up the CDS tube
and one nearly done
thast the easy bit ive got to make the other exactly the same no thats the challenge
cheers andy
Andy Sykes
Re: My 65 race car
Reply #121 on:
February 19, 2012, 15:41:33 pm »
well i went out today to get some printer ink and fell into the workshop
this is how they will fit
TIGed up the bosses didnt turn out too bad i dont do much welding
cheers andy
Andy Sykes
Re: My 65 race car
Reply #122 on:
February 21, 2012, 18:52:51 pm »
good news is ive got my car back now to go to bruce for painting
ive finished the other arm all i have to do if fab up a bracket for the coil overs
for a bit of extra strength i plug weled the bosses in as well
cheers andy
Andy Sykes
Re: My 65 race car
Reply #123 on:
February 22, 2012, 20:33:45 pm »
The java charger has reached the paint shop woo hoo it's down hill now
Cheers andy
Richyrich
Re: My 65 race car
Reply #124 on:
February 23, 2012, 00:42:12 am »
Nice work Andy, Oh how i miss a workshop
Andy Sykes
Re: My 65 race car
Reply #125 on:
February 24, 2012, 17:17:13 pm »
bit done today started taking the car apart again
transmission out
i like this bit
time to take the diff out
ring gear on the quaife just need the new bearings now and find out if i need any preload i havent spotted anything yet but there maybe shims behind the bearing but not checked that yet
cheers andy
Andy Sykes
Re: My 65 race car
Reply #126 on:
February 26, 2012, 10:28:07 am »
Thanks to ricola I have the diff set up details all looks v easy
Just got to get hold of shims now if I need any
Cheers andy
Andy Sykes
Re: My 65 race car
Reply #127 on:
February 27, 2012, 14:21:20 pm »
thought i would weld in the heater pockets and give it a try
20amps needed for all 4 plugs
and in one hour we have just over 90 Deg C and 50 Deg C in the oil feed line
so looks like that works
cheers andy
Andy Sykes
Re: My 65 race car
Reply #128 on:
March 06, 2012, 19:27:39 pm »
I thought I would have a go at making the breather/catch tank for the VAC pump
Baffles and 4" tube
Baffles welded in place
All welded up didn't turn out too bad I defo need to practice welding aluminium lol
Cheers andy
Last Edit: March 06, 2012, 19:29:54 pm by fast65
61ragtop
Re: My 65 race car
Reply #129 on:
March 07, 2012, 11:35:39 am »
Andy
What size are your front runners
Getting mine this week not sure if I should go for 22" or 24" tall
Cheers James aka beetleragtop
Andy Sykes
Re: My 65 race car
Reply #130 on:
March 07, 2012, 13:30:35 pm »
hi James mine are 22"
cheers andy
Andy Sykes
Re: My 65 race car
Reply #131 on:
March 07, 2012, 18:32:21 pm »
Got the car back for a few days while the paint shop is busy and started to fit the a arms
Got my pencil out to design the brakets I have moved to 22 mm hole as it was going to be too close when I welded the brackets on
Started cutting out
And then had to try one of the new wheels on
And that was about it today but I have changed my mind yet again I'm completely changing the motor now to a 4" oxyboxer as after a few discussions my T1 block is just not going to take it
so here we go again lol
Cheers andy
Re: My 65 race car
Reply #132 on:
March 07, 2012, 19:00:12 pm »
Andy
i was thinking before you need to get those A arms mounted before paint but didnt want to interfere
So why do you think your type 1 wont be enough,there are examples making over 700hp still with comp elim heads and flat tappet cam,my turd in the old cab makes enough power to go 8s,its just the driver that isnt up to it yet
what advantages do you see with the 4inch oxyboxer?
Andy Sykes
Re: My 65 race car
Reply #133 on:
March 07, 2012, 19:26:29 pm »
Hi riche interfere when ever you like that's why I post to get others opinions
,I know a bit about engines a very small bit lol ( I'm a sparky) the main reason is I started building this a few years back planning on 300 bhp as you can see its gone a bit mad since. I was always worried about over 400 bhp on an 8 dowel. I have been told that will be fine if i wedgemate it but in my silly brain I can't get the idea of the the flywheel coming off. The advantages I can see is smaller crank and stronger case. I may be a bit of a fool but I do like like making things work and trying things. I think my main problem is I did my apprenticeship at BR and they overengineer everything lol
Cheers andy
Re: My 65 race car
Reply #134 on:
March 07, 2012, 20:24:47 pm »
I am with you on trying things and making them work,I just like to actually drive it to see if it does before I change my mind again
Yes there are limitations to 8 dowell only cranks,I went that way when it was a nitrous car,I wegemated it when I 1st went turbo,that was about 9 years ago I think,that engine still lives today with the same crank/flywheel and its still on standard size,its had 2 other owners since though.
Mine was still 8 dowelled with wedgemate when it ran the 9.23@152 so it is plenty strong.
The 4inch bore area does give more power potential that 94mm bore,i dont see why you would go smaller on the crank though? the main 2 problems with the 4inch stuff is cost,and availability,its hard enough getting quality parts for 94 bore in a reasonable time scale,4inch seems to take years longer,anyway enough of my ramblings,keep on progressing forward
BR? british rail? if so that explains why nothing ever gets finished
dannyboy
Re: My 65 race car
Reply #135 on:
March 07, 2012, 20:40:38 pm »
[/quote]
dont say that he is going to be doing some work on my car tomorrow
8.77@156.8mph
O/FF 60
Andy Sykes
Re: My 65 race car
Reply #136 on:
March 07, 2012, 20:58:43 pm »
You pair of wankxxs l
I do finish things I've got two kids
the wife may have another view mind
Richyrich
Re: My 65 race car
Reply #137 on:
March 08, 2012, 00:03:55 am »
Yer Guys, It was also raining and there was leaf`s on the line,
.. didnt mean it, love this build, keep it up Buddy...
Re: My 65 race car
Reply #138 on:
March 08, 2012, 07:53:01 am »
With what we know today about clutches the 8 dowels are not a problem. 400 - 500 - 750 hp... I dont think it even matter but hit it with 150hp, a stage 4 and a angry disc and you can easily snap it off. There is a thread here on The Lounge where you can find the calculations on what a dowel/original style crank can take.
Not sure why I wrote this since you have anyway decided to build a new engine and go the WBX route that is so popular today. I think I even spotted one for sale on TheSamba where they called it Type 5 - Oxy
Keep feeding us with pictures and comments, it is one of my favourite threads here.
Best rgs
BB
Andy Sykes
Re: My 65 race car
Reply #139 on:
March 08, 2012, 19:33:35 pm »
Quote from: BeetleBug on March 08, 2012, 07:53:01 am
Best rgs
BB
Cheers thanks I will have a look on the samba
I've done a bit today took most of the day working out we're things are going to and what room I do and don't have in the back
Finish off the brackets I've gone for M22 bolts very OTT but I think they will be ok lol
Tacked the A arms in place
Got this far
Any input would be great about this bit there's a few more tubes to go in yet so I'm happy but will it work?
Somebody left there heap I'm my workshop today if anybody knows who it is before I clamp it lol
Cheers andy
Last Edit: March 08, 2012, 19:36:41 pm by fast65
dannyboy
Re: My 65 race car
Reply #140 on:
March 08, 2012, 20:00:19 pm »
you were supposed to be working on my car
not welding bits to the neverending story
8.77@156.8mph
O/FF 60
Andy Sykes
Re: My 65 race car
Reply #141 on:
March 08, 2012, 20:28:37 pm »
Quote from: dannyboy on March 08, 2012, 20:00:19 pm
Your turns tmw you can't expect a sparky to do things straight away lol
thejohn66
Re: My 65 race car
Reply #142 on:
March 08, 2012, 22:09:29 pm »
Cheers andy
[/quote]
If you clamp it Andy you will never get rid. If I was you I would have it towed to the pound
Bitburg motor boating club member.
Andy Sykes
Re: My 65 race car
Reply #143 on:
March 08, 2012, 22:12:08 pm »
I did try to sell it to a pikey but it weighs fuck all lol
Fasterbrit
Re: My 65 race car
Reply #144 on:
March 08, 2012, 22:16:18 pm »
Andy... I don't want to chuck a spanner into your works, but you have asked for input, so I will give you some based on my own experience. Your coilover mounts are way too weedy. By the looks of it, they are 2mm wall section mild still box tubing? On my car I managed to bend 4mm cro-mo brackets, so had to beef right up to 6mm thick lowers and 8mm uppers.
You will need springs somewhere in the region of 600-850lbs looking at the pivot points of your mounts and guessing your car's weight. This is obviously a guess, but that translates to a whole load of energy being transferred to that single bracket on launch. If there's one area you need to BR (over-engineer) it's these mounts. Trust me
I would also make a lower mount that spreads the energy over at least two of your a-arm tubes, not one as you have it at the mo. Go for good surface area, and you won't bust it
Regards, Keeno
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
Andy Sykes
Re: My 65 race car
Reply #145 on:
March 08, 2012, 22:39:56 pm »
Quote from: All Torque on March 08, 2012, 22:16:18 pm
Regards, Keeno
That's great info thanks the top mount was a mock up I did think 4 mm would be so I will be upping that know
Cheer mat
Andy Sykes
Re: My 65 race car
Reply #146 on:
March 12, 2012, 16:54:50 pm »
bit done today ive been looking at the fly wheel ive had made im sure i can get it machined for Flange crank that would save a bit og money lol
fitted the bearing housing and trial fitted the brakes before welding the a arms in place
the wheels are on the will need a 30mm spacer
but they are on ish
cheers andy
Last Edit: March 12, 2012, 17:01:37 pm by fast65
dannyboy
Re: My 65 race car
Reply #147 on:
March 12, 2012, 19:04:34 pm »
good work mate did bruce ok the bonnet?
8.77@156.8mph
O/FF 60
Andy Sykes
Re: My 65 race car
Reply #148 on:
March 12, 2012, 19:46:17 pm »
Quote from: dannyboy on March 12, 2012, 19:04:34 pm
Yes mate it got the Bruce seal of approval
thanks again
Andy Sykes
Re: My 65 race car
Reply #149 on:
March 13, 2012, 20:08:52 pm »
Little bit done today made the brackets for the second A arm and tacked in place I need the measure again and check it ok before I mig it in for good
Finished fitting the air scoops into the pop outs
Cheers andy
5
6
7
32
