November 03, 2026, 11:06:19 am
| | |-+  My 65 race car
Pages: 1 ... 12 13 [14] 15 16 ... 32 Print
Author Topic: My 65 race car  (Read 715626 times)
Andy Sykes
« Reply #390 on: December 09, 2012, 17:04:06 pm »
having choped up a few porsche drive shafts over this project the 997 ones seam to be harder and larger Dia theres no way they would cut with a saw they just sat there and nothing happened
so chop saw it was then lol
so they are hollow again but 27mm dia
cut and shut them so i can send away to get shorter ones made alway helps will a pattern Smiley
slight angle but i dont think oits too bad but theres not much that can be done about anyway
cheers andy
Sepi
« Reply #391 on: December 09, 2012, 21:38:05 pm »
slight angle but i dont think oits too bad but theres not much that can be done about anyway --- You can't be serious with these drive shafts  Huh
Andy Sykes
« Reply #392 on: December 09, 2012, 21:46:46 pm »
Why what's wrong with them lol
I think you missed the point I've done this before cut them weld them and send them off to the the guys that machine quaife driveshafts and have them make new ones I may get a few sets done as spares
Cheers andy
dannyboy
« Reply #393 on: December 09, 2012, 22:56:52 pm »
Cheers andy
i say run em  Grin
8.77@156.8mph
O/FF 60
Andy Sykes
« Reply #394 on: December 09, 2012, 23:37:51 pm »
I think they will fine for he first 6 months  Tongue
Sepi
« Reply #395 on: December 10, 2012, 06:52:19 am »
Cheers andy
..Ok, I jumped to your thread without reading what was you plan. Experimental way indeed to build!
i say run em  Grin
Andy Sykes
« Reply #396 on: December 10, 2012, 20:31:34 pm »
Little bit done tonight welded on the HX52 flange and started reworking the wasts gates
Not much I acn do with this lot till the motor comes  Roll Eyes
Cheers andy
« Reply #397 on: December 10, 2012, 23:41:43 pm »
Andy
what size tubes have you got there for the header? and how did you come to chose that size?
Andy Sykes
« Reply #398 on: December 10, 2012, 23:57:05 pm »
Hi
It  1 3/4 inch, I was advised it would be the correct size, for the size and type of turbo I'm using
Cheers Andy
« Last Edit: December 12, 2012, 11:01:17 am by fast65 » Logged
« Reply #399 on: December 12, 2012, 18:22:38 pm »
Hi
Cheers Andy
By pauter? I thought the flanges they supplied with there heads were for bigger tube than that?
Andy Sykes
« Reply #400 on: December 12, 2012, 20:17:57 pm »
Hi no not by Pauter they do 1.81" or 2" indeed to be a bit smaller than 1.8 as holsets as you know work on pulse rather than heat and flow. Should be able to take up the small difference when I tig up the inside of the flange
Cheers andy
Martin
Cash Converter....
« Reply #401 on: December 12, 2012, 20:34:00 pm »
Cheers andy
I didn't know that the Holset turbos's worked differently to other turbos. please explain...
Martin
www.taylormachine.co.uk
OFF/500
« Reply #402 on: December 12, 2012, 21:30:50 pm »
Ok,
if you are happy with that then go for it Smiley
It just seems small to me on an engine that size, but no one thinks my header on the old car would work, everyone has there own ideas and thats good because we learn that way Smiley
I would be asking the engine builder what to use,they should know better than any internet experts Shocked Wink Grin
Andy Sykes
« Reply #403 on: December 12, 2012, 22:16:26 pm »
Hi Martin
As an electrician I'm no expert in the area as far as I understand its the diesel holsets that use the pulse energy for low end torque I'm sure there are better informed people to explain how or why if if I'm talking shite but that what I've read
Hi Richie
I've just asked the question so lets see what comes back I don't want to waste my time building a header that's too small I do trust a 100% the person that told me to use this size but a second opinion can't hurt I guess
Cheers andy
« Reply #404 on: December 14, 2012, 10:15:25 am »
Hi Richie
Cheers andy
Good plan,cant go wrong with asking Pauter,not many out there with more real life experience of turbo VW style engines Smiley
Andy Sykes
« Reply #405 on: December 14, 2012, 18:46:47 pm »
bit more done 4" all the way lol
first cut a bit worrying lol 4" bends are not  cheap lol
cheers andy
tikimadness
« Reply #406 on: December 14, 2012, 22:27:14 pm »
I'm playing with the same size bends. You are lucky to have such a cutter I do it with a cut of wheel  Huh
Michael
NIDGAFWYT
Andy Sykes
« Reply #407 on: December 14, 2012, 22:32:45 pm »
Michael
Lol just a tip for you put a pipe clamp around the tube and cut your way around with a hack saw bit by bit worked for me and always square
Cheers andy
Andy Sykes
« Reply #408 on: December 15, 2012, 15:08:56 pm »
so little bit more doen rework the waste gates
now with added waste gate exhaust
cheers andy
Andy Sykes
« Reply #409 on: December 17, 2012, 18:13:06 pm »
bit more nothing exciting
tacked in the lambda sensor bosses
vband and wastegate flange
looks better the the vbands on i think
cheers andy
Martin
Cash Converter....
« Reply #410 on: December 18, 2012, 11:08:55 am »
2 lambda Bosses?
Did an Essex Escort donate the tail pipe trim?   Wink
Martin
OFF/500
Andy Sykes
« Reply #411 on: December 18, 2012, 12:45:08 pm »
2 lambda Bosses?
two becouse im gready lol no the second one is for when the car is tuned so i dont have to remove my own one and screw up the wiring, i nicked the trim from a punto lol
cheers andy
« Reply #412 on: December 21, 2012, 14:25:06 pm »
Hi Richie
Cheers andy
Did you get a reply yet Andy? interested to see what they suggest
Andy Sykes
« Reply #413 on: December 21, 2012, 14:26:02 pm »
no didnt get a reply i will chase them up
cheers andy
Andy Sykes
« Reply #414 on: December 28, 2012, 15:56:25 pm »
bit the bullet to day and started back on the body worlk my least favorite part but it got to be done lol
cut the carpet grips off so the channels  can be smoothed and painted
then onto some holes that need welding up my way to do this is using some copper
placing behind the hole
and welding to the copper and the endge of the hole the copper acts as heat sink to take the heat away and also steel wont stick to it so you can just pull it away afterwards and the whole is know gone Smiley
redid the waste gate pipe i didnt like how the last one looked
cheers andy
Andy Sykes
« Reply #415 on: December 30, 2012, 16:59:16 pm »
been thinking alot about what im doing with the frontend but i poped in to work to feed terry the office turtle and thought F**k it and this happened opps
so i guess that the decision made she been on a diet plus i have a bit more room to fit thing in Smiley
cheers andy
tikimadness
« Reply #416 on: December 30, 2012, 17:12:14 pm »
Looks very familiar Grin
Michael
NIDGAFWYT
Andy Sykes
« Reply #417 on: December 30, 2012, 17:36:04 pm »
Michael
I've no idea were I nicked the idea from lol
« Reply #418 on: December 30, 2012, 21:34:43 pm »
You need to feed that turtle more often, little bugger's eaten the front of your car...
Andy Sykes
« Reply #419 on: December 30, 2012, 21:44:56 pm »
Lol he is greedy little f**ker
