May 21, 2026, 00:17:23 am
Latest Member: mvptkfjb
| | |-+  My 65 race car
Pages: 1 ... 26 27 [28] 29 30 ... 32 Print
Author Topic: My 65 race car  (Read 633598 times)
Andy Sykes
« Reply #810 on: August 24, 2014, 14:26:57 pm »
Hi Ron,
Thanks for you kind words, I did look into it and I seam remember that until this year this type of trailer was exempt from testing
Dry sump breather
Cheers Andy
Andy Sykes
« Reply #811 on: August 25, 2014, 19:51:34 pm »
 Bit more roughed out the tank breather
Cheers Andy
Andy Sykes
« Reply #812 on: August 26, 2014, 22:13:35 pm »
Started some testing on the wheelie bar sensor
New piston
Filled the cylinder with oil
Put it in the press
Over 500kg
And next to no movement I think that is in the seals so nothing to worry about the wheelie bar will not move
So know I can make a real one fit a sensor and use to collect data Smiley
Cheers Andy
Andy Sykes
« Reply #813 on: September 01, 2014, 21:48:36 pm »
so ive nearly done the MK2 cant wait to finish it tmw I hope it the parts turn up and bench test it piston is a different again
cheers andy
Andy Sykes
« Reply #814 on: September 02, 2014, 16:26:09 pm »
All done just need to bench test and get some data
Cheers Andy
Andy Sykes
« Reply #815 on: September 03, 2014, 21:27:01 pm »
Bit more billet lol it's getting boring now I know sorry
Roughed out but still lots of hours to go
Cheers Andy
Andy Sykes
« Reply #816 on: September 06, 2014, 14:35:26 pm »
Bit more done
Still more to take out but it's taking shape
Cheers Andy
Andy Sykes
« Reply #817 on: September 07, 2014, 19:57:49 pm »
height adjuster MK1
quite pleased how this is turning out lets hope it works lol
cheers andy
Andy Sykes
« Reply #818 on: September 08, 2014, 21:46:33 pm »
Shifter mount to suit my long arms
Cheers Andy
Andy Sykes
« Reply #819 on: September 12, 2014, 22:38:04 pm »
Had news today and pictures that my seqencial gearset is done and complete and dam it's a work of art and looks very strong, shame I can't show you as been asked not to buy the builder realy can't wait to get hold of the trans in a few weeks it's going to be very special
And a new tool for the cave Smiley
Cheers Andy
« Reply #820 on: September 13, 2014, 00:23:09 am »
Andy --- Everything is great!!!! -- -- looking at the wheelie bar sensor, I'm thinking you're going to need something more positive than a spring to keep that together,,,,, Especially if has to hold up the wheelie bar -- -- maybe reduce the size of the piston behind the O-rings then drill a offset hole and install a c-pin to hold it -- or put a flat on the piston and drill/tap a hole for a bolt that doesn't bottom out?Huh
Andy Sykes
« Reply #821 on: October 04, 2014, 11:59:26 am »
Hi thanks I did draw it with bolts through but I wanted to make sure it can move even a very small amount
Works out to around 600psi @ 450kg of pressure
I'm still here been busy at real work and also helping prep the car for paint
Mocked up the cable shifter
Made a Heater for the transmission
And the last parts for the sequential trans have arrive so time to assemble it the gears have all been made
Cheers andy
Andy Sykes
« Reply #822 on: January 31, 2015, 14:22:16 pm »
transmission is complete
looking forward to getting it
spoolin70
« Reply #823 on: February 01, 2015, 09:36:35 am »
Any updates on the rest of the car Andy ?
It used to seem like nearly every day you was making something new  Cheesy
Darren
« Reply #824 on: February 01, 2015, 10:38:15 am »
Where have you been Andy? Your daily updates have been missed so thank you! Any chance you will get the car ready for the coming season?
Best rgs
BB
Andy Sykes
« Reply #825 on: February 01, 2015, 11:47:42 am »
I have been a bit busy in the last 4 months in my real job
making this lot work together
its all running in auto know taken over 20000 man hours to get it done lol
Andy Sykes
« Reply #826 on: February 01, 2015, 11:49:10 am »
but I have done this little bit of modification to the rear end
so im upto date now lol
Andy Sykes
« Reply #827 on: February 01, 2015, 20:19:29 pm »
bit more suspension stuff
and started on the rear bearing housings
cheers andy
Stripped66
« Reply #828 on: February 02, 2015, 13:28:10 pm »
Did you manage to get the kinematics to jive without binding, or do you plan to remove some control arms?
« Last Edit: February 02, 2015, 13:33:21 pm by Stripped66 » Logged
Andy Sykes
« Reply #829 on: February 02, 2015, 18:54:27 pm »
hi
its all moves together ok but the front control arm is going as its not needed as I've moved the pivot point of the car to nearly the centre
Stripped66
« Reply #830 on: February 02, 2015, 20:06:50 pm »
hi
I relocated the mount of the front (lower) control arm to where you've placed your trailing links; I figured it would be easier to tune anti-squat than where it was mounted on the Porsche.
Andy Sykes
« Reply #831 on: February 02, 2015, 21:31:53 pm »
looks good I was thinking of moving my rear brake inboard also what trans is that ?
Stripped66
« Reply #832 on: February 02, 2015, 23:57:34 pm »
ZF 4hp22 Tiptronic.
With the 15" wheels and minimal offset, I had no room between the hub carrier and rim to fit a caliper.
Andy Sykes
« Reply #833 on: February 07, 2015, 15:27:25 pm »
yes I may have the same issue  Grin
the transmission is here and im very very happy with it cant wait to get it in the car and start finishing things
cheers andy
« Reply #834 on: February 07, 2015, 20:13:05 pm »
Andy -- Great build and a lot of engine porn there --
You might want to think of putting some rubber or some kind of expansion on your intake -- my 2989 cc engine grows so much, as it heats up, that it has broken exhaust studs on the exhaust and pulled intakes loose.
 I've added expansion joints on the exhaust and rubber on the intake now and those problems have gone away
Andy Sykes
« Reply #835 on: February 08, 2015, 21:20:03 pm »
thanks I have the wiggins to do it just want to see how I get on first I have feeling I will be fitting them lol
spent hours today machining one hub and pressing in the bearing but in very happy with what ive made so far
just need to make the other side now  Roll Eyes
cheers andy
Stripped66
« Reply #836 on: February 09, 2015, 16:57:49 pm »
Are you doing away with the Porsche hub carrier altogether?
Andy Sykes
« Reply #837 on: February 09, 2015, 23:09:03 pm »
yes when I added the extra bars and also tried to machine the camber out of the hubs I gain some toe in so I thought fxxk it ive made everything else so may as well make the hubs lol
« Reply #838 on: February 09, 2015, 23:11:43 pm »
If you showed me the pics on just this last page and told me you were building a space ship I wouldn't doubt you.
Andy Sykes
« Reply #839 on: February 10, 2015, 20:51:41 pm »
im trying my best to build something as fast lol
