July 24, 2026, 04:54:33 am
Carb upgrade
Topic: Carb upgrade (Read 6631 times)
edcraig
Carb upgrade
January 30, 2012, 05:03:43 am »
It was finally time for a carb upgrade, but I wasn't quite sure what I wanted. I was thinking the spanish IDF's or trying to find some good used IDF's or maybe even IDA's. I even considered the 40 HPMX carbs. Anyway...I got lucky and found exactly what I wanted in some 42 DCNF Webers. I was very lucky to find a set of NOS carbs with air filters. I was considering getting some Deano manifolds and linkage, but ending up using Berg stuff. It does look a little clustered up on the shroud compared to the bell style linkage, but it works good. The carbs are fantastic. Big big improvement over the Solexes. I'm going to swap out the filters to the taller Berg versions at some point, but for now I'll use the ones I have. Don't see too many of the Johnny Speed and Chrome filters anyway. I now have some solexes/kadrons for sale if anyone is interested! ;-)
Thanks to Marc Buelher, John Lazenby, and Ted (racecraft), for the set up tips. It's been a while since I've had a set of Webers.
...Ed.
johnl
Re: Carb upgrade
January 30, 2012, 05:25:20 am »
Ed, I'm pleased to hear all worked out well. As I told you when I traded my 48 IDAs for a pair of 42DCNF9s all those years ago I was very pleased at how much more "street friendly" they were and really enjoyed the gas mileage improvement.
They may not look as flashy as a pair of 48s, but they'll definitely get the job done. Looking forward to seeing you and the car soon and thanks for taking that adventure with me yesterday.
Re: Carb upgrade
January 30, 2012, 14:03:45 pm »
I love my DCNFs...!
Re: Carb upgrade
January 30, 2012, 14:57:28 pm »
Very cool, Ed! Always dug on those carbs... great design/performance/mileage. Plus, with the Karmann Ghia body, you have nice access to them.
CONGRATS!
Cheesepanzer
Re: Carb upgrade
February 01, 2012, 00:27:22 am »
I've always loved DCNF's. A very destinct sound - very cool! Congrats!
63 Type 2 Single Cab
Cornpanzers
Fritter
Re: Carb upgrade
February 01, 2012, 00:43:34 am »
Looks great. I have a Deano DCN carb/manifold/linkage setup on my '64. They are very simple and smooth carbs. Also very tiny looking!
Mike F.
'64 Indigo Blue sunroof Bug
Re: Carb upgrade
February 01, 2012, 07:22:28 am »
great carb for a smooth drive with extra oomph!
edcraig
Re: Carb upgrade
February 02, 2012, 05:52:41 am »
Yep..Thanks guys. I'm very happy and pretty impressed. The more I drive it the more I like them. I always thought the Kadron/Solex carbs were pretty good, but the difference is huge. Power, idle are big improvements. They are extremely smooth, and have a great sound. Betting the gas milage will be better too.
Highly recommend them so anyone searching for a really good street carb application.
...Ed.
Re: Carb upgrade
February 02, 2012, 10:14:58 am »
Really cool set-up ya have there Ed, glad it all worked out. My very first set of Webers were new 42 DCNF's back in the day, great carbs.
Ted
Jeff68
Re: Carb upgrade
February 02, 2012, 14:20:51 pm »
Real world experience is good to hear. I have a pair of Berg 42DCNF's that I plan to use on the next engine I build. I've had them for a while but I'm waiting for the right Project to use them on. I will use them with a set of Berg 865 heads that I also have. Engine will most likely be a 1776. Glad the carbs work well!
markvo
Re: Carb upgrade
March 18, 2012, 06:15:29 am »
Is it getting full throttle? If not you can always move the arm down to middle hole in the center.
edcraig
Re: Carb upgrade
March 18, 2012, 06:42:11 am »
I believe I'm getting full throttle, but honestly, I haven't checked yet. Since the initial set up I've only had the make a few minor adjustments to the linkage. Just to improve the idle and carb sync. It was good from the start, but each adjustment seems to improve things. I'm going to drive it as is for a while before I touch the linkage again. It sure is a pleasure to drive now.
...Ed
