September 13, 2026, 07:55:08 am
352305 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  New cylinder heads
Pages: 1 [2] Print
Author Topic: New cylinder heads  (Read 52368 times)
exportbug
« Reply #30 on: October 29, 2012, 08:43:04 am »
Look here.....itīs German but many pictures to see.
http://bugfans.de/forum/wbx-fremdmotoren/7er-wbx-luft-fur-das-weisze-ungetum-t2693.html
The engine runīs very well and in the next year it will be go up to 2,8l Grin
Greetings Thorsten
More information's on www.tp-technologie.de
MeXX
« Reply #31 on: October 31, 2012, 22:11:07 pm »
Greetings Thorsten
Dear Thorsten
Are you able to sell me a set of your famous tool steel lifters.
I'm thinking of using them in my race engine: 2977cc T1
Do you think they will survive 8000 RPM at 550lbs to 580lbs
spring pressure at .660 lift ?
MeXX
Drag or Die
« Reply #32 on: November 01, 2012, 12:11:23 pm »
You do not need that much spring pressure @8000 , no matter what lifters weight you have
MeXX
« Reply #33 on: November 01, 2012, 14:51:18 pm »
Dear Udo
I know that it is to much, but it is just to be sure that it is enough to avoid valve float or even worse valve bounce at every RPM and everytime, otherwise it will kill power and parts.
MeXX
Drag or Die
« Reply #34 on: November 01, 2012, 17:24:32 pm »
I do up to 9000 with my 60 gramm lifters and K-800 springs . so if you have a light weight lifter the K-800 are ok
Elnef
« Reply #35 on: November 02, 2012, 06:41:37 am »
Titanium valves I guess ? what size
What type of pushrods ?
John
« Reply #36 on: November 03, 2012, 15:05:55 pm »
50x40 titanium valves and Gene Berg silver pushrods
TSAF
Italian toys - GERMAN WAR MACHINES
« Reply #37 on: November 07, 2012, 10:27:31 am »
Can these heads be used in a type iv engine?
Tobi/DFL
« Reply #38 on: November 07, 2012, 16:54:21 pm »
No, they canīt as the distance between the cylinders is different.
Tobi
-Alex-
« Reply #39 on: January 28, 2013, 10:09:55 am »
These heads look very promising, is he selling them yet?  I am very interested. I was thinking to stuff them with JPM springs and retainers and some manley type 4 valves 48x38..
Tobi/DFL
« Reply #40 on: January 28, 2013, 10:40:49 am »
Hi Alex,
indeed there are some news about these heads! Thorsten's 2.7L (86x100mm) engine was used successffully last season. At first it had some minor problems with knocking so the chambers got modified and all is okay now.
It made around 215rwhp (I canīt remember the exact number) while being 100% street worthy. The heads are cooling very good, even on high speed autobahn trips.
A second batch of heads have just been finished so there will be a few oxyboxers built for the upcoming season.
The heads have been tested on a flow bench. The exhaust port proved to be very effective while the inlet port and 46mm inlet valve seems to be a little restrictive and could obviously be improved with a bigger valve and some porting.
The price for a pair of bare heads (no valves, seats and valve guides), black anodized will be around 1.800 Euros.
Tobi
-Alex-
« Reply #41 on: January 28, 2013, 14:04:51 pm »
Definetly want to buy these heads.   Smiley It looks like a good idea to have throughholes for cooling air.   I heard that twinspark setup is very beneficial. Wonder if you can harness megasquirt and eight coils to work together Smiley If not, then just  correct distributor.
http://www.thesamba.com/vw/forum/viewtopic.php?t=374534
ovaldriver56
« Reply #42 on: January 28, 2013, 21:20:38 pm »
Got to see these heads at the Wintermeet in Herford some days ago.
Pure cylinder head porn  Kiss
-Alex-
« Reply #43 on: February 01, 2013, 22:51:28 pm »
These heads will be a nice pair with my 4" nickies  Tongue
-Alex-
« Reply #44 on: May 14, 2013, 20:51:50 pm »
I have heard that there is better improved version coming from Thorsten Wink  And i am getting one pair these improved heads Cheesy
Tobi/DFL
« Reply #45 on: May 14, 2013, 22:08:42 pm »
Hi Alex,
you are right. The third batch of heads with some improvements (one of which being a more efficient inlet port) is getting machined right now. Great to see some more engines with these heads very soon...! Wink
Tobi
-Alex-
« Reply #46 on: May 15, 2013, 06:20:16 am »
Intake port on new version is much more straigth and smoother.  Looks also a bit bigger.  He has finished few sets, in a few weeks i will get mine  Grin
Old and new intake port  Grin
« Last Edit: May 15, 2013, 12:54:51 pm by -Alex- » Logged
numbnuts
« Reply #47 on: November 01, 2015, 09:23:07 am »
Any more progress on this?
2854cc 1956 cal looker coming to this space shortly
spanners
« Reply #48 on: November 01, 2015, 21:01:00 pm »
Very very nice, The evo intake port is an improvement, even on stock style ports like 044 etc,  I see the mistake most tuners make by removing meterial from the intake port floor below the bump, valve Spring seat looks substantial enough too, pics show wasser stud spacing dimensions I take it?
Best regards, spanners.
Pages: 1 [2] Print
