September 25, 2026, 18:29:49 pm
WBX std crank for 500HP??
Topic: WBX std crank for 500HP?? (Read 6997 times)
JIMP
February 10, 2012, 20:43:00 pm »
Hello all
we're thinking of going with a wbx-oxy case and std wbx crank for our turbo drag race car, do you think the stock crank can handle 500HP or we have to make mods -welding balancing weightss etc-, I really would like to hear your opinion before start working on it, cheers and thanks
Friendly
Dimitrios
bang
Re: WBX std crank for 500HP??
February 10, 2012, 20:48:13 pm »
I would order a dpr crank or machine the case to fit a flange crank.
SSRT
February 10, 2012, 21:30:25 pm »
No problem,- use the std crank.
Have used std balanced crank in my over 600 hp engine for many years no, racing and dayli driven, and not even changed the bearings.
JIMP
February 10, 2012, 22:29:02 pm »
Hello
Peter do you happen to know, DPR only adds the counterweights or makes other changes too? I'm thinking for example to ofset grind the rod bearings to get some extra throw, I have a set of Pauter rods with chevy bearing I could use, the overall thought was to use what we have on the selve and not buy other parts
SSRT you mean completely std crank without extra weights, only balanced as is? Any extra dowels on the flywheel besides the 5 bolts? What you used as pressure plate for that power, a kennedy or something else?
Thanks for your time
Friendly
Dimitrios
February 11, 2012, 01:11:09 am »
DPR can do it all for you, I got one from them with counterweights and its stroked with type4 center main.
bang
February 11, 2012, 08:13:49 am »
my 2 dpr cranks was 86mm stroke, counterweight, with wedge made flywheel. and with 2" chevy.
it is wery nice work he does so if i build oxy agin it will dpr.
February 11, 2012, 08:52:27 am »
Quote from: JIMP on February 10, 2012, 22:29:02 pm
Hello
Don't cut it down to chevy journal . The vw journal makes it stronger .
Last Edit: February 11, 2012, 08:54:17 am by Udo
www.Udobeckertuning.de
JIMP
February 12, 2012, 20:54:40 pm »
O.K. so can anyone say or pm some estimated cost of DPR for a crank made like this? I really would like to know if it fits my financials before contacting them, cheers and thanks
Friendly
Dimitrios
bang
February 12, 2012, 22:19:43 pm »
send jose a mail he is very friendly
February 14, 2012, 12:45:56 pm »
Before you buy a welded crank- i have an original oettinger 82 mm wbx crank for sale. It is cut for first undersize and nitrided also ready ballanced with a 914 flywheel wich is the only steel flywheel for type4 . The crank and flywheel have dowel pins and shaft bolts. Ready for dragracing but i do not know if this holds up your turbo engine
