July 02, 2026, 16:14:32 pm
Latest Member: bigsiembowski
| | |-+  Long Barrels......
Author Topic: Long Barrels......  (Read 9535 times)
« on: February 12, 2012, 05:21:48 am »
Who makes a good long 94mm barrel for the street, made in the states, or is Chinese the only ones?
Ted
« Reply #1 on: February 12, 2012, 10:06:16 am »
Ted
JPM, REV and Autocrafts are good choices I think. The new Autocrafts looks really nice and thick.
-BB-
Catbox
Slave to internal combustion.
« Reply #2 on: February 12, 2012, 18:47:54 pm »
I just bought the Revmasters.
I had them machined at Jaycee's to my length.  They look good and fit the case great!
They also seem to have a uniform thickness all the way down the cylinder compared to the Mahle's.
Mahle
They are also 19mm at the top where as the Mahle's are almost 16mm
But....
You can see in this photo that the top of the cylinder is thicker than the Mahle that is next to it.
This makes it not fit in my fancy head so well....
I will have them trimmed to fit the heads as I don't want to make these expensive heads only fit these cylinders.
They look great otherwise and they just need some extra attention that I did not expect.
 Grin
« Last Edit: February 12, 2012, 18:50:13 pm by catbox » Logged
« Reply #3 on: February 13, 2012, 00:19:50 am »
AA performance do longer barrels
Greg G
« Reply #4 on: February 13, 2012, 05:12:35 am »
I just put a set of long AA cylinders with AA forged pistons in my turbo motor.
« Last Edit: February 13, 2012, 05:22:42 am by Greg G » Logged
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #5 on: February 13, 2012, 14:17:54 pm »
  Ted,
  BUGPACK
« Reply #6 on: February 13, 2012, 19:05:36 pm »
Greg, what´s the thickness of the AA´s?
Greg G
« Reply #7 on: February 14, 2012, 07:12:06 am »
These are the same dimensions as a Cima cylinder, but AA does have a similar cylinder with a 96.7 top (4.100 diameter).
Here one next to a standard cylinder
drgouk
« Reply #8 on: February 14, 2012, 11:50:45 am »
Pauter Machine Co.
NoBars
« Reply #9 on: February 24, 2012, 04:58:03 am »
Tell me about your mandrel Greg.
Greg G
« Reply #10 on: March 04, 2012, 01:50:46 am »
just your normal expanding mandrel. I'll get the manufactures name.
« Reply #11 on: March 04, 2012, 06:30:25 am »
Thats something I wouldn't mind having being I'm a machinist. Yes, the name of the manufacture, Thanks.
Ted
« Reply #12 on: March 04, 2012, 13:19:45 pm »
I have a set of AA long barrels, but I have now got a raised deck case so they will not be needed.  Check that you will actually need them.
« Reply #13 on: March 04, 2012, 17:04:23 pm »
Ted,
what happened to your screen name? someone messed around with it Wink Cheesy
« Reply #14 on: March 04, 2012, 17:10:27 pm »
Lids,
not necessarily true,depending on what stroke and rod length you use you may need to deck the case some and still use them[long barrells],if its a short rod on a reasonable stroke,84mm say, then the cylinder may not support the piston properly at BDC,this is the main disadvantage I have seen with the CB ally case with raised deck,the piston comes out the end of the barrell and is in the raised deck area which doesnt support it now,it all depends on the combo,just another thing to check
Greg G
« Reply #15 on: March 20, 2012, 17:45:35 pm »
Not sure where we purchased it but this is the site of the manufacturer of it.
http://www.kolee.com/SMALLTOOLS/ExpandingMandrelsInfo/tabid/144/Default.aspx
