September 23, 2026, 14:45:57 pm
| | |-+  2276cc t1 with 180 ft/lbs torque
Author Topic: 2276cc t1 with 180 ft/lbs torque  (Read 5313 times)
Bad bug
« on: March 04, 2012, 13:42:31 pm »
Good day All,
Has anyone here done a 2276cc engine that made 180 ft/lbs of torque at the wheels need the combo for that, also what is the most whp and torque you can get from a 2165cc engine. I need to decide which crank i will be using in my build.
As it is now i am after a certain torque to the wheel figure as you can see. Engine will be natural aspirated.
fredy66
« Reply #1 on: March 04, 2012, 15:17:36 pm »
its not done but here is some good info
http://cal-look.no/lounge/index.php/topic,14057.0.html
arabia slugs
neil68
« Reply #2 on: March 04, 2012, 22:00:00 pm »
With a few more cc's, my 2332 cc made 180 HP and 170 ft lb to the wheels with IDA's on 91 octane, web 86C, CB 044 heads ported by K-Roc 44 x 37 valves and 10.5:1 CR:
<a href="http://www.youtube.com/v/FF2gCti3dro" target="_blank">http://www.youtube.com/v/FF2gCti3dro</a>
I'm sure with some additional tuning or head work, you could get 180 torque...
« Last Edit: March 04, 2012, 22:06:09 pm by neil68 » Logged
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Bad bug
« Reply #3 on: March 05, 2012, 01:08:16 am »
Hey neil,
I wanted to build a 2332cc t1 but the fact that i might have to slap the cylinder head tins to have them sit on the heads properly didn't appeal to me that's the reason for stepping down to a 2276cc engine however a 2165 would be better.
« Reply #4 on: March 08, 2012, 20:24:41 pm »
Hey neil,
not sure if i understand this correctly, but to me Mahle B's have the same deckhight as a standard 1600 engine if i am correct. on my 2276 i used 1mm shims, the tin fitted nicely.
