September 24, 2026, 03:03:17 am
| | |-+  Need a Bay Window Suspension Ball Joint Removal Tool
Author Topic: Need a Bay Window Suspension Ball Joint Removal Tool  (Read 6922 times)
rick m
« on: June 21, 2012, 16:41:36 pm »
Does anyone know who sells a Bay Window bus front control arm ball joint removal tool?  I would like to have one for the work I am doing on my Bay Window. Please recommend someone (if you know of a company) that sells the one specifically for the Bay Window front arms.
Rick M
Rick Mortensen
Driving Hot VWs since 1970
« Reply #1 on: June 21, 2012, 17:26:57 pm »
The bottom ball joints are usually the tough ones to get off the spindle. I used a regular removal tool but had to trim about a half inch of threads off of the ball joint to make it work. Like this one.
http://www.nextag.com/Specialty-Products-Company-37990-1259944683/prices-html
« Reply #2 on: June 21, 2012, 18:07:39 pm »
I don't know if a company made a specific tools but an hydraulic press works for me. A bit tricky to keep the arm in the press thought...
« Reply #3 on: June 21, 2012, 18:47:07 pm »
I think the tool he is using is made by PROTO.
<a href="http://www.youtube.com/v/ihW9jNLjLZI" target="_blank">http://www.youtube.com/v/ihW9jNLjLZI</a>
Geoff P DVKK
« Reply #4 on: June 21, 2012, 19:59:21 pm »
Have a torch handy......they can be real buggers to get out.
Tony Wilkie
« Reply #5 on: June 21, 2012, 22:52:07 pm »
Hey Rick,
The bus ball joints can be a pain in the a$$ to press out. If you need any help, let me know...I'm back in AZ, not far from surprise (lake pleasant/jomax)
Your welcome to use any of my tools if needed.
Thanks,
Tony
Operations Trask Manufacturing
Design, Prototype, & Dyno Tune Custom Motorcycle Exhaust
Russell
« Reply #6 on: June 22, 2012, 00:40:11 am »
Rick i made a simple frame and pulled the arms out and did them in the press, very easy that way will post some pics of frame.
Best Regards
Russell
rick m
« Reply #7 on: June 22, 2012, 01:42:14 am »
Tony,
I live about 10 minutes from Speedworld off Patton Road. Send me a PM with your contact info and I will give you a call.
Russell, would be interested in seeing what you guys made. I fabricate a lot of my own stuff too.
Rick M
Rick Mortensen
« Reply #8 on: June 22, 2012, 16:55:22 pm »
If you are trying to press the ball joints out of the trailing arm be careful. I had a friend do mine in his shop. he has a set of original VW fixtures and has done it a hundred times. After watching his press nearly come of the ground when they came loose I`m glad I had him do it.
Russell
« Reply #9 on: June 23, 2012, 19:10:24 pm »
See below
Best Regards
Russell
Russell
« Reply #10 on: June 23, 2012, 19:12:23 pm »
and more
Best Regards
Russell
whirligig
« Reply #11 on: June 23, 2012, 22:42:22 pm »
well I always grind the cap off and punch out the pin and then hacksaw 2 slots,carefully!,in the cup all the way through .its easy to punch out then .have refitted them in a large vice with a socket but you have to take boot off and you can break the vice.but it is posible for an old school mechanic /hotrodder Cool
old school racer-getting older-now crew chief
Geoff P DVKK
« Reply #12 on: June 24, 2012, 02:19:12 am »
Living in the Great White North we get a lot more rust than most of you. I did a set of Cali arms a few months ago and Wow what a difference from the ones we see every day here.
rick m
« Reply #13 on: June 24, 2012, 06:19:44 am »
Russell....such a simple idea and great way to get them out.  Thanks for posting the pictures. I have some good Chromoly plate I am going to use for the two uprights as it is harder than mild steel.  I will post a shot when I finish my jig. Thanks for sharing.
Rick Mortensen
Rick Mortensen
Russell
« Reply #14 on: June 24, 2012, 20:06:30 pm »
Rick
no problem, glad too help.
Russell
Best Regards
Russell
