September 22, 2026, 06:07:51 am
| | |-+  Leaking oil from cylinder 3
Author Topic: Leaking oil from cylinder 3  (Read 4883 times)
Erlend / bug66
Global Moderator
SCC Event
« on: June 25, 2012, 23:04:21 pm »
Hi everybody.
My retty beefy 1915 has a problem holding it's fluids. 1,2 and 4 s completely dry, but #3 is wet. It's dry above the middle of the cylinder against numer 4, so it's not the cooler.
Cylinders on the left side is off, and I can't find any cracks. All casesavers look fine (can't really see the deep stud)
Have any body had a leak between the block and the cylinders?
Or is it a crack in the deep stud area?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
« Reply #1 on: June 26, 2012, 05:50:52 am »
It's possible sometimes that when you're drilling to insert the deep #3 stud, you poke a hole into the case.  Even though you are plugging it with the stud, oil will still flow as if it's a big hole.
Erlend / bug66
Global Moderator
SCC Event
« Reply #2 on: June 26, 2012, 08:21:00 am »
Factory german AS41 case.. With deep stud from the factory.
The '67:
The '59:
Not yet..
« Reply #3 on: June 26, 2012, 08:38:10 am »
Ist it possible that there is a small scratch in the case surface or the case saver is not in deep enough and the cylinder rests on it,or just the sealant you used is not 100%,is it dry behind the flywheel?
cheers richie
Erlend / bug66
Global Moderator
SCC Event
« Reply #4 on: June 26, 2012, 08:44:34 am »
I got the casesavers I changed deep enough, so the surface between cylinder and case is good.
Looks to be dry behind the FW yes.
My guess is really thin oil (10W-40 synth) combined with a hot engine and missed a spot of sealant under the cylinder.
The '67:
The '59:
Not yet..
whirligig
« Reply #5 on: June 27, 2012, 12:30:44 pm »
had a porous case once in a bay,had to run it on floor with no tin to find leak,coming out of case on top from gallery to oil cooler .that ran down onto no3.
old school racer-getting older-now crew chief
