September 22, 2026, 06:07:06 am
Leaking oil from cylinder 3
Topic: Leaking oil from cylinder 3 (Read 4881 times)
June 25, 2012, 23:04:21 pm »
Hi everybody.
My retty beefy 1915 has a problem holding it's fluids. 1,2 and 4 s completely dry, but #3 is wet. It's dry above the middle of the cylinder against numer 4, so it's not the cooler.
Cylinders on the left side is off, and I can't find any cracks. All casesavers look fine (can't really see the deep stud)
Have any body had a leak between the block and the cylinders?
Or is it a crack in the deep stud area?
Re: Leaking oil from cylinder 3
June 26, 2012, 05:50:52 am »
It's possible sometimes that when you're drilling to insert the deep #3 stud, you poke a hole into the case. Even though you are plugging it with the stud, oil will still flow as if it's a big hole.
June 26, 2012, 08:21:00 am »
Factory german AS41 case.. With deep stud from the factory.
June 26, 2012, 08:38:10 am »
Ist it possible that there is a small scratch in the case surface or the case saver is not in deep enough and the cylinder rests on it,or just the sealant you used is not 100%,is it dry behind the flywheel?
June 26, 2012, 08:44:34 am »
I got the casesavers I changed deep enough, so the surface between cylinder and case is good.
Looks to be dry behind the FW yes.
My guess is really thin oil (10W-40 synth) combined with a hot engine and missed a spot of sealant under the cylinder.
whirligig
June 27, 2012, 12:30:44 pm »
had a porous case once in a bay,had to run it on floor with no tin to find leak,coming out of case on top from gallery to oil cooler .that ran down onto no3.
old school racer-getting older-now crew chief
